[DIABLO 2] cube combo's
  • 146 views sinds 30-01-2008
  • Crysania
  • Laatst online: 23-10 23:48
weet iemand nog gave combinaties voor de horadric cube, ik weet de standaard dingen wel enzo, maar volgens mij zijn er nog veel meer,
ook voor LOD de combo's graag, ik zou graag iets doen met runes en jewels, wan die dingen zijn alleen gewoon waardeloos.
  • HitmanWVU
  • Laatst online: 04-08-2025
Transmuting Formulae
Listed below are recipes for the Horadric Cube. We will be revealing more recipes as they are discovered. Simply place the items in the first half of the equation into the Cube and hit the Transmute Button to produce the item in the second half of the equation.
3 Perfect Skulls + 1 Rare Item + Stone of Jordan = Add 1 Socket To a Rare Item
Rare Items can only have one socket. You cannot add more than one socket. You cannot add sockets to items that don't normally have sockets.
1 Perfect Skull + 1 Rare Item + Stone of Jordan = 1 High Quality New Rare Item of the same type
This formula has the possiblity of creating a higher quality Rare Item than the following formula. ilvl=66.
6 Perfect Skulls + 1 Rare Item = 1 Random Low Quality Rare Item of the same type
You can use this formula to get another chance at a Rare Item of the same type. ilvl=40. Be warned that if you use a Sword you may get a Socketed Longsword instead. This formula will not work on items larger than 3x2.
4 Health Potions (of any type) + Ruby (any type) + Magical/Set/Rare Sword (Any type) = Long Sword of the Leech
You can use this formula to get a Life Stealing Long Sword.
3 Rings = 1 Random Amulet
Save any unwanted rings for the chance of getting a high quality amulet. The ilvl=[(3*CharacterLevel)/4]+3. This means at Character Level 65, ilvl=51.75. So any Magical Prefix or Suffix with a level of 51 and below might be available. Since +2 to Skills amulets, have a level of 90, it's not possible to create a +2 to skills Amulet with this formula.
3 Amulets = 1 Random Ring
Save any unwanted amulets for the chance of getting a high quality ring. The ilvl=[(3*CharacterLevel)/4]+3. This means at Character Level 65, ilvl=51.75. So any Magical Prefix or Suffix with a level of 51 and below might be available.
3 Health Potions + 3 Mana Potions = 1 Rejuvenation Potion
Use this formula if you are in need of instant healing and/or mana. Any grade of Health/Mana Potion can be used.
3 Health Potions + 3 Mana Potions + 1 Gem (Any Grade) = 1 Full Rejuvenation Potion
Use this formula if you are in need of instant full healing and/or mana. Any grade of Health/Mana Potion or Gem can be used.
3 Small Rejuvenation Potions = 1 Full Rejuvenation Potion
3 Gems of the Same Type and Grade (lower than Perfect) = 1 Higher Grade Gem of the Same Type
Use this formula to upgrade your growing masses of low quality Gems into something more useful.
3 Chipped Gems and 1 Sword = 1 Socketed Long Sword
For those that are having trouble finding a socketed weapon. Any One-Handed Sword can be used.
2 Quivers of Bolts = 1 Quiver of Arrows
For users of Bows that are in need of ammunition. Random quantity of Arrows produced.
2 Quivers of Arrows = 1 Quiver of Bolts
For users of Crossbows that are in need of ammunition. Random quantity of Bolts produced.
1 Spear + 1 Quiver of Arrows = 1 Stack of Javelins
Mainly for Amazons that are in need of Javelins to use with skills. Any class/type of Spear can be used.
1 Axe + 2 Daggers = Throwing Axe
Any class/type of Axe can be used (i.e. magic/socketed/non magical axe/etc). Random quantity of throwing axes produced.
