• dimir
  • Laatst online: 06-10 17:11
Hoi iedereen.
Hier mijn S.M.A.R.T LOG VAN MIJN KINGSTON SNV425S264GB ssd
Volgensmij is deze opa niet al te betrouwbaar meer :p
Heb er ubuntu op staan sinds gisteren en tot nu toe nog geen probleem.
Doordat ik al heel lang geen accu meer in mijn oude laptop heb zitten, is mijn :
192 Unexpect_Power_Loss_Ct 0x0012 100 100 000 Old_age Always - 0
op zijn aller ergste, tis eigenlijk een wonder dat ie et nog doet :p
smartctl 6.5 2016-01-24 r4214 [x86_64-linux-4.10.0-32-generic] (local build)
Copyright (C) 2002-16, Bruce Allen, Christian Franke, www.smartmontools.org
=== START OF INFORMATION SECTION ===
Model Family: JMicron based SSDs
Device Model: KINGSTON SNV425S264GB
Serial Number: 07MA30067643
Firmware Version: C091126a
User Capacity: 58,506,416,640 bytes [58,5 GB]
Sector Size: 512 bytes logical/physical
Rotation Rate: Solid State Device
Form Factor: 2.5 inches
Device is: In smartctl database [for details use: -P show]
ATA Version is: ATA8-ACS (minor revision not indicated)
SATA Version is: SATA 2.6, 3.0 Gb/s
Local Time is: Sun Aug 27 09:50:57 2017 CEST
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
=== START OF READ SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
General SMART Values:
Offline data collection status: (0x00) Offline data collection activity
was never started.
Auto Offline Data Collection: Disabled.
Self-test execution status: ( 0) The previous self-test routine completed
without error or no self-test has ever
been run.
Total time to complete Offline
data collection: ( 30) seconds.
capabilities: (0x1b) SMART execute Offline immediate.
Auto Offline data collection on/off support.
Suspend Offline collection upon new
command.
Offline surface scan supported.
Self-test supported.
No Conveyance Self-test supported.
No Selective Self-test supported.
SMART capabilities: (0x0003) Saves SMART data before entering
power-saving mode.
Supports SMART auto save timer.
Error logging capability: (0x01) Error logging supported.
General Purpose Logging supported.
Short self-test routine
recommended polling time: ( 1) minutes.
Extended self-test routine
SMART Attributes Data Structure revision number: 16
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE
1 Raw_Read_Error_Rate 0x000b 100 100 050 Pre-fail Always - 0
2 Throughput_Performance 0x0005 100 100 050 Pre-fail Offline - 0
3 Unknown_JMF_Attribute 0x0007 100 100 050 Pre-fail Always - 0
5 Reallocated_Sector_Ct 0x0013 100 100 050 Pre-fail Always - 0
7 Unknown_JMF_Attribute 0x000b 100 100 050 Pre-fail Always - 0
8 Unknown_JMF_Attribute 0x0005 100 100 050 Pre-fail Offline - 0
9 Power_On_Hours 0x0012 100 100 000 Old_age Always - 29428
10 Unknown_JMF_Attribute 0x0013 100 100 050 Pre-fail Always - 0
12 Power_Cycle_Count 0x0012 100 100 000 Old_age Always - 5302
168 SATA_Phy_Error_Count 0x0012 100 100 000 Old_age Always - 0
175 Bad_Cluster_Table_Count 0x0003 100 100 010 Pre-fail Always - 8
194 Temperature_Celsius 0x0022 041 100 020 Old_age Always - 41 (Min/Max 24/41)
197 Current_Pending_Sector 0x0012 100 100 000 Old_age Always - 0
240 Unknown_JMF_Attribute 0x0013 100 100 050 Pre-fail Always - 0
170 Bad_Block_Count 0x0003 100 100 010 Pre-fail Always - 229 349 58
173 Erase_Count 0x0012 100 100 000 Old_age Always - 21882 40679 25553
SMART Error Log Version: 1
Warning: ATA error count 65535 inconsistent with error log pointer 3
ATA Error Count: 65535 (device log contains only the most recent five errors)
CR = Command Register [HEX]
FR = Features Register [HEX]
SC = Sector Count Register [HEX]
SN = Sector Number Register [HEX]
CL = Cylinder Low Register [HEX]
CH = Cylinder High Register [HEX]
DH = Device/Head Register [HEX]
DC = Device Command Register [HEX]
ER = Error register [HEX]
ST = Status register [HEX]
Powered_Up_Time is measured from power on, and printed as
DDd+hh:mm:SS.sss where DD=days, hh=hours, mm=minutes,
SS=sec, and sss=millisec. It "wraps" after 49.710 days.
