• digidokter.net
  • Laatst online: 07-01-2024
digidokter.net
... en 'Niets' van 'Alles' LOL
Systeem:
MARANTZSR5010 | JAMO-S426HSX3 | AsrockB85i54440-16GRAMxfx7900 :
Computer = zelfbouw ASROCK
RAM = 16Gigabyte
CPU = i54440 (4 cores) op 3,1 Gigahz
Grafische kaart = xfx7900 (4 Gigabute)
HD= SSD 250Gigabyte
Toegepaste oplossingen van google search:
https://www.google.nl/webhp?sourceid=chrome-instant&ion=1&espv=2&ie=UTF-8&client=ubuntu#q=kodi+cpu
RSS uitgeschakeld, log ingeschakeld: maar geen verbeteringen?! BUG in versie16.1 GIT c327c53??
Wie heeft tips?!
Gedaan:
- Systemreset, system restart, kodi herinstall, kodi backup terug: Niets helpt...
Please HELP, het systeem loopt chronisch vast na 1 uur streamen...:(
LOG:
15:57:06 T:140182485301568 NOTICE: special://profile/ is mapped to: special://masterprofile/
15:57:06 T:140182485301568 NOTICE: -----------------------------------------------------------------------
15:57:06 T:140182485301568 NOTICE: Starting Kodi (16.1 Git:c327c53). Platform: Linux x86 64-bit
15:57:06 T:140182485301568 NOTICE: Using Release Kodi x64 build
15:57:06 T:140182485301568 NOTICE: Kodi compiled Apr 25 2016 by GCC 5.3.1 for Linux x86 64-bit version 4.4.6 (263174)
15:57:06 T:140182485301568 NOTICE: Running on Linux Mint 18.1, kernel: Linux x86 64-bit version 4.4.0-21-generic
15:57:06 T:140182485301568 NOTICE: FFmpeg statically linked, version: 2.8.6-kodi-2.8.6-Jarvis-16.0
15:57:06 T:140182485301568 NOTICE: Host CPU: Intel(R) Core(TM) i5-4440 CPU @ 3.10GHz, 4 cores available
15:57:06 T:140182485301568 NOTICE: special://xbmc/ is mapped to: /usr/share/kodi
15:57:06 T:140182485301568 NOTICE: special://xbmcbin/ is mapped to: /usr/lib/kodi
15:57:06 T:140182485301568 NOTICE: special://masterprofile/ is mapped to: /home/user/.kodi/userdata
15:57:06 T:140182485301568 NOTICE: special://home/ is mapped to: /home/user/.kodi
15:57:06 T:140182485301568 NOTICE: special://temp/ is mapped to: /home/user/.kodi/temp
15:57:06 T:140182485301568 NOTICE: The executable running is: /usr/lib/kodi/kodi.bin
15:57:06 T:140182485301568 NOTICE: Local hostname: Corsair2016
15:57:06 T:140182485301568 NOTICE: Log File is located: /home/user/.kodi/temp/kodi.log
15:57:06 T:140182485301568 ERROR: DBus: Error org.freedesktop.DBus.Error.InvalidArgs - No such property 'CanSuspend'
15:57:06 T:140182485301568 ERROR: DBus: Error org.freedesktop.DBus.Error.InvalidArgs - No such property 'CanHibernate'
15:57:06 T:140182485301568 NOTICE: load settings...