3 Perfect Gems (of any type) + 1 Magic Item = 1 New Random Magic Item of the Same Type
You can use this formula to get another chance at a Magic Item of the same type. The ilvl=100. This means that any Magical Prefix or Suffix with a level of 100 or less (which is all of them) is available. You can use this formula (with an Amulet) to create a +2 Skills Amulet. And you cannot Gamble one before Character Level 84. Be warned however, that the chances of getting that on an Amulet might be very low (considering everything is available) and it might take a lot of tries. Rare Items cannot be used with this formula to create new Rare Items.
Strangling Gas Potion + any type of Healing Potion = 1 Antidote Potion
6 Perfect Gems (1 of each type) + 1 Amulet (any quality) = Prismatic Amulet
Use this formula to create an Amulet with Resistance to all.
1 Ring + 1 Emerald + 1 Antidote Potion = 1 Viridian Ring
Use this formula to create a Poison Resistance Ring. Any grade of Emerald can be used. The Poison Ring has a random percentage of Poison Resistance
1 Ring + 1 Ruby + 1 Exploding Potion = 1 Garnet Ring
Use this formula to create a Fire Resistance Ring. Any grade of Ruby can be used. The Garnet Ring has a random percentage of Fire Resistance
1 Ring + 2 Topaz = 1 Coral Ring
Use this formula to create a Lightning Resistance Ring. Any grade of Topaz can be used. The Coral Ring has a random percentage of Lightning Resistance
1 Ring + 1 Sapphire + 1 Thawing Potion = 1 Cobalt Ring
Use this formula to create a Cold Resistance Ring. Any grade of Sapphire can be used. The Cobalt Ring has a random percentage of Cold Resistance
1 Small Shield (magical or better) + 1 Spiked Club (any quality) + 2 Skulls (any quality) = Small Shield of Spikes
Diamond (any quality) + 1 Staff (any type and quality) + 1 Kris (any type and quality) + 1 Belt (any type and quality) = Savage Bardiche
Wirt's Leg + A Tome of Town Portal = Secret Cow Level
You must Transmute in the Act I Rogue Encampment. You must have already killed Diablo in the same Difficulty Level. One time per Difficulty Level. Warning: if you lead the Cows around the Red Portal and die, you may not be able to fight your way back inside. Try to run in as far as you can and open up an escape Town Portal for backup. MooOOOOOOooooo
  • Jax
Jax
waar hebbie die eigenlijk vandaan als ik vragen mag :)
Program "Pro'gram" A magical spell cast over a computer allowing it to turn input into error messages.
  • Crysania
heeft ook iemand iets met Runes jewels en die zooi, want daar zit mijn stash al van vol met de hoop er iets goeds van te kunnen maken
  • Deleted user
Op zondag 08 juli 2001 18:53 schreef TOGrimReaper het volgende:
op http://www.battle.net/diablo2 kun je ergens bij items de cube combo's vinden en nog veel meer!
uhm alles is verplaatst naar: http://www.battle.net/diablo2exp/
en over de cubE:
http://www.battle.net/diablo2exp/items/cube.shtml
  • Dizzy
  • Laatst online: 19-08 20:17
Dizzy
Where am I?
Wat is een stone of jordan?????
Steam Profile I5 14600K / 64 GB DDR5 / RTX 4090 / Rift S / HP Omen / Odyssey Neo G9 / Steam Deck OLED / Switch
Op zondag 08 juli 2001 20:14 schreef Dizzle het volgende:
idd.. ben nu in act 5 maar zo'n ding ben ik ook nog nooit tegengekomen
  • Infinitive
  • Laatst online: 14-10 10:07
dat is een ring. Ik ben 'm in hell op skill hell een keer tegengekomen.
putStr $ map (x -> chr $ round $ 21/2 * x^3 - 92 * x^2 + 503/2 * x - 105) [1..4]
  • Flapmo
  • Laatst online: 22:12
Flapmo
and back is gigi!
