creditcard cdr doet het niet.
  • WhiteAss
  • Laatst online: 13-09 08:55
Ik heb pas een paar cdr's gekocht die het formaat van een creditcard hebben maar nu wil mijn brander die cd's niet pakken.
Ik heb in plextor8220. wanneer ik de cd plaats gaat er een led knipperen verder nix.
dit is de melding die ik van een brand prog. (feurio) krijg.
SCSI error: TRACKING SERVO FAILURE
There is an error at the servo unit of the writing head.
This is a hardware error of the writer. Possible causes:
- Overburning: If you overburn a CD-R, it will be written in non-specified ranges of the CD. Of course, the coating is not as "good" there. (is het niet)
- Defective medium:
On the medium the track isn't prestamped correctly. This could be caused by a damaged blank (scratches, fingerprints). When using "no-name" blanks there are some blanks with the wrong coating, sometimes you can even see "holes" with the naked eye!
It could just be that your writer doesn't "like" this kind of blanks, it would be best to try some other blanks!(mogelijk)
- Writer overheated:
In general, the higher the temperature, the worse the focussing of the laser. If the writer is internal, please see to it that the writer has adequate ventilation! Most writers work up to 40°C, in a tower normally it will be hotter - particulary when using high-performance hard discs. Just touch your writer to feel how hot it is. - Vibrations:
Often the cause for this error are vibrations, e.g. transferred by a nearby fast CD-Rom. This causes the write-head of the writer to swing, such that the track following is disturbed. If possible, don't install the writer near to the CD-Rom; if necessary, suspend the drive dampedly or install it externally.(is het niet)
- Misalignment/fatigue of the laser:
Unfortunately the laser of a writer"fatigues" in time, also the head misaligns (and with it the focussing of the laser) in time.
In this case, unfortunately, you should think about buying a new CD-Writer!
However, often it is possible still to burn at lower speeds!(ook niet)
- Drivers of other programs:
Unfortunately some other burning programs install drivers that don't behave"neutrally" in the system, but send commands to the writer that can "confuse" the writer.
Please call at the menu "Extras" the "System Diagnosis" to check the configuration of your system! (is het ook niet)
zouden alle 3 de cd's defect kunnen zijn? of is het toch iets anders.
  • SmokeyTheBandit
  • Laatst online: 17-06 10:20
SmokeyTheBandit
DOCer met Pensioen
waar heb je die cdrs gekocht ????
Turn it off and on again.
  • SmokeyTheBandit
SmokeyTheBandit
DOCer met Pensioen
probeer nero eens en is je firmware up to date
  • P5ycho
  • Laatst online: 23:09
Op zondag 08 juli 2001 20:38 schreef Smokey_The_Bandit het volgende:
het is een hardware failure, nero zal vast dezelfde melding geven. of een andere, maar door dezelfde oorzaak. foutmeldingen willen nog wel eens wisselen per writingtool.
firmware zou misschien helpen, maar ik denk het niet.
12x 280Wp ZO, 9x 280Wp + 8x 465Wp ZW, Zubadan SHW80YAA 8kW, Zehnder Q450 ERV
  • Kaj.
Kaj.
1 LED is niet genoeg
Kicked/to.OM
  • PipoDeClown
PipoDeClown
Izze Zimpell
rechthoekige cd's :? :? :?
God weet alles, want hij is lid van de Mosad. To protect your freedom i will take that away from you. Mijn drankgebruik heeft ernstig te lijden onder mijn gezondheid.
  • Diamon
  • Laatst online: 23:21
Diamon
The Weird One
Je kunt hem niet gebruiken als creditcard he :+
Maar moet de brander ook niet weten dat zo'n ding er in ligt.
Past dat wel in je brander :?
And The Only One
  • AFR
AFR
De foutmelding die je noemt ontstaat doordat de laserkop niet snel genoeg kan worden gepositioneerd als er een rechthoekige CDR in je brander zit.
Met een beetje geluk kun je de CD wel branden op een lagere snelheid (positioneringsfout neemt immers grofweg exponentieel toe met brandsnelheid).
