testje voor je engels
had geen zin om dit weer te gaan vertalen
I had my cel II 566 running at 850. WIth all my abit converter jumpers at auto. Because of that my abit bf6 couldn't go higher than a voltage of 1,75. So I set my abit converter jumpers to a voltage of 1,9 so I could bump the voltage in the bios to max of 2,10.
I went further with OC. I first set my fsb to 105, voltage 1,85. Stable. Then I tried 110 but failed. I've got 3x128 dimm and I removed 2 of them because I suspect them of being not capable of such a fsb. Didn't matter by the way. I bumped the voltage 2,00 and the fsb 110 and it was stable. However, my dnet rc5 thingie now only did 1,6 mkeys instead of the 2,33 with the original settings!! I clocked back to 105fsb but the same. I set the jumpers of the abit converter back to the original settings (all auto) but I still get a very low dnet score.
Q3 and UT are however normal. Only UT needs some more swapping (but this is I think of the less memory available).
) of heeft je moederbord dat misschien gedaan? Mijn CUSL2 zet automatisch de CAS latency van mijn geheugen terug op 3 als het geheugen de FSB niet aankan...
