DICE zet wijzigingen voor volgende grote Battlefield 1 updat
  • dusty-2011
  • Laatst online: 07-08 09:35
nieuws: DICE zet wijzigingen voor volgende grote Battlefield 1 update uiteen
Om de Operations-spelmodus meer onder de aandacht te brengen, wordt het lobbysysteem daarvan aangepakt. Spelers die Operations doen, zullen na de update niet alleen van zijde wisselen, maar de teams zullen ook door alle Operations-levels heengaan in plaats van constant op dezelfde blijven.
Volgens PC-gamer komt dit pas later en zeker weten niet in de aankomende mei update:
http://www.pcgamer.com/ba...ylists-and-bayonet-nerfs/
Operation playlists are exactly what they sound like: They keep you playing Operations, instead of throwing you back to the main menu at the end of a match. However, it will be quite limited at first—when the feature is introduced, the playlists will only play the same Operation over and over again, with the teams simply switching sides. DICE calls this a "first step" and plans to have players going through different Operations eventually.
Gamespot:
https://www.gamespot.com/...s-tweaks-aa/1100-6450376/
One such improvement is called Operation playlists. Rather than playing through an Operation and then having to return to the main menu to find a new game, these servers will keep you playing. This is described as a "first step," and it shows--for the time being, the same Operation will loop over and over, with players simply swapping sides at the end of each game. In the future, DICE intends for this to cycle through different Operations. In the meantime, this should allow you to keep playing on a full server without having to deal with matchmaking.
Tweakers zit er duidelijk naast.
