Smartwares SH5-RBS-04A set to ON by default
Is it possible to make the smartwares SH5-RBS-04A and SH5-RBD-01A wireless switches to be ON by default or remember last state after power outage?
I tried to short circuit the two wires that can be connected to a wall switch, but it does not help. It will be always OFF after power outage.
What I`m trying to achieve:
Have two lights in the living room on the same single wall switch. I want to be able to use the wall switch as default ON/OFF and then additionally control the two wireless switches remotely when needed. I would built in the smartwares switches directly on the two lights so I can control them independently.
At the moment I could only control them with the Remote, cannot turn ON with the wall switch.
The main reason is that I want to be able to switch ON/OFF with a static wall switch in case a remote is left somewhere else. And then use the remote when want to control the independently.
Any ideas or suggestions?
Would I be able to control the two Smartwares switches with this kaku switch?
pricewatch: KlikAanKlikUit AWST-8802 Draadloze dubbele wandschakelaar
