Mislukte cd's..... bij 97% ongeveer kapt het ermee
  • 372 views sinds 30-01-2008
Ik krijg nu telkens als ik een cd bak deze error:
[img]removed on req[/img]
Daarvoor had ik het niet, maar nu ineens wel ook als ik een andere cd wil maken.
Dit is het logfile.
Renko
Windows 98 4.90 (ME)
WinAspi: File 'Wnaspi32.dll': Ver=1, 0, 0, 0, size=36864 bytes, created 8-6-2000 17:00:00
Nero Version: 5.5.1.8
Recorder: <PHILIPS PCRW804> Version: 2.0 - HA 0 TA 1 - 5.5.1.8
Adapter driver: <ESDI_506> HA 0
Drive buffer : 2048kB
CD-ROM: <AOpen 12X DVD-ROM/ASH>Version: R22 - HA 0 TA 0 - 5.5.1.8
AOpen 12X DVD-ROM/ASH (Target 0, G:): Autoinsert On, DMA Off, Disconnect ?, SyncDataXfer ?
PHILIPS PCRW804 (Target 1, H:): Autoinsert On, DMA Off, Disconnect ?, SyncDataXfer ?
CmdQueuing : 1
CmdNotification: 2
WriteBufferSize: 20971520 (0) Byte
ShowDrvBufStat : 0
EraseSpeed : 0
BUFE : 0
Physical memory : 127MB (130496kB)
Free physical memory: 17MB (17680kB)
Memory in use : 77 %
Uncached PFiles: 0x0
Use Static Write Speed Table: 0
Use Inquiry: 1
Wizard: Off
CD-ROM (ISO)
1.7.2001
12:41:49#1 Text 0 File Writer.cpp, Line 125
Writer PCRW804 running
12:41:51#2 Text 0 File Burncd.cpp, Line 1497
Recorder: PHILIPS PCRW804;
CDR code: 00 97 28 12; OSJ entry from: GIGASTORAGE CORPORATION
ATIP Data:
Special Info [hex] 1: F0 00 80, 2: 61 1C 0C (LI 97:28.12), 3: 4F 21 00 (LO 79:33.00)
Additional Info [hex] 1: 00 00 00 (invalid), 2: 00 00 00 (invalid), 3: 00 00 00 (invalid)
12:41:51#3 Text 0 File ThreadedTransferInterface.cpp, Line 800
Prepare recorder PCRW804 for write in raw writing
DAO infos:
MCN:
TOCTYPE: 0x20 Close CD
Tracks 1 to 1:
TRM_DATA_ULTRARAW_MODE2, 2368/0x4, ISRC "", FilePos 0 355200 781736000
12:41:51#4 Text 0 File ThreadedTransferInterface.cpp, Line 665
Setup items (after recorder preparation)
0: TRM_DATA_MODE2_2336 (CTransferItem)
2 indices, index0 (150) not provided
original CD pos #0 + 329975 (329975) = #329975/73:19.50
relocatable, CD pos for caching/writing not required/required, no patch infos
-> TRM_DATA_ULTRARAW_MODE2, 2368, config 0x4, wanted index0 0 blocks, length 329975 blocks [PCRW804 ]
12:41:51#5 Phase 24 File dlgbrnst.cpp, Line 1372
Start of caching files
12:41:51#6 Phase 25 File dlgbrnst.cpp, Line 1372
Caching files completed
12:41:51#7 Phase 36 File dlgbrnst.cpp, Line 1372
Start of burnprocess at 8x (1200 KB/s)
12:41:51#8 Text 0 File ThreadedTransferInterface.cpp, Line 1836
Verifying CD position of item 0 (relocatable, CD pos, no patch infos, orig at #0): write at #0
12:51:24#9 SCSI -1061 File Cdrdrv.cpp, Line 1392
SCSI Exec, HA 0, TA 1, LUN 0, buffer 0x03662F7C
Status: 0x04 (0x01, SCSI_ERR)
HA-Status 0x00 (0x00, OK)
TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND)
Sense Key: 0x04 (KEY_HARDWARE_ERROR)
Sense Code: 0x44
Sense Qual: 0x85
