Computer crashed BSOD Windows 10 mogelijk cpu of mobo?
  • bluesbrother
  • Laatst online: 26-01-2025
bluesbrother
Blues Rocks!!!
Ik ben gisteren en vandaag bezig geweest om er achter te komen waar mijn BSOD vandaan komt.
Maar ik krijg maar geen duidelijkheid.
Ik heb het volgende systeem:
Model : GigaByte Z97X-UD3H
Mainboard : GigaByte Z97X-UD3H-CF
BIOS : AMI (OEM) F9 09/18/2015
Intel vPro : 9.01.25.1005
Total Memory : 31.88GB DIMM DDR3
Processors
Processor : Intel(R) Core(TM) i5-4440 CPU @ 3.10GHz (4C 3.3GHz, 3.3GHz IMC, 4x 256kB L2, 6MB L3)
Socket/Slot : FC LGA1150
Chipset
Memory Controller : Gigabyte Core (Haswell) DRAM Controller 100MHz, 2x 16GB DIMM DDR3 1.6GHz 128-bit, Integrated Graphics
Memory Module(s)
Memory Module : Crucial/Micron BLS8G3D1609DS1S00 8GB DIMM DDR3 PC3-12800U DDR3-1600 (9-9-9-24 4-39-12-6)
Video Adapter : Intel(R) HD Graphics 4600 (20CU 160SP 600MHz/1.1GHz, 512kB L2, 128MB DDR3 1.6GHz 128-bit, Integrated Graphics)
Graphics Processor
OpenCL GP Processor : Intel(R) HD Graphics 4600 (160SP 20C 600MHz/1.1GHz, 256kB L2, 1.6GB DDR3 1.6GHz 128-bit, Integrated Graphics)
Compute Shader Processor : Intel(R) HD Graphics 4600 (160SP 20C 600MHz/1.1GHz, 512kB L2, 128MB DDR3 1.6GHz 128-bit, Integrated Graphics)
OpenGL Processor : Intel(R) HD Graphics 4600 (160SP 20C 600MHz/1.1GHz, 512kB L2, 128MB DDR3 1.6GHz 128-bit, Integrated Graphics)
Storage Devices
INTEL SSDSC2BW240A4 (240GB, SATA600, 2.5", SSD) : 224GB (V:)
Crucial_CT480M500SSD1 (480.1GB, SATA600, 2.5", SSD, OPAL, SED) : 447GB (C:) (D:)
STORAGE DEVICE (USB2/NVMe) : N/A (E:)
Peripherals
LPC Hub Controller #1 : Gigabyte 9 Series Chipset Family Z97 LPC Controller
LPC Legacy Controller #1 : T2 86-20
Audio Device : Intel Core (Haswell) HD Audio Controller
Audio Codec : Intel 2807
Audio Device : Gigabyte 9 Series Chipset Family HD Audio Controller
Audio Codec : 32768 0000
Audio Codec : Realtek Semi 0900
Serial Port(s) : 1
Disk Controller : Gigabyte 9 Series Chipset Family SATA Controller [AHCI Mode]
USB Controller #1 : Gigabyte 9 Series Chipset Family USB xHCI Controller
USB Controller #2 : Gigabyte 9 Series Chipset Family USB EHCI Controller #2
USB Controller #3 : Gigabyte 9 Series Chipset Family USB EHCI Controller #1
SMBus/i2c Controller #1 : Intel ICH SMBus
Network Services
Network Adapter : Intel(R) Ethernet Connection I217-V (Ethernet, 1Gbps)
Operating System
Windows System : Microsoft Windows 10 Professional 10.00.10586
Platform Compliance : x64
Het BSOD gebeurt random lijkt het.
Ik kan het nu reproduceren doordat ik Sisoft Sandra heb geinstalleerd om een check en een stress test te doen.(ging prima) Maar als ik bij Sisoft sandra de specs wil weten onder Hardware >> Processors dan heb ik de BSOD. Ik heb het ook gehad als ik een exe bestand op wilde slaan. (maakt daarbij niet uit op welke schijf of op mijn NAS, allemaal BSOD, Anders had het nog aan een schijf kunnen liggen was mijn gedachte.
Afbeeldingslocatie: https://digiweten.nl/images/20170820_132627_small.jpg
In de windows logboeken staat niks dat duidelijk maakt wat er gebeurt.
Alleen dat de computer onverwacht afgesloten is. (JA hé hé)
Ik heb alle drivers en de bios naar de laatste versie gebracht. Geupdate dus.
Ik heb van Intel de Driver utility gebruikt.
Ik heb van Intel ook de Processor Diagnostic Tool gedraaid.
Deze kwam met een fail en error zoals hieronder.
Afbeeldingslocatie: https://digiweten.nl/images/cpu_test_small.jpg
De output van deze tool is als volgt
--- IPDT64 - Revision: 4.0.0.29
--- IPDT64 - Start Time: 20-8-2017 13:34:18
-- Testing
CPU 1 - SPBC - Pass.
CPU 1 - Genuine Intel - Pass.
CPU 1 - BrandString - Pass.
CPU 1 - Floating Point - Pass.
CPU 1 - Prime Number - Pass.
CPU 1 - Cache - Pass.
