Vraagje IVM CPU cooling
hey, misschien een "stomme" vraag maar een CPU dat draaid op 16 graden. kan dit kwaad? is dit te laag?
als ik iets open "jumpt" die wel naar 25-35 graden.
heb AMD FX-8150 proccessor met watercooling
gewoon
AMD FX-8150
Cores 8
Threads 8
Name AMD FX-8150
Code Name Zambezi
Package Socket AM3+ (942)
Technology 32nm
Specification AMD FX-8150 Eight-Core Processor
Family F
Extended Family 15
Model 1
Extended Model 1
Stepping 2
Revision OR-B2
Instructions MMX (+), SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, SSE4A, AMD 64, NX, VMX, AES, AVX, FMA4
Virtualization Supported, Disabled
Hyperthreading Not supported
Fan Speed 2014 RPM
Bus Speed 200.6 MHz
Rated Bus Speed 2207.0 MHz
Stock Core Speed 3600 MHz
Stock Bus Speed 200 MHz
Average Temperature 16 °C
Caches
L1 Data Cache Size 8 x 16 KBytes
L1 Instructions Cache Size 4 x 64 KBytes
L2 Unified Cache Size 4 x 2048 KBytes
L3 Unified Cache Size 8192 KBytes
Cores
Core Speed Multiplier Bus Speed Rated Bus Speed Temperature Threads
Core 0 1404.4 MHz x 7.0 200.6 MHz 2207.0 MHz 16 °C APIC ID: 0
Core 1 1404.4 MHz x 7.0 200.6 MHz 2207.0 MHz 16 °C APIC ID: 1
Core 2 1404.4 MHz x 7.0 200.6 MHz 2207.0 MHz 16 °C APIC ID: 2
Core 3 1404.4 MHz x 7.0 200.6 MHz 2207.0 MHz 16 °C APIC ID: 3
Core 4 1404.4 MHz x 7.0 200.6 MHz 2207.0 MHz 16 °C APIC ID: 4
Core 5 1404.4 MHz x 7.0 200.6 MHz 2207.0 MHz 16 °C APIC ID: 5
Core 6 1404.4 MHz x 7.0 200.6 MHz 2207.0 MHz 16 °C APIC ID: 6
Core 7 1404.4 MHz x 7.0 200.6 MHz 2207.0 MHz 16 °C APIC ID: 7]
bij opening/beweging
CPU
AMD FX-8150
Cores 8
Threads 8
Name AMD FX-8150
Code Name Zambezi
Technology 32nm
Family F
Extended Family 15
Model 1
Extended Model 1
Stepping 2
Revision OR-B2
Fan Speed 1950 RPM
Bus Speed 200.6 MHz
Average Temperature 33 °C
Caches
Cores
Core 0 3912.4 MHz x 19.5 200.6 MHz 2207.0 MHz 33 °C APIC ID: 0
Core 1 3912.4 MHz x 19.5 200.6 MHz 2207.0 MHz 33 °C APIC ID: 1
Core 2 4213.3 MHz x 21.0 200.6 MHz 2207.0 MHz 33 °C APIC ID: 2
Core 3 4213.3 MHz x 21.0 200.6 MHz 2207.0 MHz 33 °C APIC ID: 3
Core 4 3912.4 MHz x 19.5 200.6 MHz 2207.0 MHz 33 °C APIC ID: 4
Core 5 3912.4 MHz x 19.5 200.6 MHz 2207.0 MHz 33 °C APIC ID: 5
Core 6 3912.4 MHz x 19.5 200.6 MHz 2207.0 MHz 33 °C APIC ID: 6
Core 7 3912.4 MHz x 19.5 200.6 MHz 2207.0 MHz 33 °C APIC ID: 7
  • .Maarten
Een CPU kan niet onder de omgevingstemperatuur komen tenzij je extra koeling gebruikt zoals bijvoorbeeld stikstof / dry ice / warmtewisselaar.
Ik verwacht dat het gewoon een meetfoutje is.
  • friggler
  • Laatst online: 06:40
De AMD FX series staan erom bekend dat de aangegeven temperatuur in diverse programma's niet klopt. Kijk eens in je BIOS naar de temperatuur.
