Khronos Brengt OpenGL 4.6 uit met SPIR-V Ondersteuning
  • 567 views
  • twoker
  • Laatst online: 07-08-2017
The Khronos Group heeft OpenGL 4.6 uitgebracht.
(OpenGL is een API voor grafische hardware te gebruiken, Direct3D tegenhanger en voorganger van Vulkan.)
Lijkt mij toch iets dat tweakers en vooral de programmeurs zou interesseren?
Waarom heeft tweakers hier geen bericht over? (Of heb ik iets in het nieuws over het hoofd gezien?)
Khronos Releases OpenGL 4.6 with SPIR-V Support
OpenGL celebrates 25th anniversary with 4.6 release adding 11 ARB and EXT extensions into the core specification
https://www.khronos.org/news/press/khronos-releases-opengl-4.6-with-spir-v-support
July 31, 2017 – SIGGRAPH 2017, Los Angeles, CA – The Khronos™ Group, an open consortium of leading hardware and software companies, announces from the SIGGRAPH 2017 Conference the immediate public availability of the OpenGL® 4.6 specification. OpenGL 4.6 integrates the functionality of numerous ARB and EXT extensions created by Khronos members AMD, Intel, and NVIDIA into core, including the capability to ingest SPIR-V™ shaders.
SPIR-V is a Khronos-defined standard intermediate language for parallel compute and graphics, which enables content creators to simplify their shader authoring and management pipelines while providing significant source shading language flexibility. OpenGL 4.6 adds support for ingesting SPIR-V shaders to the core specification, guaranteeing that SPIR-V shaders will be widely supported by OpenGL implementations.
OpenGL 4.6 adds the functionality of these ARB extensions to OpenGL’s core specification:
  • GL_ARB_gl_spirv and GL_ARB_spirv_extensions to standardize SPIR-V support for OpenGL
  • GL_ARB_indirect_parameters and GL_ARB_shader_draw_parameters for reducing the CPU overhead associated with rendering batches of geometry
  • GL_ARB_pipeline_statistics_query and GL_ARB_transform_feedback_overflow_query standardize OpenGL support for features available in Direct3D
  • GL_ARB_texture_filter_anisotropic (based on GL_EXT_texture_filter_anisotropic) brings previously IP encumbered functionality into OpenGL to improve the visual quality of textured scenes
  • GL_ARB_polygon_offset_clamp (based on GL_EXT_polygon_offset_clamp) suppresses a common visual artifact known as a “light leak” associated with rendering shadows
  • GL_ARB_shader_atomic_counter_ops and GL_ARB_shader_group_vote add shader intrinsics supported by all desktop vendors to improve functionality and performance
  • GL_KHR_no_error reduces driver overhead by allowing the application to indicate that it expects error-free operation so errors need not be generated
In addition to the above features being added to OpenGL 4.6, the following are being released as extensions:
  • GL_KHR_parallel_shader_compile allows applications to launch multiple shader compile threads to improve shader compile throughput
  • WGL_ARB_create_context_no_error and GXL_ARB_create_context_no_error allow no error contexts to be created with WGL or GLX that support the GL_KHR_no_error extension
“I’m proud to announce OpenGL 4.6 as the most feature-rich version of OpenGL yet. We've brought together the most popular, widely-supported extensions into a new core specification to give OpenGL developers and end users an improved baseline feature set. This includes resolving previous intellectual property roadblocks to bringing anisotropic texture filtering and polygon offset clamping into the core specification to enable widespread implementation and usage,” said Piers Daniell, chair of the OpenGL Working Group at Khronos. “The OpenGL working group will continue to respond to market needs and work with GPU vendors to ensure OpenGL remains a viable and evolving graphics API for all its customers and users across many vital industries.“
The OpenGL 4.6 specification can be found at https://khronos.org/registry/OpenGL/index_gl.php. The GLSL to SPIR-V compiler glslang has been updated with GLSL 4.60 support, and can be found at https://github.com/KhronosGroup/glslang.