CDB Data: 0x2A 0x00 0x00 0x04 0xF7 0x4A 0x00 0x00 0x19 0x00 0x00 0x00
Sense Data: 0xF0 0x00 0x04 0x00 0x04 0xF4 0x4F 0x13
0x00 0x00 0x00 0x00 0x44 0x85
12:51:24#10 mmc -1061 File Writer.cpp, Line 311
Internal target failure
12:51:24#11 Text 0 File ThreadedTransfer.cpp, Line 218
all writers idle, stopping conversion
12:51:28#12 Phase 38 File dlgbrnst.cpp, Line 1372
Burnprocess failed at 8x (1200 KB/s)
12:51:28#13 Text 0 File Scsicmd.cpp, Line 371
SCSI not using temporary buffers
20 out of 20 temporary buffers allocated
Existing drivers:
File 'IoSubSys\SCSI1HLP.VXD': Ver=4.90.3000, size=19278 bytes, created 8-6-2000 17:00:00
File 'IoSubsys\NEROCD95.VXD': Ver=4, 0, 0, 16, size=33451 bytes, created 10-6-2001 11:03:22
File 'IoSubsys\CDR4VSD.VXD': Ver=2.5 (093), size=197984 bytes, created 10-6-2001 12:43:44
File 'IoSubsys\CDUDF.VXD': Ver=3.01d (182S3), size=63877 bytes, created 10-6-2001 12:45:22
File 'IoSubsys\CDUDFRW.VXD': Ver=3.01d (177), size=151807 bytes, created 29-6-2000 3:01:00
File 'IoSubsys\CDRPWD.VXD': Ver=3.01d (177), size=48647 bytes, created 29-6-2000 3:01:00
File 'IoSubsys\CDFS.VXD': Ver=4.90.3000, size=59141 bytes, created 8-6-2000 17:00:00
File 'IoSubsys\ESDI_506.PDR': Ver=4.90.3000, size=25365 bytes, created 8-6-2000 17:00:00
File '..\System32\Drivers\1394bus.sys': Ver=4.90.3000.1, size=44240 bytes, created 8-6-2000 17:00:00
File '..\System32\Drivers\Ohci1394.sys': Ver=4.90.3000.1, size=49488 bytes, created 8-6-2000 17:00:00
File '..\System32\Drivers\Sbp2port.sys': Ver=4.90.3000.1, size=36336 bytes, created 8-6-2000 17:00:00
File 'IoSubsys\Disktsd.vxd': Ver=4.90.3000, size=18663 bytes, created 8-6-2000 17:00:00
File 'IoSubsys\ElbyCDIO.vxd': Ver=3, 1, 2, 5, size=13587 bytes, created 6-4-2001 13:44:02
Weet iemand hoe ik dit kan verhelpen?
Want die cd's kosten me veel te veel om zomaar een zooi te laten mislukken :r
Even je serial weggepoetst :)
[ Voor 0% gewijzigd door Xandrios op 23-12-2007 15:26 ]
Eeh, je hebt een Philips brander zo te zien, mag ik vragen hoe oud deze is? Lijkt wel een melding van een hardwarematige fout...
Hij is 2 weken oud....
dit heb ik nog nooit eerder gehad.
  • a casema user
  • Laatst online: 11-09 10:39
gebeurt dit ook op lagere brandsnelheden en met andere typen CDr's ?
Taaaa taa taa taaaa taa taa ta taaataaaaa.
  • Xandrios
  • Laatst online: 13-09 14:47
ik had laatst ook een vage error: "scsi target error"
Ook onder nero 5.5
maar dat heb ik kunnen verhelpen door nero opnieuw te installen. :)
Is het niet zo dat je probeert teveel op je cdr te branden ?
of anders is je cdrw miss gewoon kapot.. :(
Het is geen cdrw nee. Anders kan het me niet veel schelen, nu als het mislukt kost het 2 piek per cd.
En te veel erop... mha, nee, 670MB moet kunnen op een 700MB ding. is me vaker gelukt.
