Problemen met herinstallatie Samba (raspberry pi)
  • PheraX
  • Laatst online: 01-10 10:00
na een update op mijn raspberry krijg ik samba niet meer aan de praat, ik merkte dat hij niet mijn in de netwerk shares stond bij m'n PC.
geprobeerd te herinstaleren door de volgende commandsbron:
sudo apt-get remove --purge samba-common
sudo reboot
sudo apt-get install samba
alleen krijg ik dan de volgende output (laatste paar regels)
Setting up samba-common (2:4.2.14+dfsg-0+deb8u5) ...
debconf: warning: possible database corruption. Will attempt to repair by adding back missing question samba-common/workgroup.
Can't call method "description" on an undefined value at /usr/share/perl5/Debconf/Question.pm line 93, <GEN1> line 1.
dpkg: error processing package samba-common (--configure):
subprocess installed post-installation script returned error exit status 255
dpkg: dependency problems prevent configuration of samba-common-bin:
samba-common-bin depends on samba-common (= 2:4.2.14+dfsg-0+deb8u5); however:
Package samba-common is not configured yet.
dpkg: error processing package samba-common-bin (--configure):
dependency problems - leaving unconfigured
Setting up samba-dsdb-modules (2:4.2.14+dfsg-0+deb8u5) ...
Setting up tdb-tools (1.3.6-0+deb8u1) ...
update-alternatives: using /usr/bin/tdbbackup.tdbtools to provide /usr/bin/tdbbackup (tdbbackup) in auto mode
Setting up libfile-copy-recursive-perl (0.38-1) ...
Setting up update-inetd (4.43) ...
dpkg: dependency problems prevent configuration of samba:
samba depends on samba-common (= 2:4.2.14+dfsg-0+deb8u5); however:
samba depends on samba-common-bin (= 2:4.2.14+dfsg-0+deb8u5); however:
Package samba-common-bin is not configured yet.
dpkg: error processing package samba (--configure):
Setting up attr (1:2.4.47-2) ...
Setting up samba-vfs-modules (2:4.2.14+dfsg-0+deb8u5) ...
Processing triggers for libc-bin (2.19-18+deb8u7) ...
Errors were encountered while processing:
samba-common
samba-common-bin
samba
E: Sub-process /usr/bin/dpkg returned an error code (1)
als ik samba dan probeer op te starten krijg ik terug dat hij niet is geinstalleerd
sudo service smbd restart
Failed to restart smbd.service: Unit smbd.service failed to load: No such file or directory.
wat moet ik doen om dit op te lossen?
[ Voor 4% gewijzigd door PheraX op 04-05-2017 10:25 ]
  • Lethalis
Al eens eerst sudo apt update gedraaid?
Ask yourself if you are happy and then you cease to be.
  • PheraX
Lethalis schreef op donderdag 4 mei 2017 @ 11:40:
ja meerdere keren, ook geen succes.
  • CAPSLOCK2000
  • Laatst online: 16:00
CAPSLOCK2000
zie teletekst pagina 888
Er gaat iets mis met debconf, ik durf zo niet te zeggen of de database corrupt is of het package samba-common. Draai eens
sudo /usr/share/debconf/fix_db.pl
Je kan ook nog proberen om debconf te herinstalleren
sudo apt-get install --reinstall debconf
Welke distributie draai je? Debian Jessie? Raspbian?
[ Voor 22% gewijzigd door CAPSLOCK2000 op 04-05-2017 21:41 ]
This post is warranted for the full amount you paid me for it.