Sophisticated graphics applications will also benefit from a set of newly released extensions for both OpenGL and OpenGL ES to enable interoperability with Vulkan and Direct3D. These extensions are named:
  • GL_EXT_memory_object
  • GL_EXT_memory_object_fd
  • GL_EXT_memory_object_win32
  • GL_EXT_semaphore
  • GL_EXT_semaphore_fd
  • GL_EXT_semaphore_win32
  • GL_EXT_win32_keyed_mutex
They can be found at: https://khronos.org/registry/OpenGL/index_gl.php
Industry Support for OpenGL 4.6
“With OpenGL 4.6 our customers have an improved set of core features available on our full range of OpenGL 4.x capable GPUs. These features provide improved rendering quality, performance and functionality. As the graphics industry’s most popular API, we fully support OpenGL and will continue to work closely with the Khronos Group on the development of new OpenGL specifications and extensions for our customers. NVIDIA has released beta OpenGL 4.6 drivers today at https://developer.nvidia.com/opengl-driver so developers can use these new features right away,” said Bob Pette, vice president, Professional Graphics at NVIDIA.
"OpenGL 4.6 will be the first OpenGL release where conformant open source implementations based on the Mesa project will be deliverable in a reasonable timeframe after release. The open sourcing of the OpenGL conformance test suite and ongoing work between Khronos and X.org will also allow for non-vendor led open source implementations to achieve conformance in the near future," said David Airlie, senior principal engineer at Red Hat, and developer on Mesa/X.org projects.
About OpenGL
OpenGL® is the most widely adopted 2D and 3D graphics API in the industry, bringing thousands of applications to a wide variety of computer platforms. It is window-system and operating-system independent as well as network-transparent. OpenGL enables developers of software for PC, workstation, and supercomputing hardware to create high-performance, visually compelling graphics software applications, in markets such as CAD, content creation, energy, entertainment, game development, manufacturing, medical, and virtual reality. OpenGL comprehensively exposes the features of the latest graphics hardware.
About The Khronos Group
The Khronos Group is an industry consortium creating open standards to enable the authoring and acceleration of parallel computing, graphics, vision and neural nets on a wide variety of platforms and devices. Khronos standards include Vulkan®, OpenGL®, OpenGL® ES, OpenGL® SC, WebGL™, SPIR-V™, OpenCL™, SYCL™, OpenVX™, NNEF™, COLLADA™, OpenXR™ and glTF™. Khronos members are enabled to contribute to the development of Khronos specifications, are empowered to vote at various stages before public deployment, and are able to accelerate the delivery of their cutting-edge accelerated platforms and applications through early access to specification drafts and conformance tests.
For more information about The Khronos Group visit Khronos.org.
Vulkan is a registered trademark of The Khronos Group. Khronos, OpenXR, DevU, SPIR, SPIR-V, SYCL, WebGL, WebCL, COLLADA, OpenKODE, OpenVG, OpenVX, EGL, glTF, OpenKCAM, StreamInput, OpenWF, OpenSL ES, NNEF and OpenMAX are trademarks of the Khronos Group Inc. OpenCL is a trademark of Apple Inc. and OpenGL is a registered trademark and the OpenGL ES and OpenGL SC logos are trademarks of Silicon Graphics International used under license by Khronos. All other product names, trademarks, and/or company names are used solely for identification and belong to their respective owners.
  • Barryvdh
  • Laatst online: 14:55
Heb je de redactie getipt? https://tweakers.net/submit/
  • MAX3400
  • Laatst online: 14:54
MAX3400
XBL: OctagonQontrol
  • Creepy
  • Laatst online: 11:13
Creepy
Tactical Espionage Splatterer
Gevalletje eerst de redactie tippen inderdaad :)
"I had a problem, I solved it with regular expressions. Now I have two problems". That's shows a lack of appreciation for regular expressions: "I know have _star_ problems" --Kevlin Henney
