Scherm werkt niet meer!
Ik heb een probleem met mijn scherm en weet niet hoe ik dit oplos. Hieronder de tekst die ik ook op een engelstalig forum heb gepost, vandaar het engels!
So this is whap happened:
My computer worked all great, I could game rainbow six siege on almost the higest quality with the ultra hd texturepack. But then thr steam summersale came and I bought GTA V, and installed it overnight. The next day (today) when I started up GTA V it worked and I was really happy. Then all of a sudden in storymode (gta V) my screens turned off and said no connection (like it does when nothing is turned on, like a pc or playstation) so I did not really think anything off it and restarted my system. Then when I started GTA V back on it worked again, so I gamed for like 15 minutes and it happened again, my screens turned off. I restarted my system, and thought maybe it is my drivers. And it had to do a upgrade so i did that and thought ohh its just the drivers. Turned on GTA V again and it worked for like 10 minutes. It turned off again, so I thought maybe somthing is getting to hot, so i started up a monitoring process for that and it was 31 °C whitout doing anithing, then when i started up GTA V and played for like 5 minutes it was 49°C, my screens turned off again. Then when I started up my windows again the screens when turning on were white stripes where you normaly see the logo of the screens, then it turned off again, restarted again and this time it just turned off almost emediately after seeing the windows screen.
Can anyone please help me with this.
I already tried: Putting my graphicscard, inbuilt batery, and RAM in and out. But it still does not work.
I have an
BenQ GW2270 (screen)
Asus H97M-E (Motherboard)
Intel Core i5-4460 (I maybe want to upgrade it to an i7)
Nvidia GTX 960 (Prossesor)
Goodram GR1600D364L11S (2x4GB) (and want to upgrade it to 2x8GB)
Seagate ST1000DM003-1ER162 (HDD)
TS128GSSD370S (SSD)
MS Tech 750 Watt ATX PSU ms-n750-val-cm rev.b (Powersupply)
  • roches
  • Laatst online: 30-10 22:23
Het kan het moederbord zijn.
Het kan de voeding zijn.
Het kan de videokaart zijn.
En misschien kan het ook de koelpasta tussen koeler en processor zijn, deze al gecheckt?
Ik denk niet dat het aan je scherm ligt...
Begin met het checken van de voeding....
@.Maarten hieronder: Dat laatste was ook mijn eerste gedachte, maar gezien de naam van TS zal het daar wel mee te maken hebben.. >:)
[ Voor 40% gewijzigd door roches op 23-06-2017 21:25 ]
  • .Maarten
  • Laatst online: 28-10 23:17
Probeer eens een andere voeding. Mstech is niet echt kwaliteit.
En vertaal je post eens. dit is een Nederlands forum. Waarom zouden wij moeite moeten doen als jij nog niet eens moeite wil doen om je post te vertalen?
Ongeacht of het de oorzaak is kan je de voeding maar beter vervangen. Slechtere kwaliteit dan MS-Tech is er niet. Deze voeding sloopt langzaam je systeem. En koop dan niet een andere goedkope slechte zogenaamde 750w voeding maar een goede 400w. Daar heb je met een systeemverbruik van net 200w namelijk zat aan.
Stap één is dus een nieuwe voeding halen. Als je dat gedaan hebt ga je troubleshooten. Zie het betreffende topic op Tweakers.net.
