Wat is het verschil hiertussen?
  • 105 views sinds 30-01-2008
  • FireStarter
  • Laatst online: 22-05 14:08
In de Pricewatch staan 2 monitoren:
de Sony 19" CPD-E400 FL 1324,-
en Sony 19" CPD-E400e FL 1324,-
Wat is het verschil hiertussen of is het gewoon een fout ofzo?
En is deze monitor even goed als de EIZO 19" F730 FL 1556,- ?
w00t
  • Rhino
  • Laatst online: 20-08 13:03
Rhino
Dat ben ik
Wortelkanaal behandelingen zijn volgens mij niet zo prettig
  • FireStarter
ow, ik was nog effe bezig met het uitwerken van de specs.
De specs van de Sony CPD-E400 :
Specifications
Model:
CPD-E400
CRT:
19" (18.0" viewable image size)
Aperture Grille Pitch:
0.24mm (minimum)
Screen Treatment:
High contrast AR coating
Horizontal Scan Range:
30 - 96kHz
Vertical Scan Range:
48 - 120Hz
Maximum Resolution:
1800 x 1440 @ 60Hz
Recommended Resolution:
1280 X 1024 @ 85Hz
Preset Resolutions:
Timing Data Table (TDT) - 28 modes,
User adjustable - 15 settings
Color Temperature Presets:
5000 Kelvin, 9300 Kelvin, User adjustable, sRGB
Signal Inputs:
Analog RGB 0.7Vp-p, 75 ohm (typical)
External Sync Signals:
Separate HD/VD, polarity-free TTL
External composite, polarity-free TTL
Sync on Green 0.3 p-p +/- 10%, negative
Input Connector:
Input 1: D-sub 15HD Captive
Power Requirements:
90-264V AC; 50-60Hz
Operating Temperature:
50° F-104° F (10° C-40° C)
Operating Humidity:
10%-80% (non-condensing)
Dimensions (W x H x D):
17.6" x 18.3" x 18.2"
Weight:
57.3 lbs.
Power Management:
Operation:<140 watts
Suspend:<15 watts (maximum)
Active Off: <3 watts (maximum)
Power Off: 0 watts
Front Panel Digital Controls:
Power On/Off
Slide Input Indicator
Reset
DisplayMouse control
On-Screen Display:
Contrast
Brightness
H/V Size and Centering
H/V Convergence
Control Lock
Zoom
Raster Rotation
Pincushion
Pin Balance
sRGB
Keystone
Key Balance
Color Temperature
Moire Adjust
H/V OSD Position
Manual DeGauss
Control Lock
Multi-Language Select: 9 Languages
Help Menu
Supplied Accessories:
AC Power Cord
INF Diskette
MAC Adapter
User's Manual
Limited Warranty:
3 Years - Parts, Labor and CRT
En de specs van de EIZO F730
CRT Size:
50 cm (19 inch) class, 90° deflection Invar Shadow Mask
CRT Phosphor Pitch:
0.26 mm/0.22 mm (horizontal)
CRT Surface Treatment:
SuperErgoCoat®
Scanning Frequency:
H: 30 - 115 kHz V: 50 - 160 Hz
Input Signals:
RGB Analog
Input Terminal:
D-Sub mini 15 pin
Active Display Size:
363 mm (H) x 271 mm (V) (Diagonal: 453 mm)
1280 dots x 1024 lines flicker-free at 107 Hz (max) (1600 dots x 1200 lines at 92 Hz addressable)
Screen Control:
ScreenManager® & ScreenManager Pro, One Touch Auto Adjustment Function (Auto-Sizing)
Power Management System:
VESA DPMS
Power Consumption:
120 watts
Power Save Mode 1:
Less than 10 watts
Power Save Mode 2 (Off):
Less than 3 watts
Plug & Play1 DDC 1/2B
Dimensions:
452 mm (W) x 455 mm (H) x 478 mm (D)
Net Weight:
22.8 kg
Certifications and Standards:
TCO'99, TÜV/Ergonomics, TÜV/GS, CE, CB, UL 1950, CSA C22.2 No.950, FCC-B, Canadian ICES-003-B, TUV/S, VCCI-B, EPA ENERGY STAR® Program, Energy 2000
w00t
  • FireStarter
Wat ik dus wil vragen heeft iemand wat gedetaileerdere refresh rates zoals bij een iiyama monitor word gegeven:
Iiyama vision master pro 451
640 x 480 @ 180Hz refresh
800 x 600 @ 180Hz refresh
1024 x 768 @ 142Hz refresh
1152 x 864 @ 126Hz refresh
1280 x 1024 @ 107Hz refresh
1600 x 1200 @ 92Hz refresh
1800 x 1440 @ 77Hz refresh
weet iemand die te vinden? want op beide sites worden maar 2 resoluties gegeven :?
Wat mij opvalt is dat de sony bij 1280x1024@85Hz draait en die iiyama [die 200 piek goedkoper is] @107Hz daarop kan draaien. En die Eizo heeft dezelfde refresh rates, waar betaal je dan voor?
w00t