CPU 1 - MMXSSE - Pass.
CPU 1 - FMA - Pass.
CPU 1 - AVX - Pass.
CPU 1 - IMC - Pass.
CPU 1 - PCH - Fail.
CPU 1 - IGD - Pass.
CPU 1 - GFX - Pass.
CPU 1 - CPULoad - Pass.
CPU 1 - CPU Frequency - Pass.
IPDT64 Failed
--- IPDT64 - End Time: 20-8-2017 13:39:07
FAIL
Hij failed op alleen PCH, de rest gaat goed.
Als ik daar op zoek dan vind ik het volgende:
https://communities.intel.com/thread/60375
Die verteld me (en andere draadjes die ik vond) dat ik intel rapid storage moet installeren.
Alleen als ik dat wil doen verteld deze software mij dat ik dat niet heb op mijn Gigabyte Mobo.
En dat klopt ook wel. Dus een doodlopend spoor.
Ook wordt er wel gesproken van het up to date brengen van de video driver. Dat heb ik al gedaan en lijkt mij ook niet de oorzaak te kunnen zijn. BSOD blijven.
Ik heb ook de Windows Geheugen controle app gebruikt van Windows 10 .
Die gaf niks aan verder. Alles was goed.
Ik heb de computer losgekoppeld van alle randapparatuur die ik niet nodig heb.
Hebben jullie nog tools, ideeën hoe ik verder kan achterhalen waar het aan ligt.
Als ik Intel of Gigabyte ga bellen dan zullen ze elkaar de schuld gaan geven.
Ik zou liever duidelijker willen hebben waar het zit voor ik verdere stappen ga ondernemen.
Kunnen jullie daarbij adviseren?
[Edit: plaatjes even aangepast]
Wil je je pizza in 4 of 8 stukken? .......Doe maar in 4, 8 krijg ik niet op.
  • McFastFood
Welke BSOD's codes krijg je? Dit kun je uitlezen met het programma bleuscreenview.
Daarnaast heb je al een rondje Memtest 86 + gedraaid?
Zou je ook even een stresstest willen uitvoeren met Prime95?
  • bluesbrother
bluesbrother
Blues Rocks!!!
Update: Ik kreeg net een nieuwe BSOD die ik nog niet eerde gezien heb.
PFN_LIST_CORRUPT
Door dit draadje ga ik nu meer richting RAM denken.
Verwijderd in "BSOD - PFN_LIST_CORRUPT"
Inmiddels loopt ook memtest86 en zit ik al vrij snel op de 1300 errors. ;(
@McFastFood
Ik zal even wat verder testen. Het lijkt er toch op dat het RAM is.
  • bluesbrother
bluesbrother
Blues Rocks!!!
Ik heb nu alle reepjes afzonderlijk getest met memtest en elk reepje geeft fouten. Ik ga er maar van uit dat mijn RAM een optater heeft gekregen en ik dus nieuwe moet gaan kopen. Is dat een juiste conclusie?
  • ToFast
  • Laatst online: 22-02 15:08
bluesbrother schreef op zondag 20 augustus 2017 @ 15:07:
Lopen ze op het juiste aantal MHz en de juiste timing (cas latencies etc). Wat vaak kan helpen is het voltage 0.1-0.2v omhoog te gooien (kan geen kwaad) voor het dram!
  • bluesbrother
bluesbrother
Blues Rocks!!!
Ik heb tijdens het troubleshooten de bios op de defauls gezet. Ik ben niet zon overclocker. Denk je dat het toch zin heeft dit te proberen. As we speak draait memtest nog en zit op 2918 errors.
En hij is al een paar keer opnieuw opgestart uitzichzelf. Ik denk omdat hij dan het memory address bereikt waar het fout gaat ofzo.(die conclusie is logisch nadenken, heeft niks te maken met hardware kennis)
  • McFastFood
bluesbrother schreef op zondag 20 augustus 2017 @ 15:26:
Ik zou een RMA indienen bij de leverancier waar je het gekocht hebt of bij de fabrikant. Op RAM zit vaak lang garantie. Meestal standaard 10 jaar
  • bluesbrother
bluesbrother
Blues Rocks!!!
Ga ik doen. Dank voor de hulp.
  • bluesbrother
bluesbrother
Blues Rocks!!!
Ik heb inmiddels de geheugen modules opgestuurd en heb heel snel weer gloednieuwe teruggekregen.
Wel eerst een RMA moeten aanmaken op de website. Maar goede service.
  • McFastFood
bluesbrother schreef op dinsdag 3 oktober 2017 @ 20:19:
Fijn om te horen dat je weer een nieuw setje hebt gekregen. :)
Puur uit nieuwsgierigheid. Kun je de Intel diagnostic test nu wel zonder problemen draaien? Ervaar je nog BSOD'S?
  • bluesbrother
bluesbrother
Blues Rocks!!!
McFastFood schreef op dinsdag 3 oktober 2017 @ 20:35:
Ik heb nu andere problemen en misschien zijn ze gerelateerd. :'(
Daar ben ik op dit moment naar op zoek. Zie een ander draadje hierover.
bluesbrother in "Beeld valt uit, pc crashed niet RAM maar wat dan wel?"
