[Ubuntu] WARNING **: Unable to register authentication agent
  • Possible
  • Laatst online: 21:47
Sinds enkele maanden draai ik naar tevredenheid Ubuntu server 16.10 op mijn thuis server.
Vanochtend wou ik mijn packages upgraden zodat alles weer up-to date zou zijn. Echter wil dit maar niet lukken. Elke keer als ik wil upgraden krijg ik de volgende error:
 WARNING **: Unable to register authentication agent: GDBus.Error:org.freedesktop.PolicyKit1.Error.Failed: User of caller and user of subject differs.
Error registering authentication agent: GDBus.Error:org.freedesktop.PolicyKit1.Error.Failed: User of caller and user of subject differs. (polkit-error-quark, 0)
Failed to start snapd.service: Interactive authentication required.
See system logs and 'systemctl status snapd.service' for details.
snapd.service couldn't start.
Details
snapd.service - Snappy daemon
   Loaded: loaded (/lib/systemd/system/snapd.service; enabled; vendor preset: enabled)
   Active: active (running) since Fri 2017-03-10 16:32:52 CET; 2h 18min ago
 Main PID: 1087 (snapd)
    Tasks: 7 (limit: 4915)
   Memory: 15.9M
      CPU: 21ms
   CGroup: /system.slice/snapd.service
           └─1087 /usr/lib/snapd/snapd
Mar 10 16:32:52 ubuntu-server systemd[1]: Started Snappy daemon.
Mar 10 16:32:52 ubuntu-server /usr/lib/snapd/snapd[1087]: daemon.go:250: DEBUG: init done in 396.71µs
Mar 10 16:32:52 ubuntu-server /usr/lib/snapd/snapd[1087]: daemon.go:251: started snapd/2.22.3+16.10 (series 16; classic) ubuntu/16.10 (amd64).
Mar 10 16:32:52 ubuntu-server snapd[1087]: 2017/03/10 16:32:52.522287 daemon.go:251: started snapd/2.22.3+16.10 (series 16; classic) ubuntu/16.10 (amd64).
Met google word ik niet echt wijzer. Zelfs rebooten met ''sudo reboot'' werkt niet meer:
sudo apt-get -f install heeft helaas ook niet geholpen. Dit resulteert in dezelfde foutmelding.
User eterpstra is logged in on sshd.
Please retry operation after closing inhibitors and logging out other users.
Alternatively, ignore inhibitors and users with 'systemctl reboot -i'.
Ik log in via Putty. (Ik ben die user ook die alleen is ingelogd)
Iemand enig idee wat er aan de hand kan zijn?
[ Voor 26% gewijzigd door Possible op 10-03-2017 18:58 ]
  • Hero of Time
  • Laatst online: 21:56
Hero of Time
Moderator LNX
There is only one Legend
Die snapd service klinkt als iets voor snappy apps, dat nieuwe ding van Ubuntu. Als je daar geen gebruik van maakt, kan je 't net zo goed eraf gooien. Maar begin eerst met het uitschakelen van dat ding. Als je root kan worden of anderszins die foutmelding kan omzeilen voor het moment, voer dan het volgende uit:
systemctl stop snapd
systemctl disable snapd
En herstart de machine voor de zekerheid. Dat zal iig de laatste twee errors oplossen.
Hoe het met die gdbus error zit durf ik niet te zeggen. Iets met dbus of polkit, maar welke van de twee is dus de vraag.
Commandline FTW
