hoi! ik heb een vraagje denken jullie dat mijn mobo 384 sdram aankan
hier wat info:
hier wat info:
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
| <<< Mainboard Information >>>
< Entire System >
Manufacturer: Gateway
Serial Number: 0001306768
Unique ID: D36AE280-11B21DDD-E9D90080-10A7C58B
< System Chassis >
Can be locked: No
< System Mainboard >
Manufacturer: Intel Corporation
MP Support: No
Model: WS440BX
Version: AA744110-203
Serial Number: IMWS94018825
< On-board Devices >
ENSONIQ: Sound Device
< System Memory Controller >
Error Correction Capability: ECC
Number of Memory Slots: 3
Maximum Installable Memory: 768MB
BANK 0 - J6J1: DIMM Synchronous DRAM 64MB/32
BANK 1 - J6J2: DIMM Synchronous DRAM 64MB/32
BANK 2 - J7J1: Empty
< System Chipset >
Model: Intel Corporation 82443BX/ZX 440BX/ZX CPU to PCI
Bridge (AGP Implemented)
Bus(es): ISA X-Bus AGP PCI USB SMBus/i2c
Front Side Bus Speed: 100MHz
ACPI PM Support: Yes
< Logical/Chipset Memory Banks >
Bank 0 Setting: 64MB SDRAM 8-1-1-1R 6-1-1-1W 3-2-2CL
Bank 2 Setting: 64MB SDRAM 8-1-1-1R 6-1-1-1W 3-2-2CL
Memory Bus Speed: 100MHz
< Memory Modules >
Memory Module 1: BPB6781A 128MB 8x(16Mx8) SDRAM PC100-322-622 (CL3 upto
100MHz) (CL2 upto 83MHz)
Memory Module 2: Samsung KMM3 66S 823CTS-GL 39E01E07 64MB 8x(8Mx8)
SDRAM PC100-322-622 (CL3 upto 100MHz) (CL2 upto 83MHz)
< System Clock Generator >
Model: Generic PLL-IC-WO
Software Programmable: Yes
Read-Back Support: No
< AGP Bus >
Version: 1.00
Bus Speed: 67MHz
Current Data Transfer Rate: 2x (134MHz)
Side Band Enabled: Yes
Fast-Writes Enabled: No
Aperture Size: 64MB
< PCI Bus(es) >
Version: 2.10
No Buses: 1
Bus Speed: 33MHz
Speed Multiplier: 1/3x
< LPC/ISA Bus(es) >
Model: Intel Corporation 82371AB/EB/MB PIIX4 ISA Bridge
Speed Multiplier: 1/4x
Bus Speed: 8MHz
DMA Multiplier: 1/2x
DMA Speed: 4MHz
< LPC/X-Bus(es) >
Type: SMSC LPC v1
Version: 42.00
No Enabled Devices: 3
< USB Bus(es) >
Model: Intel Corporation 82371AB/EB/MB PIIX4 USB Controller
Version: 1.10
UHCI Interface: Yes
Channels: 2
Bus Speed: 48MHz
Legacy Emulation Enabled: No
< i2c/SMBus/BMB Bus(es) >
Total/MB Channels: 1 / 1
< Expansion Slot(s) >
ISA-1, J4A2: ISA 16-bit 5V FullLength
PCI-1, J4D2 (1h): PCI 32-bit 3.3V FullLength InUse (Intel Corporation
82443BX/ZX 440BX/ZX PCI to AGP Bridge)
PCI-2, J4D1 (2h): PCI 32-bit 3.3V FullLength InUse
PCI-3, J4C1 (3h): PCI 32-bit 3.3V FullLength InUse
PCI-4, J4B1 (4h): PCI 32-bit 3.3V FullLength InUse
PCI-5, J4A1 (5h): PCI 32-bit 3.3V FullLength Available
AGP, J4E1: AGP-2x 32-bit 3.3V FullLength
< Port Connector(s) >
J1K1 - COM A: Serial Port 16550A Compatible - None / DB-9 pin male
J1J1 - COM B: Serial Port 16550A Compatible - None / DB-9 pin male
J1J2 - LPT1: Parallel Port ECP/EPP - None / DB25 pin female
J1M1 - Keyboard: Keyboard Port - None / PS/2
J1M1 - MOUSE: Mouse Port - None / PS/2
J1L1 - USB0: USB - None / USB
J1L1 - USB1: USB - None / USB
J8K2, FLOPPY: None - Floppy / None
J8G1, PRI IDE: None - ATA / None
J7G1, SEC IDE: None - ATA / None
J1G1 - GAME: MIDI Port - None / DB-15 pin female
J1G1 - MIC: Audio Port - None / Mini-jack
J1G1 - LINE IN: Audio Port - None / Mini-jack
J1G1 - LINE OUT: Audio Port - None / Mini-jack
J1F1 CD: Audio Port - CD-ROM Sound Input / None
J1F2 Telephony, 4 pin: Audio Port - None / None
J2D1 AUX IN: Audio Port - None / None
J2C1 WOL, Wake on LAN: None - None / None
J5B1 WOR, Wake on Ring: None - None / None
J2B1, AC97 Header: None - None / None
J7C1, Front Panel USB: None - None / None
< Performance Tips >
Notice N224: SMBIOS/DMI information may be inaccurate.
Tip T2: For more information about tips, press F1 and scroll
to the Tips section. |