15:57:12 T:140182485301568 NOTICE: Found 1 Lists of Devices
15:57:12 T:140182485301568 NOTICE: Enumerated PULSE devices:
15:57:12 T:140182485301568 NOTICE: Device 1
15:57:12 T:140182485301568 NOTICE: m_deviceName : Default
15:57:12 T:140182485301568 NOTICE: m_displayName : Default
15:57:12 T:140182485301568 NOTICE: m_displayNameExtra: Default Output Device (PULSEAUDIO)
15:57:12 T:140182485301568 NOTICE: m_deviceType : AE_DEVTYPE_PCM
15:57:12 T:140182485301568 NOTICE: m_channels : FL,FR
15:57:12 T:140182485301568 NOTICE: m_sampleRates : 5512,8000,11025,16000,22050,32000,44100,48000,64000,88200,96000,176400,192000,384000
15:57:12 T:140182485301568 NOTICE: m_dataFormats : AE_FMT_U8,AE_FMT_S16NE,AE_FMT_S24NE3,AE_FMT_S24NE4,AE_FMT_S32NE,AE_FMT_FLOAT
15:57:12 T:140182485301568 NOTICE: Device 2
15:57:12 T:140182485301568 NOTICE: m_deviceName : alsa_output.pci-0000_01_00.1.hdmi-surround71
15:57:12 T:140182485301568 NOTICE: m_displayName : Tahiti XT HDMI Audio [Radeon HD 7970 Series] Digital Surround 7.1 (HDMI)
15:57:12 T:140182485301568 NOTICE: m_displayNameExtra: HDMI / DisplayPort (PULSEAUDIO)
15:57:12 T:140182485301568 NOTICE: m_channels : FL,FR,BL,BR,FC,LFE,SL,SR
15:57:12 T:140182485301568 NOTICE: Device 3
15:57:12 T:140182485301568 NOTICE: m_deviceName : alsa_output.pci-0000_00_1b.0.analog-stereo
15:57:12 T:140182485301568 NOTICE: m_displayName : Built-in Audio Analog Stereo
15:57:12 T:140182485301568 NOTICE: m_displayNameExtra: Line Out (PULSEAUDIO)
15:57:12 T:140182485301568 NOTICE: No settings file to load (special://xbmc/system/advancedsettings.xml)
15:57:12 T:140182485301568 NOTICE: Loaded settings file from special://profile/advancedsettings.xml
15:57:12 T:140182485301568 NOTICE: Contents of special://profile/advancedsettings.xml are...
<advancedsettings>
<network>
<buffermode> 1 </buffermode>
<readbufferfactor> 1.5 </readbufferfactor>
<cachemembuffersize> 104857600 </cachemembuffersize>
</network>
</advancedsettings>
15:57:12 T:140182485301568 NOTICE: Default DVD Player: dvdplayer
15:57:12 T:140182485301568 NOTICE: Default Video Player: dvdplayer
15:57:12 T:140182485301568 NOTICE: Default Audio Player: paplayer
15:57:12 T:140182485301568 NOTICE: Disabled debug logging due to GUI setting. Level 0.
15:57:12 T:140182485301568 NOTICE: Log level changed to "LOG_LEVEL_NORMAL"
15:57:12 T:140182485301568 NOTICE: CMediaSourceSettings: loading media sources from special://masterprofile/sources.xml
15:57:12 T:140182485301568 NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
15:57:12 T:140182485301568 NOTICE: Loaded playercorefactory configuration
15:57:12 T:140182485301568 NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
15:57:12 T:140182485301568 NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
15:57:12 T:140181997524736 NOTICE: PulseAudio: Opened device Default in pcm mode with Buffersize 150 ms
15:57:12 T:140182485301568 NOTICE: Running database version Addons20
15:57:12 T:140182485301568 NOTICE: ADDONS: Using repository repository.exodus
15:57:12 T:140182
485301568 NOTICE: Setup SDL
15:57:13 T:140182485301568 NOTICE: Checking resolution 15
15:57:13 T:140182485301568 NOTICE: Using visual 0x2f8