Tja... Nero zal ik opnieuw installeeren en hopen dat het over gaat! :)
  • bjck
  • Laatst online: 03-01 20:09
Hebbik ook vaak gehad met nero en 4speed philips .. opeens rare error's en geen cd meer goed. Format C: --> setup.exe en nero eropnieuw op en het was over :)
Of alleen Nero opnieuw installen ook helpt weet ik niet zeker .. maar voordat je terug gaat naar de winkel zou ik je pc is opnieuw formateren .. en windows opnieuw installen .. hiep bij mij altijd :)
(nu iig Lite-on zonder problemen)
Een onderschrift moet altijd zinvol zijn.
Net Nero opnieuw erop gezet.
Een cdrw ging wel goed.
Die tip van format c:\
ja... ik ga windows er wel opnieuw opzetten voor de zekerheid, had nog meer probleemnpjes mee en was het zowieso van plan.
Bedankt voor de tips! :)
Tsja, als je nu ook nog een philips wilt kopen..... Heb je hem zeker voor niks gehad :)
  • Neman
  • Laatst online: 30-08 12:47
Neman
Een uit de lucht gegrepen naam
Op zondag 01 juli 2001 16:17 schreef Renko het volgende:
KRIJG NOU EEN KUT!!!
WINDHOOS EROPNIEUW OPGEZET... EN WEER HET ZELFDE!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
AAAAAAH!!!!
En dat ding is maar 3 weken oud of 2 weet ik veel.
gelukkig 3 jaar garantie... maar die cd's die verpest zijn mot ik ook terug.
vuile gasten, kappote cdbranders geven!
Juist, ik ben erg boos!
Je hoeft niet zo te schreeuwen! Wat moeten wij hier nou mee?! Hele forum wordt vervuild met deze onzin :r
  • Xandrios
AAAAAAH!!!!
doe ff normaal man !
die paar cd's die je vern**kt hebt, boeie
je zal die brander wel voor heeeel weinig hebben gekregen, anders neem je toch ook geen philips...
enne, ik heb laatst ook nog iets van 15 cd's vern**kt, omdat mijn acer brander kapot was...
gewoon die philips ruilen voor een lite on ofzo :)
mzzl
  • dhm00
  • Laatst online: 21-08 21:37
Ik heb ook een Philips 804 8x4x32
Het zelfde probleem gehad de brander werkt niet lekker met 80min CD's probeer die cd tot en met 640MB te branden dan heb je geen Problemen....
Dus een 700MB CD Branden tot 640MB dan lukt elke CD en Nero werkt ook niet mee met Philips ,erg rot allemaal maar ja lekker goedkoop he :)
  • Kaj.
Kaj.
1 LED is niet genoeg
Aangezien dit toch een hardwareprobleem blijkt, is deze van SA naar OM gegooid.
  • eymey
  • Laatst online: 23:46
Tsja, heb zelf ooit een Philips 3610 gehad. Lekker apparaatje, brandde altijd goed, lekker degelijk :)
Totdat de problemen begonnen met power calibration errors en cd's die mislukken nadat ze een goede 1 cm. gebrand zijn. :( :( :(.
Helaas, maar Philips bakt er met cd-writers bedroevend weinig van.
Marstek Venus 5.12kWh v154, CT002 V118, CT003 V118 DSMR5.5, PV 11xEnphase IQ7+ Z-O, 5xEnphase IQ7+ N-W - ~4,7Wp theoretisch, ~3,5Wp praktijk.
  • Flake
  • Laatst online: 01-11-2024
SONiCB00M's guide naar werkende CD's
© 2001 - SONiCB00M
  • Zet alle virusscanners/background processes uit tijdens het branden!
  • Gooi je internet verbinding eruit!
  • Geen MP3's
  • Zorg voor een gedefragmenteerde HD
All rights reserveed
Die zit een beetje verkeerd hiero, maar je weet maar nooit :). Maare, probeer es CloneCD met de optie "Power calibration on"
Desnoods op lagere speed, omdat je zei dat CDRW wel werkte.
  • Kev0867
  • Laatst online: 12-12-2020
koop dan een lite-on burnproof en klaar ben je.......
