Greetings everyone! [Still learning Dutch, sorry for English!]
I am having Difficulties to POST.
MOBO: GIGABYTE AB350M GAMING 3
MEM: CMK16GX4M2A2133C13R [2x8GB 2133Mhz]
PSU: Corsair RM550x
GPU: MSI RX 480 OC 8GB
I noticed that the memory I'm currently using is not supported by the motherboard (do have supported memory slots coming tomorrow) but was wondering what is the possibillity that the unsupported mememory is actually causing the problems?
When I power-on the computer, all fans spin-up and lights turn-on. Just no HDMI/DVI signal.
Thank you for your comments!
  • pharmacist
  • Laatst online: 25-09 17:46
Heb je de stroomconnector van de videokaart wel aangesloten ?
Yes, made sure it's connected firmly.
  • Xadeon
Xadeon
[☆] Generaal Laagvlieger [☆]
Heb je ook geprobeerd om met 1 geheugenkaart je systeem op te starten? Of je reepjes in A2 en B2 memoryslots te steken.
Gigabyte Aorus X570 Master / AMD Ryzen 9 5900X / G.Skill Trident Z 4000@3800 32GB / PowerColor Red Devil Radeon RX 7900 XTX 24GB | Tesla M3 LR '21
I've tried different combinations of DUAL-CHANNEL and also each single memory slot in each slot (that took awhile!) -- Also tested the monitor with my laptop, it does in fact work.
  • JesseMacaw
  • Registratie: Juli 2013
  • Laatst online: 20:42
JesseMacaw
Electronicafanaat
Have connected the small buzzer to the motherboard? If it's a hardware issue on the motherboard, you will most likely hear beeping then. If there are no problems and POST completes, even if it doesn't give a video signal, you will hear one short beep. It should be connected to a header near the front panel connectors.
