Cheats Operation Flashpiont
  • Guider
  • Laatst online: 08:56
ik kan ze echt nergens vinden
zit nu in een level waar ik dus totaal niet door heen kom. :'(
...hier veel cheats te krijgen....
**************** S I M - P E L ****************
  • Skywalker
  • Laatst online: 11-05 09:30
Skywalker
Use the force Luke!!
Ik weet niet of deze werken, maar ik kwam ze net tegen:
God Mode
Start the game and start playing any level then type 'iwillbetheone' and You will Become God.
Infinite Save Games
If you need to save more than once in a mission, then you need to delete the old save game file. It can be found in the directory Users\\Saved\Campaigns\1985. ALT-TAB out of the game, make a backup copy (trust me!) and then delete the save file. ALT-TAB back and press ESC to pause the game. You should now be able to save the game again. You can do this as many times as you like.
Full Ammo
On the second level on campaign mode when your officer shouts go go go! Immediately type in moreammo and u will get full ammo.
Unlimited Ammo (Hex Method)
BACKUP FILES BEFORE PROCEEDING
To alter the amount of ammo available to each weapon or magazine simply edit the weapons.cfg file found in the 'saved' folder contained within your user folder.
...\Users\NAME\Saved\Campaigns\1985\
or
...\Users\NAME\Saved\Missions\01TakeTheCar\
* Save a back-up copy prior to changing !!!
The weapons.cfg file defines weapon classes
where u can change the ammo amounts.
class Magazine3
type="M16";
ammo=30.000000;
reload=0.133733;
id=352.000000;
class Magazine4
type="HandGrenade";
ammo=1.000000;
reload=1.215374;
id=353.000000;
Once changed you will need to re-start your mission or continue your campaign for the changes to take effect. These changes are often reset at the beginning of new missions/campaings requiring you to alter the new cfg file for that particular mission.
En dan nog een paar trainers:
http://www.actiontrip.com/cheats/operationflashpoint.phtml
Greetz,
Skywalker
May the force be with you!!
  • Guider
ja bedankt voor alles
  • Skywalker
Skywalker
Daar staan geen OFP cheats!
Greetz,
Skywalker
By the way: cheating is for losers!!
  • Gallus
  • Laatst online: 12:28
Gallus
Cheesy
Als je in een singleplayer spel met geen mogelijkheid verder komt, kan dat heel frustrerend zijn. Dan mag je best een keertje cheaten...
All I want is a warm bed, a kind word and unlimited power.
  • steveman
  • Registratie: Mei 2001
  • Laatst online: 17:55
steveman
Comfortabel ten onder
Je kunt niet echt zeggen dat OP echt lekker loopt, soms blijft er nogal iets steken in het spel, bijvoorbeeld: een kapotte tank staat een truck in de weg die moet draaien op dat punt, leuk joh :(
nu kun je bijvoorbeeld de banden kapot schieten en te voet verder gaan. Maarja, BMP's are lurking... Godmode is dan wel handig lijkt me...
Op vrijdag 06 juli 2001 12:58 schreef Gallus het volgende:
Dan vind ik het zelf ook wel gerechtvaardigd eigenlijk, als je ECHT niet meer verder kunt.
  • Guider
hoe moet ik die codes dan invoeren het lukt me niet.
en ik kom echt niet verder en dat is echt heel frustrerend. ik moet een openveld over waar helikopters en kei veel man lopen lukt me echt niet. Kan niet eens in dat level sniperen :'(
Op vrijdag 06 juli 2001 21:35 schreef DMaarten het volgende:
Ach als je maar een dag later niet een topic hier opend van ik heb Operation flashpoint uitgespeeld en dan beweren op Hard en zonder cheats |:(
[edit]
En dat doen er nog al wat heb ik het idee.
maar dat geld voor meerdere games natuurlijk
[edit]
CHEATS helpen je GAME naar de KLOTEN!!!
weet er jammer genoeg alles van :(