Wanneer dit niet lukt moet je op zoek gaan naar zogenaamde "Clear Discs". Dit zijn normale, ronde, CD's die transparant zijn rond de aangebrachte vorm. In jouw geval dus: een rechthoekig CDR gedeelte met daarom heen een doorzichtig gedeelte om voor een goed krachtenspel in je brander te zorgen.
(voor meer info zie: http://www.cdfabriek.nl)
Zo'n ding raakt toch heel makkelijk in onbalans (trillen in je writer :? ) Lijkt me dat je daar idd iets van een inleghoes voor nodig hebt om dat trillen tegen te gaan...
  • R2
  • Registratie: Juli 1999
  • Laatst online: 14-02-2022
R2
Nee nee, de Plextor 8220 kan niet overweg met 8cm cd recordables, dus ook niet die vierkante, dus stop er maar mee, ik heb hier over gemailed met plextor en de 8cm cd recordables wordt pas ondersteund vanaf de 12x series, ook met een firmware upgrade is dit niet te wijzigen, zit gewoon in de hardware.
Ik heb zelf later een Plextor SCSI 12 speed brander gehaald en nu geen problemen meer.
  • WhiteAss
dat is dan jammer maar heelaas :(
Wie wil er 3 creditcard cd's kopen :)
  • ScooBY_DoO
  • Laatst online: 07-09 21:42
LOL...........hoe zien die dingen eruit dan!?
Ik heb die link van de cdfabriek ff bekeken maar zie alleen een lemonshaped cdr.......!
Heb je pics van zo'n ding?
  • Pizzaman
Pizzaman
16:00 Cup-a-soup.
Ik heb ze ook, zal ff een plaatje schieten met de webcam, moment :)
  • ScooBY_DoO
Kewl........ ben benieuwd
  • Pizzaman
Pizzaman
16:00 Cup-a-soup.
Afbeeldingslocatie: http://members1.chello.nl/~ah.hoogerdijk/Foto%201.jpg
Afbeeldingslocatie: http://members1.chello.nl/~ah.hoogerdijk/Foto%202.jpg
Afbeeldingslocatie: http://members1.chello.nl/~ah.hoogerdijk/Foto%203.jpg
heej, stoere dingetjes man, jammer dat ze het niet doen heh? :P
  • Pizzaman
Pizzaman
16:00 Cup-a-soup.
Op maandag 09 juli 2001 15:43 schreef powerpulse het volgende:
Ik heb nergens last van |:(
  • SiGNe
  • Laatst online: 18-06 00:01
SiGNe
Ook hoi!
Op zondag 08 juli 2001 23:25 schreef Stoned-cow het volgende:
Wat moet er in onbalans zijn dan?
Zo'n ding is gewoon vierkant en dus zijn de "G" krachten op alle 4 de uiteinden gelijk.
Niet?
[Specs]
  • ScooBY_DoO
WHoehahahahahha KICK ASS!!!!
ik wist verdomme helemaal niet dat zuks bestond!
LOL
Kosten die dingen?? en wie verkoopt ze allemaal???
Op maandag 09 juli 2001 15:45 schreef Pizzaman het volgende:
[BLAAT]
Ik bedoel dus niet dat ze het HELEMAAL niet doen, tuurlijk doen ze het wel, dat werd daarboven ook wel verteld, het is alleen jammer dat ze het bij HEM niet doen... :Z
  • AFR
AFR
Waar kun je die CDR's in normale aantallen kopen? Ik kan ze nergens vinden.
Het heeft wel iets speciaals om je software/afstudeerverslag op die CD-tjes te distributeren. *D
  • Dr.Q
  • Laatst online: 18-07 16:21
Holcom Computers Zuidbroek (waar ik werk) verkoopt ze ook, ik zal es kijken hoeveel ze kosten....
Inmiddels onderdeel van de huisraad... ;)
  • WhiteAss
Ik heb ze gekocht bij www.cdrwinkel.com (natuurlijk met een hele lading andere cd's anders werden ze wel wat duur met de verzendkosten.
  • SkoolieDie
En ik heb ze gekocht bij Opussupplies
Als het niet lukt met je brander kun je altijd nog die kleine 200Mb CD's kopen.
Heb je toch nog een beetje koelheidsfaktor. *D
/Edit
CardCD's waren geloof ik rond de 2,50 met jewelcase.