15:57:13 T:140182485301568 NOTICE: GL_VENDOR = X.Org
15:57:13 T:140182485301568 NOTICE: GL_RENDERER = Gallium 0.4 on AMD TAHITI (DRM 2.43.0, LLVM 3.8.0)
15:57:13 T:140182485301568 NOTICE: GL_VERSION = 3.0 Mesa 11.2.0
15:57:13 T:140182485301568 NOTICE: GL_SHADING_LANGUAGE_VERSION = 1.30
15:57:13 T:140182485301568 NOTICE: GL_GPU_MEMORY_INFO_TOTAL_AVAILABLE_MEMORY_NVX = 5238576
15:57:13 T:140182485301568 NOTICE: GL_GPU_MEMORY_INFO_DEDICATED_VIDMEM_NVX = 3145728
15:57:13 T:140182485301568 NOTICE: GL_EXTENSIONS = GL_ARB_multisample GL_EXT_abgr GL_EXT_bgra GL_EXT_blend_color GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_copy_texture GL_EXT_polygon_offset GL_EXT_subtexture GL_EXT_texture_object GL_EXT_vertex_array GL_EXT_compiled_vertex_array GL_EXT_texture GL_EXT_texture3D GL_IBM_rasterpos_clip GL_ARB_point_parameters GL_EXT_draw_range_elements GL_EXT_packed_pixels GL_EXT_point_parameters GL_EXT_rescale_normal GL_EXT_separate_specular_color GL_EXT_texture_edge_clamp GL_SGIS_generate_mipmap GL_SGIS_texture_border_clamp GL_SGIS_texture_edge_clamp GL_SGIS_texture_lod GL_ARB_framebuffer_sRGB GL_ARB_multitexture GL_EXT_framebuffer_sRGB GL_IBM_multimode_draw_arrays GL_IBM_texture_mirrored_repeat GL_ARB_texture_cube_map GL_ARB_texture_env_add GL_ARB_transpose_matrix GL_EXT_blend_func_separate GL_EXT_fog_coord GL_EXT_multi_draw_arrays GL_EXT_secondary_color GL_EXT_texture_env_add GL_EXT_texture_filter_anisotropic GL_EXT_texture_lod_bias GL_INGR_blend_func_separate GL_NV_blend_square GL_NV_light_max_exponent GL_NV_texgen_reflection GL_NV_texture_env_combine4 GL_S3_s3tc GL_SUN_multi_draw_arrays GL_ARB_texture_border_clamp GL_ARB_texture_compression GL_EXT_framebuffer_object GL_EXT_texture_compression_s3tc GL_EXT_texture_env_combine GL_EXT_texture_env_dot3 GL_MESA_window_pos GL_NV_packed_depth_stencil GL_NV_texture_rectangle GL_ARB_depth_texture GL_ARB_occlusion_query GL_ARB_shadow GL_ARB_texture_env_combine GL_ARB_texture_env_crossbar GL_ARB_texture_env_dot3 GL_ARB_texture_mirrored_repeat GL_ARB_window_pos GL_EXT_stencil_two_side GL_EXT_texture_cube_map GL_NV_depth_clamp GL_NV_fog_distance GL_APPLE_packed_pixels GL_APPLE_vertex_array_object GL_ARB_draw_buffers GL_ARB_fragment_program GL_ARB_fragment_shader GL_ARB_shader_objects GL_ARB_vertex_program GL_ARB_vertex_shader GL_ATI_draw_buffers GL_ATI_texture_env_combine3 GL_ATI_texture_float GL_EXT_depth_bounds_test GL_EXT_shadow_funcs GL_EXT_stencil_wrap GL_MESA_pack_invert GL_NV_primitive_restart GL_ARB_depth_clamp GL_ARB_fragment_program_shadow GL_ARB_half_float_pixel GL_ARB_occlusion_query2 GL_ARB_point_sprite GL_ARB_shading_language_100 GL_ARB_sync GL_ARB_texture_non_power_of_two GL_ARB_vertex_buffer_object GL_ATI_blend_equation_separate GL_EXT_blend_equation_separate GL_OES_read_format GL_ARB_color_buffer_float GL_ARB_pixel_buffer_object GL_ARB_texture_compression_rgtc GL_ARB_texture_float GL_ARB_texture_rectangle GL_ATI_texture_compression_3dc GL_EXT_packed_float GL_EXT_pixel_buffer_object GL_EXT_texture_compression_dxt1 GL_EXT_texture_compression_rgtc GL_EXT_texture_mirror_clamp GL_EXT_texture_rectangle GL_EXT_texture_sRGB GL_EXT_texture_shared_exponent GL_ARB_framebuffer_object