  • Operations
  • Laatst online: 30-10 17:29
Ik heb onze Exchange 2016 willen updaten naar CU6.
De update opzich is goed verlopen.
Na het installeren kan ik niet meer inloggen via OWA, ik krijg dan error 500. De ECP doet het wel.
Nu ben ik de eventvwr in gedoken, en zag ik dat de thumbprint niet meer correct was. Dat heb ik opgelost via:
https://social.technet.mi...te?forum=exchangesvradmin
Die error is nu ook verdwenen, ik blijf nu zitten met error 1309:
Event code: 3005
Event message: An unhandled exception has occurred.
Event time: 12-8-2017 16:50:56
Event time (UTC): 12-8-2017 14:50:56
Event ID: 3dc8e0e44f3747189ffb333c84974788
Event sequence: 2
Event occurrence: 1
Event detail code: 0
Application information:
Application domain: /LM/W3SVC/2/ROOT/owa-4-131470230420883879
Trust level: Full
Application Virtual Path: /owa
Application Path: C:\Program Files\Microsoft\Exchange Server\V15\ClientAccess\owa\
Machine name: SERVERNAAM
Process information:
Process ID: 4884
Process name: w3wp.exe
Account name: NT AUTHORITY\SYSTEM
Exception information:
Exception type: TargetInvocationException
Exception message: Exception has been thrown by the target of an invocation.
at System.RuntimeMethodHandle.InvokeMethod(Object target, Object[] arguments, Signature sig, Boolean constructor)
at System.Reflection.RuntimeMethodInfo.UnsafeInvokeInternal(Object obj, Object[] parameters, Object[] arguments)
at System.Reflection.RuntimeMethodInfo.Invoke(Object obj, BindingFlags invokeAttr, Binder binder, Object[] parameters, CultureInfo culture)
at Owin.Loader.DefaultLoader.<>c__DisplayClass12.<MakeDelegate>b__b(IAppBuilder builder)
at Owin.Loader.DefaultLoader.<>c__DisplayClass1.<LoadImplementation>b__0(IAppBuilder builder)
at Microsoft.Owin.Host.SystemWeb.OwinAppContext.Initialize(Action`1 startup)
at Microsoft.Owin.Host.SystemWeb.OwinBuilder.Build(Action`1 startup)
at Microsoft.Owin.Host.SystemWeb.OwinHttpModule.InitializeBlueprint()
at System.Threading.LazyInitializer.EnsureInitializedCore[T](T& target, Boolean& initialized, Object& syncLock, Func`1 valueFactory)
at Microsoft.Owin.Host.SystemWeb.OwinHttpModule.Init(HttpApplication context)
at System.Web.HttpApplication.RegisterEventSubscriptionsWithIIS(IntPtr appContext, HttpContext context, MethodInfo[] handlers)
at System.Web.HttpApplication.InitSpecial(HttpApplicationState state, MethodInfo[] handlers, IntPtr appContext, HttpContext context)
at System.Web.HttpApplicationFactory.GetSpecialApplicationInstance(IntPtr appContext, HttpContext context)
at System.Web.Hosting.PipelineRuntime.InitializeApplication(IntPtr appContext)
Encryption certificate is absent
at Microsoft.Exchange.Security.Authentication.Utility.GetCertificates()
at Microsoft.Exchange.Clients.Owa2.Server.Core.notifications.SignalR.SignalRStartup.Configuration(IAppBuilder app)
Request information:
Request URL: https://localhost:444/owa/proxylogon.owa
Request path: /owa/proxylogon.owa
User host address: 127.0.0.1
User:
Is authenticated: False
Authentication Type:
Thread account name: NT AUTHORITY\SYSTEM
Thread information:
Thread ID: 136
Is impersonating: False
Stack trace: at System.RuntimeMethodHandle.InvokeMethod(Object target, Object[] arguments, Signature sig, Boolean constructor)
Dit zou dan komen omdat SharedWebConfig.config in de C:\Program Files\Microsoft\Exchange Server\V15\ClientAccess niet bestaat.
Die heb ik aangemaakt via:
https://support.microsoft...p-after-you-install-excha
Alleen nu blijft die error terugkomen, terwijl ik ook fysiek het bestand zie staan.
Toen kwam ik nog een website tegen die aangaf deze map C:\Windows\Microsoft.NET\Framework64\v4.0.30319\Temporary ASP.NET Files\owa leeg te gooien, en de mappen opnieuw zelf te laten genereren door opnieuw in te loggen op de OWA. Heeft helaas ook niet geholpen.
Iemand enig idee? Beetje overbodig misschien maar voor de CU6 update werkte OWA uiteraard wel.
PC1: ASUS B850-Plus WiFi -- 9900X incl. X72 -- 64GB DDR5-6000Mhz -- Kingston Fury Renegade G5 2TB -- DELL 4025QW | Servers: 2x DELL R730 -- E5-2660 v4 -- 256GB -- Synology DS3617xs: 4x1,92TB SSD RAID F1 -- 6x8TB WD Purple RAID5
  • Operations
Deze mag dicht, als je eerst met een half oog naar engels voetbal kijkend .NET framework 4.7 installeert op de Exchange server dan gaat dit uiteraard problemen geven. Iets met wijze les en 1 ding tegelijk doen :)
  • Vorkie
@Operations Mooi zo :)
