"nieuwe" voodoo banshee problemen....
  • Electrowolf
  • Laatst online: 21-08 21:03
Electrowolf
Mod met Liefde!
ok, ik heb nu dus een banshee in deze pc (dual p2 233, 128mb ram, win 2k) en wil de q3 dual cpu sopport testen. maar dat mislukt jammerlijk: openGL sub buffer problemen (ik weet niet eens wat het is maar ok)
de console log:
Q3 1.11 win-x86 Nov 24 1999
----- FS_Startup -----
Current search path:
D:\Quake 3 Arena\baseq3\pak1.pk3 (7 files)
D:\Quake 3 Arena\baseq3\pak0.pk3 (2964 files)
D:\Quake 3 Arena/baseq3
execing default.cfg
execing q3config.cfg
couldn't exec autoexec.cfg
...detecting CPU, found x86 (P5/Pentium2, MMX)
------- Input Initialization -------
Initializing DirectInput...
Couldn't set DI coop level
Falling back to Win32 mouse support...
Joystick is not active.
----- Client Initialization -----
----- Initializing Renderer ----
----- Client Initialization Complete -----
--- Common Initialization Complete ---
Winsock Initialized
Opening IP socket: localhost:27960
Hostname: p2pc
IP: 10.11.12.3
Working directory: D:\Quake 3 Arena
----- R_Init -----
Initializing OpenGL subsystem
...assuming '3dfxvgl' is a standalone driver
...initializing QGL
...WARNING: missing Glide installation, assuming no 3Dfx available
...shutting down QGL
...initializing QGL
...calling LoadLibrary( 'C:\WINNT\System32\opengl32.dll' ): succeeded
...setting mode 3: 640 480 FS
...using desktop display depth of 16
...calling CDS: ok
...registered window class
...created window@0,0 (640x480)
Initializing OpenGL driver
...getting DC: succeeded
...GLW_ChoosePFD( 16, 16, 0 )
...35 PFDs found
...GLW_ChoosePFD failed
...35 PFDs found
...failed to find an appropriate PIXELFORMAT
...restoring display settings
...WARNING: could not set the given mode (3)
...using colorsbits of 16
...calling CDS: ok
...35 PFDs found
...35 PFDs found
...unloading OpenGL DLL
----- CL_Shutdown -----
RE_Shutdown( 1 )
GLW_StartOpenGL() - could not load OpenGL subsystem
ik snap er nix van. ik heb wel geprobeert om glsetup te instaleren, maar dat is alleen win 9x :(
nog een 2e probleem met ut, het draait wel met hardware. maar ik krijg deze error: The dynamic link library glide2x.dll could not be found in the specified path bla bla bla. ik heb mijn hele hd afgezocht, maar nergens glide2x.dll. :'(
pleace help asap
Het stoplicht staat op rood, het stoplicht staat op groen, in #TMF is altijd wat te doen. || http://quotes.negotiator.nl/7270 || /16 at work
  • Electrowolf
Electrowolf
Mod met Liefde!
glide2x.dll heb ik nu, maar ut crasht frontaal na de error: you need to configure XGI200 configutator, of zoiets.... HELP
  • P5ycho
3dfx heeft geen dual cpu support in zijn drivers zitten, dit kun je dus zeker schudden.
12x 280Wp ZO, 9x 280Wp + 8x 465Wp ZW, Zubadan SHW80YAA 8kW, Zehnder Q450 ERV
Ik wil die kaart wel voor 20,00 overnemen.
  • Kirpeknots
  • Registratie: Mei 2001
  • Laatst online: 07-08 23:39
Kirpeknots
Wazzup!
bied 25,00
(of is dit slechter dan een MGA200?)
moet de glide installeren die op de q3 cd staat
llama
  • Electrowolf
Electrowolf
Mod met Liefde!
heb jij de cd dan? ik niet (wat nou illigaal?! >:))
P5ycho heeft gelijk. Er zit geen smp ondersteuning in 3dfx kaarten. Bespaar je de moeite en koop een nVidia want die hebben het wel.
  • Electrowolf
Electrowolf
Mod met Liefde!
de kaart moet nix doen met de dual cpu's, q3 moet het doen... maar we zullen zien. heb net ergens beta drivers gevonden voor win2k 3dfx :)
  • Access
  • Laatst online: 06-08 19:54
Misschien moet je ff zoeken naar nieuwe drivers voor je Banshee op:
www.voodoofiles.com
ze hebben daar heel veel zooi, maar ik zou niet weten of er iets voor jouw tussen zit, moet je zelf maar ff kijken.
ik bied fl 30.00
ik heb ook nog een voodoo banshee kaart liggen (agp met 16mb ram) als je wil hebbe (voor prijsje natuurlijk) vraag je het me maar
voor wie wilt heb ik ook nog wel een voodoo 1 kaart ( bestaan er 286 met pci slote :D )