GL_EXT_framebuffer_blit GL_EXT_framebuffer_multisample GL_EXT_packed_depth_stencil GL_ARB_vertex_array_object GL_ATI_separate_stencil GL_ATI_texture_mirror_once GL_EXT_draw_buffers2 GL_EXT_draw_instanced GL_EXT_gpu_program_parameters GL_EXT_texture_array GL_EXT_texture_compression_latc GL_EXT_texture_integer GL_EXT_texture_sRGB_decode GL_EXT_timer_query GL_OES_EGL_image GL_AMD_performance_monitor GL_ARB_copy_buffer GL_ARB_depth_buffer_float GL_ARB_draw_instanced GL_ARB_half_float_vertex GL_ARB_instanced_arrays GL_ARB_map_buffer_range GL_ARB_texture_rg GL_ARB_texture_swizzle GL_ARB_vertex_array_bgra GL_EXT_texture_swizzle GL_EXT_vertex_array_bgra GL_NV_conditional_render GL_AMD_conservative_depth GL_AMD_draw_buffers_blend GL_AMD_seamless_cubemap_per_texture GL_AMD_shader_stencil_export GL_ARB_ES2_compatibility GL_ARB_blend_func_extended GL_ARB_debug_output GL_ARB_draw_buffers_blend GL_ARB_draw_elements_base_vertex GL_ARB_explicit_attrib_location GL_ARB_fragment_coord_conventions GL_ARB_provoking_vertex GL_ARB_sample_shading GL_ARB_sampler_objects GL_ARB_seamless_cube_map GL_ARB_shader_stencil_export GL_ARB_shader_texture_lod GL_ARB_texture_cube_map_array GL_ARB_texture_gather GL_ARB_texture_multisample GL_ARB_texture_query_lod GL_ARB_texture_rgb10_a2ui GL_ARB_uniform_buffer_object GL_ARB_vertex_type_2_10_10_10_rev GL_ATI_meminfo GL_EXT_provoking_vertex GL_EXT_texture_snorm GL_MESA_texture_signed_rgba GL_NV_texture_barrier GL_ARB_get_program_binary GL_ARB_robustness GL_ARB_separate_shader_objects GL_ARB_shader_bit_encoding GL_ARB_shader_precision GL_ARB_texture_compression_bptc GL_ARB_timer_query GL_ARB_transform_feedback2 GL_ARB_transform_feedback3 GL_NV_vdpau_interop GL_ANGLE_texture_compression_dxt3 GL_ANGLE_texture_compression_dxt5 GL_ARB_base_instance GL_ARB_compressed_texture_pixel_storage GL_ARB_conservative_depth GL_ARB_internalformat_query GL_ARB_map_buffer_alignment GL_ARB_shading_language_420pack GL_ARB_shading_language_packing GL_ARB_texture_storage GL_ARB_transform_feedback_instanced GL_EXT_framebuffer_multisample_blit_scaled GL_EXT_transform_feedback GL_AMD_shader_trinary_minmax GL_ARB_ES3_compatibility GL_ARB_arrays_of_arrays GL_ARB_clear_buffer_object GL_ARB_copy_image GL_ARB_explicit_uniform_location GL_ARB_invalidate_subdata GL_ARB_program_interface_query GL_ARB_stencil_texturing GL_ARB_texture_query_levels GL_ARB_texture_storage_multisample GL_ARB_texture_view GL_ARB_vertex_attrib_binding GL_KHR_debug GL_AMD_pinned_memory GL_ARB_buffer_storage GL_ARB_multi_bind GL_ARB_seamless_cubemap_per_texture GL_ARB_texture_mirror_clamp_to_edge GL_ARB_texture_stencil8 GL_ARB_vertex_type_10f_11f_11f_rev GL_EXT_shader_integer_mix GL_NVX_gpu_memory_info GL_ARB_clip_control GL_ARB_conditional_render_inverted GL_ARB_derivative_control GL_ARB_get_texture_sub_image GL_ARB_pipeline_statistics_query GL_ARB_shader_texture_image_samples GL_ARB_texture_barrier GL_EXT_polygon_offset_clamp GL_KHR_context_flush_control
15:57:14 T:140182485301568 NOTICE: Running database version Addons20
15:57:14 T:140182485301568 NOTICE: Running database version ViewModes6
15:57:14 T:140182485301568 NOTICE: Running database version Textures13
