Cisco AP wil niet joinen met Controller
Ik heb hier een Cisco wireless controller op een ESX host staan. Hier zijn 2 accesspoints op gejoined , maar een 3e ( nieuwe & ander type ) wil maar niet joinen.
Nuttige info:
Controller versie: Software Version 8.0.100.0
Host: VMware ESX 4
Type accesspoints welke wel willen: 2602I-E-K9
Type accesspoints welke niet willen: 2702IAIR-AP2702I-UXK9
Melding in de van de log controller :
*spamApTask3: Jan 09 20:20:21.685: #CAPWAP-3-INVALID_PREAMBLE: capwap_ac_sm.c:8713 The system detects an invalid preamble type (12) in capwap message from 192.168.8.2:61585
*spamApTask4: Jan 09 20:20:21.655: #CAPWAP-3-DUP_AP_NAME: capwap_ac_decode.c:1113 AP with same name AP5c83.8f8f.0914 exist. Using default name AP5c83.8f8f.0914 for this AP.
Deze meldingen herhalen zich.
Op de Join pagina staat
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
General
Base MAC Address    5c:83:8f:8f:09:14
AP Name         AP5c83.8f8f.0914
Ethernet MAC Address    5c:83:8f:8f:09:14
IP Address(Ipv4/Ipv6)   192.168.8.2
Status          Not joined
Last AP Join
Timestamp       Message
Jan 09 20:26:52.043 Received Discovery request and sent response
Jan 09 20:26:52.019 Received Join request and sent response
Discovery Phase Statistics
Requests Received   164
Responses Sent      164
Unsuccessful Request Processed  0
Reason For Last Unsuccessful Attempt    -
Last Successful Attempt Time        Jan 09 20:26:52.043
Last Unsuccessful Attempt Time  -
Join Phase Statistics
Requests Received   54
Responses Sent      54
Last Successful Attempt Time    Jan 09 20:26:52.019
Configuration Phase Statistics
Requests Received   0
Responses Sent      0
Last Successful Attempt Time    -
Last Error Summary
Last AP Message Decryption Failure  -
Last AP Connection Failure      -
Last AP Disconnect Reason       -
Last Error Occurred         -
Last Error Occurred Reason      -
Last Join Error Timestamp       -
Wat ik zelf al gedaan heb?
- zo'n beetje alles :'(
- esx host herstarten
- controller herstarten
- devices in zelfde subnet
- landinstellingen controller aanpassen
- andere licentie activeren in controller
- DHCP parameters mee geven ( optie 43 )
- DNS naam invullen in dns
- datum & tijd goed zetten
Handmatig joinen gaat helaas niet lukken aangezien je niet kan inloggen op de accesspoints met Cisco / Cisco ( wat volgens internet wel zou moeten kunnen )
De vraag is dus als iemand nog suggesties heeft hoe ik alsnog de accesspoints kan joinen
  • .Maarten
  • Laatst online: 23:18
Check de mac adressen eens. Het lijkt erop dat er een apparaat is gejoind met dezelfde naam. Tenminste dat staat in het logboek. En die naam is op basis van Mac adres.
.Maarten schreef op maandag 9 januari 2017 @ 20:38:
Dat heb ik dus gecontroleerd. Maar dat is dus niet het geval. Er zijn maar 2 accesspoints gejoined en dat zijn de oude 2602I.
  • Swifty88
  • Registratie: Januari 2016
  • Laatst online: 01-10 18:58
Die 2702I is het gehele type nummer ? Zijn het toevallig AIR-AP2702I-UXK9 ?
Swifty88 schreef op maandag 9 januari 2017 @ 20:55:
toevallig zijn het wel de AIR-AP2702I-UXK9 ja...
  • Swifty88
Volgens de release guide van je controller software wordt dat type access point niet ondersteund. Pas vanaf versie 8.0.110 is dit type AP welkom.
Linkje
Je zult moeten upgraden om het te laten werken ben ik bang.
Swifty88 schreef op maandag 9 januari 2017 @ 21:07:
Linkje
thnx ..
[ Voor 10% gewijzigd door Verwijderd op 09-01-2017 22:57 ]