Error 65535 occurred at disk power-on lifetime: 29426 hours (1226 days + 2 hours)
When the command that caused the error occurred, the device was active or idle.
After command completion occurred, registers were:
ER ST SC SN CL CH DH
40 51 00 88 0b 00 e0 Error: UNC at LBA = 0x00000b88 = 2952
Commands leading to the command that caused the error were:
CR FR SC SN CL CH DH DC Powered_Up_Time Command/Feature_Name
c8 00 08 88 0b 00 e0 08 01:12:32.900 READ DMA
c8 00 08 80 0b 00 e0 08 01:12:32.900 READ DMA
c8 00 08 78 0b 00 e0 08 01:12:32.900 READ DMA
c8 00 08 70 0b 00 e0 08 01:12:32.900 READ DMA
c8 00 08 68 0b 00 e0 08 01:12:32.900 READ DMA
Error 65534 occurred at disk power-on lifetime: 29426 hours (1226 days + 2 hours)
c8 00 08 88 0b 00 e0 08 01:12:32.800 READ DMA
c8 00 08 80 0b 00 e0 08 01:12:32.800 READ DMA
c8 00 08 78 0b 00 e0 08 01:12:32.800 READ DMA
c8 00 08 70 0b 00 e0 08 01:12:32.800 READ DMA
c8 00 08 68 0b 00 e0 08 01:12:32.800 READ DMA
Error 65533 occurred at disk power-on lifetime: 29426 hours (1226 days + 2 hours)
c8 00 08 88 0b 00 e0 08 01:12:32.700 READ DMA
c8 00 08 80 0b 00 e0 08 01:12:32.700 READ DMA
c8 00 08 78 0b 00 e0 08 01:12:32.700 READ DMA
c8 00 08 70 0b 00 e0 08 01:12:32.700 READ DMA
c8 00 08 68 0b 00 e0 08 01:12:32.700 READ DMA
Error 65532 occurred at disk power-on lifetime: 29426 hours (1226 days + 2 hours)
c8 00 08 88 0b 00 e0 08 01:12:31.200 READ DMA
c8 00 08 80 0b 00 e0 08 01:12:31.200 READ DMA
c8 00 08 78 0b 00 e0 08 01:12:31.200 READ DMA
c8 00 08 70 0b 00 e0 08 01:12:31.200 READ DMA
c8 00 08 68 0b 00 e0 08 01:12:31.200 READ DMA
Error 65531 occurred at disk power-on lifetime: 29426 hours (1226 days + 2 hours)
c8 00 08 88 0b 00 e0 08 01:12:29.400 READ DMA
c8 00 08 80 0b 00 e0 08 01:12:29.400 READ DMA
c8 00 08 78 0b 00 e0 08 01:12:29.400 READ DMA
c8 00 08 70 0b 00 e0 08 01:12:29.400 READ DMA
c8 00 08 68 0b 00 e0 08 01:12:29.400 READ DMA
SMART Self-test log structure revision number 1
Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error
# 1 Short offline Completed without error 00% 29428 -
# 2 Short offline Completed without error 00% 29428 -
# 3 Extended offline Completed without error 00% 29428 -
# 4 Extended offline Completed without error 00% 29428 -
# 5 Short offline Completed without error 00% 29428 -
# 6 Short offline Completed without error 00% 29413 -
# 7 Extended offline Completed without error 00% 29375 -
# 8 Short offline Completed without error 00% 29375 -
# 9 Short offline Completed without error 00% 14469 -
#10 Extended offline Completed without error 00% 14468 -
#11 Extended offline Self-test routine in progress 00% 14468 -
Selective Self-tests/Logging not supported
Wordt et tijd voor een nieuwe ? (hi hi)
groeten :)
  • dcm360
dcm360
Moderator Discord
HD7767 powered
dimir schreef op zondag 27 augustus 2017 @ 10:16:
Hoi iedereen.
Ehm, nog nooit onverwacht stroom verloren op zijn aller ergste? Weet je hoe je smart-waarden moet lezen?
  • Kortfragje
  • Laatst online: 15-11 22:27
Kortfragje
Met 65000+ errors is er wel een probleem... Ofwel een kabel probleem, ofwel een disk probleem...
Ik denk dat eerste vanwege het feit dat je disk tests geen fouten geven, maar ben geen expert.
Kan je dit niet beter in het 'check je smart' topic plaatsen?
[ Voor 23% gewijzigd door Kortfragje op 27-08-2017 11:06 ]
http://www.gjpvanwesten.nl
  • dimir
ah dankjewel, ik wist niet dat er zo en topic was,.
ik zal et daar zo posten