15:57:14 T:140182485301568 NOTICE: Running database version MyMusic56
15:57:14 T:140182485301568 NOTICE: Running database version MyVideos99
15:57:14 T:140182485301568 NOTICE: Running database version TV29
15:57:14 T:140182485301568 NOTICE: Running database version Epg11
15:57:14 T:140182485301568 NOTICE: start dvd mediatype detection
15:57:14 T:140182485301568 NOTICE: starting zeroconf publishing
15:57:14 T:140182485301568 NOTICE: starting upnp client
15:57:14 T:140182485301568 ERROR: JSONRPC Server: Failed to bind ipv4 serversocket
15:57:14 T:140180954543872 NOTICE: ES: Starting UDP Event server on 127.0.0.1:9777
15:57:14 T:140180954543872 NOTICE: UDP: Listening on port 9777
16:05:55 T:140182485301568 WARNING: JSONRPC: Could not parse type "Setting.Details.SettingList"
16:05:55 T:140182485301568 NOTICE: ActiveAE DSP - starting
16:05:55 T:140182485301568 NOTICE: initialize done
16:05:55 T:140182485301568 NOTICE: Running the application...
16:05:55 T:140182485301568 ERROR: Keymapping error: no such action 'playmedia()' defined
16:05:57 T:140181675955968 NOTICE: 1Channel: Service: Installed Version: 2.5.72
16:05:57 T:140181675955968 NOTICE: 1Channel: Loading sqlite3 as DB engine
16:05:57 T:140181675955968 NOTICE: 1Channel: Service: Resetting...
16:05:57 T:140181675955968 NOTICE: 1Channel: Service: starting...
16:05:57 T:140180946151168 ERROR: Exception in thread Thread-1:
File "/usr/lib/python2.7/threading.py", line 801, in __bootstrap_inner
self.run()
File "/usr/lib/python2.7/threading.py", line 754, in run
self.__target(*self.__args, **self.__kwargs)
File "/home/user/.kodi/addons/script.module.axel.downloader/lib/axelproxy.py", line 579, in start_proxy_internal
httpd = server_class((host_name, port), myhandler)
File "/usr/lib/python2.7/SocketServer.py", line 417, in __init__
self.server_bind()
File "/usr/lib/python2.7/BaseHTTPServer.py", line 108, in server_bind
SocketServer.TCPServer.server_bind(self)
File "/usr/lib/python2.7/SocketServer.py", line 431, in server_bind
self.socket.bind(self.server_address)
File "/usr/lib/python2.7/socket.py", line 228, in meth
return getattr(self._sock,name)(*args)
error: [Errno 98] Address already in use
16:05:57 T:140181659170560 NOTICE: [plugin.video.youtube] Startup: detected Jarvis (Kodi-16.1), setting DASH_SUPPORT_BUILTIN = False, DASH_SUPPORT_ADDON = False
16:05:57 T:140181997524736 NOTICE: PulseAudio: Opened device Default in pcm mode with Buffersize 150 ms
16:05:59 T:140182485301568 NOTICE: Storing total System Uptime
16:05:59 T:140182485301568 NOTICE: Saving settings
16:05:59 T:140182485301568 NOTICE: stop all
16:05:59 T:140182485301568 NOTICE: stop player
16:05:59 T:140182485301568 NOTICE: ES: Stopping event server
16:05:59 T:140182485301568 NOTICE: stopping upnp
16:05:59 T:140182485301568 NOTICE: stopping zeroconf publishing
16:06:00 T:140180954543872 NOTICE: ES: UDP Event server stopped
16:06:00 T:140182485301568 NOTICE: stop dvd detect media
16:06:00 T:140182485301568 NOTICE: stop sap announcement listener
16:06:00 T:140182485301568 NOTICE: clean cached files!
16:06:00 T:140182485301568 NOTICE: unload skin
16:06:02 T:140181675955968 NOTICE: 1Channel: Service: shutting down...
