[Raspberry Pi 3] Wifi instabiel
  • Shinji
  • Laatst online: 15:02
Sinds eergister een Raspberry Pi gekocht. Helaas lijkt de wifi niet echt stabiel:
Staat op ongeveer 1 meter van mijn Horizon box. Heb verschillende posities geprobeerd om te kijken of dat het verbeterde.
29
30
31
32
Reply from 192.168.1.140: bytes=32 time=15ms TTL=64
Reply from 192.168.1.140: bytes=32 time=7ms TTL=64
Request timed out.
Reply from 192.168.1.140: bytes=32 time=14ms TTL=64
Reply from 192.168.1.140: bytes=32 time=9ms TTL=64
Request timed out.
Reply from 192.168.1.140: bytes=32 time=10ms TTL=64
Reply from 192.168.1.140: bytes=32 time=313ms TTL=64
Reply from 192.168.1.140: bytes=32 time=72ms TTL=64
Request timed out.
Reply from 192.168.1.140: bytes=32 time=21ms TTL=64
Reply from 192.168.1.140: bytes=32 time=16ms TTL=64
Request timed out.
Reply from 192.168.1.140: bytes=32 time=6ms TTL=64
Reply from 192.168.1.140: bytes=32 time=8ms TTL=64
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Reply from 192.168.1.140: bytes=32 time=11ms TTL=64
Daarnaast lijkt die regelmatig helemaal uit te vallen.
Andersom geen timeouts maar wel hele hoge reply tijden:
64 bytes from 192.168.1.254: icmp_seq=32 ttl=64 time=11.5 ms
64 bytes from 192.168.1.254: icmp_seq=33 ttl=64 time=7.56 ms
64 bytes from 192.168.1.254: icmp_seq=34 ttl=64 time=3.91 ms
64 bytes from 192.168.1.254: icmp_seq=35 ttl=64 time=52.4 ms
64 bytes from 192.168.1.254: icmp_seq=36 ttl=64 time=10.1 ms
64 bytes from 192.168.1.254: icmp_seq=37 ttl=64 time=8.07 ms
64 bytes from 192.168.1.254: icmp_seq=38 ttl=64 time=5.75 ms
64 bytes from 192.168.1.254: icmp_seq=41 ttl=64 time=349 ms
64 bytes from 192.168.1.254: icmp_seq=42 ttl=64 time=12.5 ms
64 bytes from 192.168.1.254: icmp_seq=44 ttl=64 time=112 ms
64 bytes from 192.168.1.254: icmp_seq=46 ttl=64 time=2061 ms
64 bytes from 192.168.1.254: icmp_seq=47 ttl=64 time=1061 ms
64 bytes from 192.168.1.254: icmp_seq=48 ttl=64 time=61.9 ms
64 bytes from 192.168.1.254: icmp_seq=50 ttl=64 time=7.83 ms
64 bytes from 192.168.1.254: icmp_seq=51 ttl=64 time=57.1 ms
64 bytes from 192.168.1.254: icmp_seq=52 ttl=64 time=16.6 ms
64 bytes from 192.168.1.254: icmp_seq=53 ttl=64 time=8.61 ms
Draai er tot nu toe Raspbian Lite (Jessie) met Home Assistant en Mosquitto op. Iemand een idee wat dit zou kunnen zijn of waar ik kan zoeken wat er aan de hand is? Als die is vastgelopen kan ik niks, herstart lost het op maar weet niet waar ik logging kan vinden over wat er aan de hand was.
Ook nog even bedraad geprobeerd:
Reply from 192.168.1.153: bytes=32 time=53ms TTL=64
Reply from 192.168.1.153: bytes=32 time=3ms TTL=64
Reply from 192.168.1.153: bytes=32 time=5ms TTL=64
Reply from 192.168.1.153: bytes=32 time=295ms TTL=64
Reply from 192.168.1.153: bytes=32 time=1ms TTL=64
Reply from 192.168.1.153: bytes=32 time=10ms TTL=64
Reply from 192.168.1.153: bytes=32 time=12ms TTL=64
Reply from 192.168.1.153: bytes=32 time=4ms TTL=64
Stukken beter maar voor een directe verbinding vind ik het nog best een hoge reply.
[ Voor 33% gewijzigd door Shinji op 18-12-2016 16:22 ]
  • Mitchelll010
  • Laatst online: 19-10 15:42