Op zondag 08 juli 2001 21:49 schreef Infinitive het volgende:
Arg NewB's :). Stone of Jordan is meest zeldzame ring van DII en nu ook nog wel van DII exp. 1 to all skill lvls en to mana. Alleen de exp stones zijn lvl restricted en de oude niet. De oude zijn dan ook zo'n 40 PS (perfect Skulls) waard zeggen ze :). Errug leuk als je er nog 1 hebt van DII normal :P
Btw, DII ownes
Afbeeldingslocatie: http://home.worldonline.nl/~mvissers/diablosig.gif
P.s. -->Iemand een WoE (Wall of the Eyeless) voor me?? (traden of course)Realm=Europe
"The purpose of computing is insight, not numbers." -- Richard Hamming
  • Toewan
  • Laatst online: 22:54
Ik heb het spel vorige week ook gekocht, de gewone (niet de uitbreiding) en het is best wel verslavend kan ik je zeggen. Ik ben Paladin, inmiddels Level 33 (vakantie rules), en * Toewan is known as Sir Toewan. :)
Maar in Nightmare valt het toch wel tegen hoor, ik zit nu in de 2e act.
Om even niet offtopic te raken, ik heb een Wirt's Leg, en die schijn je met een Book of Town portals in je cube te moeten doen en dan kom je in een secret cow level :? (Vreemd ding, ik kon het niet verkopen dus ik vroeg een beetje rond wat het precies was en toen kwam iemand met dat verhaal.)
[edit]ow, het staat er al bij zie ik.. :) heb ik er overheen gelezen[edit]
Oh ja, nog even een vraagje, ik ben dus Paladin, maar welke skills kan ik het beste ontwikkelen eigenlijk ?? Ik heb een Amulet +1 Paladin Skills, maar ik heb nog een stuk of 11 skills te verdelen, maar ik weet niet precies wat handig is eigenlijk. Thorns is bij mij +6 en Might is +7. Kijk, ik kan wel veel op 1 ding gooien, maar met een internet character kan je het niet meer veranderen (zo heb ik ook al een imbue verneukt)
Oh ja, een ding wil ik wel even vermelden, ik speel het spel dus in 640 x 480, D3D op m'n AMD TBird 800, 256 Mb RAM en Asus GeForce V6600, maar soms dropt het aantal frames per seconde naar 15 of lager. Is dat normaal ?? En tsja, soms lagt ie ook wel een beetje veel, pings van 1600. Dat is ook wel misselijk, want wanneer ik nu in Nightmare dood ga, verlies ik experience (hoeveel dat ik dan verlies weet ik niet.)
  • HitmanWVU
Op maandag 09 juli 2001 00:31 schreef Toewan het volgende:
Geen Might meer doen over gaan op concentration
  • SimonBenson
  • Laatst online: 29-09 18:44
Kijk eens hiernaar voor Crafted Items en meer info.
http://www.planetdiablo.com/expansiond2/items/guide/crafted/table.shtml
Op zondag 08 juli 2001 21:54 schreef Flapmo het volgende:
ik heb er nog wel een for trade op realm europe, /w *[|CodeX|]
  • HitmanWVU
Hehe de meest bekende ring op heel fuckin LagAtBNet :)
BTW best wel een id voor een runeword :) => LagAtBNet
  • delorean7
  • Laatst online: 08-10 19:53
delorean7
Let's take the Aston toni
Ligt eraan of je ook nog aan de multiplayer gaat....Fanatacism roeleeert!! Mijn lvl 46 Paladin (binnen een week zo hoog gekomen zonder vakantie... party of five ;) ) Helpt iedereen door 250% xtra damage 100+% attack rating en nog boeiender +33% attack speed.
Might boeit dan echt niet meer, concentration heb ik geloof ik zelfs maar 1x boeit die dan?
Dan heb je ook nog die fist of heavens... nou lekker niet boeiend geval zeg (al wordt deze in 1.08 wel sterker dus moet ik nog even bekijken) maar met vengeance doe ik in 1 slag 2x zoveel damage als die hele level 3-4 fist of heavens!! Dat kan toch niet de bedoeling zijn?
Ik gebruik 2 combinaties die erg goed werken (paladin lvl51, act3 hell):
-Zeal met Concentration; waarbij je op moet letten dat je Zeal niet hoger maakt dan lvl 4, Concentration moet zo hoog mogelijk.