16:06:03 T:140182485301568 NOTICE: stopped
16:06:03 T:140182485301568 NOTICE: destroy
16:06:03 T:140182485301568 NOTICE: closing down remote control service
16:06:03 T:140182485301568 NOTICE: unload sections
16:06:03 T:140182485301568 NOTICE: special://profile/ is mapped to: special://masterprofile/
16:06:03 T:140182485301568 WARNING: Attempted to remove window 10013 from the window manager when it didn't exist
16:06:03 T:140182485301568 WARNING: Attempted to remove window 10014 from the window manager when it didn't exist
16:06:03 T:140182485301568 WARNING: Attempted to remove window 10015 from the window manager when it didn't exist
16:06:03 T:140182485301568 WARNING: Attempted to remove window 10016 from the window manager when it didn't exist
16:06:03 T:140182485301568 WARNING: Attempted to remove window 10017 from the window manager when it didn't exist
16:06:03 T:140182485301568 WARNING: Attempted to remove window 10018 from the window manager when it didn't exist
16:06:03 T:140182485301568 WARNING: Attempted to remove window 10019 from the window manager when it didn't exist
16:06:03 T:140182485301568 WARNING: Attempted to remove window 10021 from the window manager when it didn't exist
16:06:03 T:140182485301568 WARNING: Attempted to remove window 10107 from the window manager when it didn't exist
16:06:03 T:140182485301568 WARNING: Attempted to remove window 10115 from the window manager when it didn't exist
16:06:03 T:140182485301568 WARNING: Attempted to remove window 10104 from the window manager when it didn't exist
16:06:03 T:140182485301568 NOTICE: application stopped...
[ Voor 104% gewijzigd door digidokter.net op 05-02-2017 14:59 . Reden: code toegevoegd ]
Verstand van 'Alles' van 'Niets'
  • TommyboyNL
Wat voor systeem hebben we het over? Een dual-core ARMv7 op 700MHz, of een 16 core Xeon, of iets daar tussenin?
  • digidokter.net
digidokter.net
TommyboyNL schreef op zaterdag 4 februari 2017 @ 17:49:
Sorry voor ontbreken systeem: Maar staat in mijn onderschift:
RAM = 16Gigabyte
CPU = i54440 (4 cores) op 3.1 Gigahz
HD= SSD 250Gigabyte
  • devil-strike
  • Laatst online: 25-10 01:02
staat in de log: 15:57:06 T:140182485301568 NOTICE: Host CPU: Intel(R) Core(TM) i5-4440 CPU @ 3.10GHz, 4 cores
  • digidokter.net
digidokter.net
Als ie echt vastloopt is het lastig, want dan vind ik vaak niks terug in de logs en is het dus niet vast te stellen waar het misgaat. Volgens mij is 16.1 trouwens een oude versie en is 16.2 al weer geruime tijd uit en staat 18.1 mint mate (heb ik updated) op uitkomen.
Overigens heb ik mijn moederbord en voeding vervangen, juist vanwege dit soort problemen. Het heeft geholpen, maar dat wil niet zeggen dat zulke rigoureuze maatregelen weer nodig zijn want het systeem is 2 jaar oud! :(
Update:
Een oplossing gevonden:
Freezes/Crashes with ASRock Skylake motherboards
A known issue is affecting ASRock Skylake motherboards. The kernel floods /var/log/syslog with messages until the disk runs out of space.
If you are suffering from this issue add "echo 'disable' > /sys/firmware/acpi/interrupts/gpe6F" into your /etc/rc.local (to edit this file with admin privileges, you can type "gksu xed /etc/rc.local").
For more information on this issue, please visit https://forums.linuxmint.com/viewtopic.php?f=49&t=223180.
Bron: https://www.linuxmint.com/rel_sarah_mate.php
Ik ga bovenstaande uitproberen....:)
Update bovenstaande is niet gelukt:
Ik maak backup van alles en instaleer fresh van 0! Hopelijk werkt het?! _/-\o_
Update:
Vastlopen is opgelost!!!
Kan slotje op. _/-\o_
Allen bedankt!! :)
Probleem is terug :(
[ Voor 49% gewijzigd door digidokter.net op 20-02-2017 17:15 ]
