I am planning to install the NEST Learning Thermostat in my living room that is heated via a radiant floor. The upstair floors are heated through hot water radiators that have clearly a shorter time response than the radiant floor in the living room. I am not sure how to equalise temperature in the house and which target temperature to specify in the NEST thermostat. Also, I am not sure which kind of heating system settings shall I select on the NEST thermostat (floor heating or radiator).
Anyone having a similar configuration? Any suggestion to get a comfortable uniform temperature in the house?
Thank you in advance
Luca