-Blessed Hammer met Redemption; Blessed Hammer zo hoog mogelijk, Redemption is lvl 5 meer dan genoeg.
Tegen een overdosis aan elemental attacks is Salvation erg handig, ook in combinatie met Zeal of Blessed hammer.
Met die 2 combinaties ros ik behoorlijk hard. Nog een groot voordeel: Redemption is de enige skill die je pas na lvl 30 kan upgraden, dus je hebt alle skills vrij snel omhoog.
Blessed Hammer/Redemption wordt overigens wel snel saai. Je rent een veld door, tot er genoeg vijanden om je heen zijn. Dan laat je Blessed Hammer 'ratelen'. Hiermee kan je eindeloos doorgaan omdat redemption zorgt dat je mana erg snel wordt bijgevuld.
Ik moet er wel bij zeggen dat ik niet heb gekeken of de laatste patch iets veranderd heeft aan die skills, want ik speel nu alleen nog maar met de Druid.
Weer ff ontopic --> [topic=165461]
Ummm, HOEZO, neemt ELKE paladin nou weer Concentration :? Je kunt beter Fanaticism nemen, doet meer damage, je hebt meer AR, en je slaat 35% sneller. Weet niemand watFana doet ofzo?? Over het hoofd gezien??
(BTW, ik heb een Level 66 Paladin, Lvl 20 Fanaticism, Holy Shield en Zeal)
  • delorean7
delorean7
Preachin' to tha choir brother, preachin' to tha choir!
  • delorean7
delorean7
ff OT als je toch een item gaat personalizen, neem dan een groen item ;)
Dayne's (me) Vidala's boots of (weet ik veel lang en hardst lopen)
humor.
  • Bokkie
Bokkie
What the hell are you?
Assasin is cool, def voor de traps en shadow tree
maar net als barb, voornamelijk melee en wat leuke helmpjes met modifers zoals kans op nova als je vastzit ofzo, die kloon van jezelf is erg nuttig
wapens moet je goede claws hebben
voor de druid weet ik niet wat voor wapens ik nodig hebt, maar ik denk dqat ik em opnieuw ga doen en dan focussen op summon spells en attack spells
shapeshiften alles 1 voor erbij, hij doet me een beetje aan als de necro
maar desondanks hou ik het nog steeds bij mijn allereerste sorc (offline) online ben ik opnieuw begonnen met sorc en assassin en druid :)
speel nog steeds meer offline dan bnet omdat het nog steeds erg laggy is bij, alleen dan kan ik niet de runewords gebruiken helaas
| Respect to the man in the icecream van! |
| i'm not completely useless, I can be used as a bad example! |
Op zondag 08 juli 2001 18:28 schreef THE_CR0SS het volgende:
voor al je vragen kan je naar site gaan.
  • Dizzy
Dizzy
Where am I?
Iemand nog een paar goede rune combo's voor de assassin?
Ja, waar kan ik rune combo's vandaan halen? ik heb er een stuk of 20 geloof ik lol. Ff wat plaats maken.
  • -=Indigo=-
  • Laatst online: 21:09
bij www.planetdiablo.com staan ook veel rune/crafted items combo's.
Moet je ff bij items kijken en dan bij runes/crafted items
  • Crysania
Op zaterdag 28 juli 2001 02:10 schreef Dizzle het volgende:
rune combo's zijn niet per character, maar gelden voor allemaal
  • Bokkie
Bokkie
Op zaterdag 28 juli 2001 12:48 schreef THE_CR0SS het volgende:
en ze werken (op dit moment) alleen op de realms, dus niet in single of open
  • Dizzy
Dizzy
Where am I?
aha, vandaar dat toen ik het met een cheat offline probeerde neit werkte..
ik speel ook onlimne..
lvl 54 assassin..
en wat die rune combo's betreft, er zijn dus bepaalde combo's die alleen op character-based weapons van toepassing zijn..
zo is er een combo die alleen op claws past, dan kan je wel zeggen dat er geen speciale character combo's bestaan, maar ik zie een barbarian nog geen claws dragen
