Powershell - Excel: Find named cells and their values
  • 923 views
  • mootjuhh
  • Laatst online: 29-08 13:52
Hi,
Currently, I'm working on a PowerShell script which will read data from excel files. reading the cell values is not a problem as long as I use numbered reference (eg. instead o1,1 instead of A1). However, it is easy to add or remove rows/columns and therefore a fixed cell is not desirable.
We decided to used named cells, to fix the problem of adding rows/column. A new problem is the PowerShell script. I can't find an example of reading named cell.
Does anyone kwon whet
her it is possible to use named cell references?
Part of my current code:
$book=$excel.Workbooks.Open($global:filesNames[1].FullName)
$sheet=$book.WorkSheets.item(1)
$Cell=$sheet.Cells.Item(2,1).text #(row,col)
$Cell
What I would like:
$Cell=$sheet.Cells.Item("First_Name").text #(named cell)
$Cell
Many thanks in advance
P.s. Vraag staat ook op het Microsoft forum, maar tot op heden nog geen reactie op gehad. Hopelijk hier meer geluk.
  • ArnoutV
  • Laatst online: 13:40
Waarom in het Engels??
Maar gaat dat niet via de Range object?
  • mootjuhh
Thanks. De " was wat eerst niet werkte.
  • Creepy
  • Laatst online: 07:13
Creepy
Tactical Espionage Splatterer
Open je dan je volgende topic gewoon in het Nederlands? Want anders gaat ie gewoon op slot ;) We zijn hier nog steeds een Nederlands forum, geen Engelse..
[ Voor 14% gewijzigd door Creepy op 19-02-2017 19:28 ]
"I had a problem, I solved it with regular expressions. Now I have two problems". That's shows a lack of appreciation for regular expressions: "I know have _star_ problems" --Kevlin Henney
There are only two hard things in computer science: Naming things and vertically centering things - @DavidKPiano
We're building self-driving cars, but we haven't even figured out how to make sure vacuum cleaners don't join botnets. ?????????????????? Nederlands ????????????
  • RobIII
RobIII
Admin Devschuur®
^ Romeinse Ⅲ ja!
(overleden)
d:)b thanks voor deze nuttige bijdrage! _O_
Overigens: het is "There are 2 hard problems in computer science: cache invalidation, naming things, and off-by-1 errors. -- Leon Bambrick" :+
[ Voor 63% gewijzigd door RobIII op 28-11-2018 13:57 ]
Je eigen tweaker.me redirect
Over mij
