Hoe dom is SMART?
  • Olaf van der Spek
Ik heb een server met twee HDDs in een RAID 1 array en volgens mij is (minimaal) een van de schijven aan het doodgaan..
Maar SMART zegt volgens mij niks, mis ik iets of werkt SMART gewoon niet?
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
144
145
146
147
148
149
150
151
152
153
154
155
156
157
158
159
160
161
162
163
164
165
166
167
168
169
170
171
172
173
174
175
176
177
178
179
180
181
182
183
184
185
186
187
188
189
190
191
192
193
194
195
196
197
198
199
200
201
202
203
204
205
206
207
208
209
210
211
212
213
214
215
216
This is an automatically generated mail message from mdadm
A DegradedArray event had been detected on md device /dev/md1.
Faithfully yours, etc.
P.S. The /proc/mdstat file currently contains the following:
Personalities : [raid1]
md2 : active raid1 sda2[0] sdb2[1]
      955260864 blocks [2/2] [UU]
md1 : active raid1 sda1[2](F) sdb1[1]
      20971456 blocks [2/1] [_U]
unused devices: <none>
# smartctl -a /dev/sda
smartctl 6.4 2014-10-07 r4002 [x86_64-linux-3.16.0-4-amd64] (local build)
Copyright (C) 2002-14, Bruce Allen, Christian Franke, www.smartmontools.org
=== START OF INFORMATION SECTION ===
Model Family:     Toshiba 3.5" HDD DT01ACA...
Device Model:     TOSHIBA DT01ACA100
Serial Number:    13OWMKRFS
LU WWN Device Id: 5 000039 ff2e8be7f
Firmware Version: MS2OA750
User Capacity:    1,000,204,886,016 bytes [1.00 TB]
Sector Sizes:     512 bytes logical, 4096 bytes physical
Rotation Rate:    7200 rpm
Form Factor:      3.5 inches
Device is:        In smartctl database [for details use: -P show]
ATA Version is:   ATA8-ACS T13/1699-D revision 4
SATA Version is:  SATA 3.0, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is:    Wed Nov 23 15:10:16 2016 CET
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
=== START OF READ SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
General SMART Values:
Offline data collection status:  (0x84) Offline data collection activity
                                        was suspended by an interrupting command from host.
                                        Auto Offline Data Collection: Enabled.
Self-test execution status:      (   0) The previous self-test routine completed
                                        without error or no self-test has ever
                                        been run.
Total time to complete Offline
data collection:                ( 7410) seconds.
capabilities:                    (0x5b) SMART execute Offline immediate.
                                        Auto Offline data collection on/off support.
                                        Suspend Offline collection upon new
                                        command.
                                        Offline surface scan supported.
                                        Self-test supported.
                                        No Conveyance Self-test supported.
                                        Selective Self-test supported.
SMART capabilities:            (0x0003) Saves SMART data before entering
                                        power-saving mode.
                                        Supports SMART auto save timer.
Error logging capability:        (0x01) Error logging supported.
                                        General Purpose Logging supported.
Short self-test routine
recommended polling time:        (   1) minutes.
Extended self-test routine
recommended polling time:        ( 124) minutes.
SCT capabilities:              (0x003d) SCT Status supported.
                                        SCT Error Recovery Control supported.
                                        SCT Feature Control supported.
                                        SCT Data Table supported.
SMART Attributes Data Structure revision number: 16
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME          FLAG     VALUE WORST THRESH TYPE      UPDATED  WHEN_FAILED RAW_VALUE
  1 Raw_Read_Error_Rate     0x000b   087   087   016    Pre-fail  Always       -       99
  2 Throughput_Performance  0x0005   141   141   054    Pre-fail  Offline      -       72
  3 Spin_Up_Time            0x0007   129   129   024    Pre-fail  Always       -       178 (Average 178)
  4 Start_Stop_Count        0x0012   100   100   000    Old_age   Always       -       13
  5 Reallocated_Sector_Ct   0x0033   077   077   005    Pre-fail  Always       -       589
  7 Seek_Error_Rate         0x000b   100   100   067    Pre-fail  Always       -       0
  8 Seek_Time_Performance   0x0005   118   118   020    Pre-fail  Offline      -       33
  9 Power_On_Hours          0x0012   096   096   000    Old_age   Always       -       31584
 10 Spin_Retry_Count        0x0013   100   100   060    Pre-fail  Always       -       0
 12 Power_Cycle_Count       0x0032   100   100   000    Old_age   Always       -       13
192 Power-Off_Retract_Count 0x0032   100   100   000    Old_age   Always       -       25
193 Load_Cycle_Count        0x0012   100   100   000    Old_age   Always       -       25
194 Temperature_Celsius     0x0002   214   214   000    Old_age   Always       -       28 (Min/Max 15/43)
196 Reallocated_Event_Count 0x0032   076   076   000    Old_age   Always       -       604
197 Current_Pending_Sector  0x0022   100   100   000    Old_age   Always       -       0
198 Offline_Uncorrectable   0x0008   100   100   000    Old_age   Offline      -       0
199 UDMA_CRC_Error_Count    0x000a   200   200   000    Old_age   Always       -       0
SMART Error Log Version: 1
No Errors Logged
SMART Self-test log structure revision number 1
Num  Test_Description    Status                  Remaining  LifeTime(hours)  LBA_of_first_error
# 1  Short offline       Completed without error       00%      1725         -
# 2  Short offline       Completed without error       00%      1720         -
# 3  Short offline       Completed without error       00%      1720         -
# 4  Short offline       Completed without error       00%         7         -
# 5  Short offline       Completed without error       00%         2         -
# 6  Short offline       Completed without error       00%         2         -
SMART Selective self-test log data structure revision number 1
 SPAN  MIN_LBA  MAX_LBA  CURRENT_TEST_STATUS
    1        0        0  Not_testing
    2        0        0  Not_testing
    3        0        0  Not_testing
    4        0        0  Not_testing
    5        0        0  Not_testing
Selective self-test flags (0x0):
  After scanning selected spans, do NOT read-scan remainder of disk.
If Selective self-test is pending on power-up, resume after 0 minute delay.
# smartctl -a /dev/sdb
Serial Number:    13OWXZTGS
LU WWN Device Id: 5 000039 ff2e8e1dd
Local Time is:    Wed Nov 23 15:10:21 2016 CET
                                        been run.
data collection:                ( 7264) seconds.
                                        command.
                                        power-saving mode.
recommended polling time:        ( 121) minutes.
  1 Raw_Read_Error_Rate     0x000b   100   100   016    Pre-fail  Always       -       0
  3 Spin_Up_Time            0x0007   127   127   024    Pre-fail  Always       -       181 (Average 179)
  5 Reallocated_Sector_Ct   0x0033   100   100   005    Pre-fail  Always       -       0
  9 Power_On_Hours          0x0012   096   096   000    Old_age   Always       -       31583
192 Power-Off_Retract_Count 0x0032   100   100   000    Old_age   Always       -       29
193 Load_Cycle_Count        0x0012   100   100   000    Old_age   Always       -       29
194 Temperature_Celsius     0x0002   200   200   000    Old_age   Always       -       30 (Min/Max 15/42)
196 Reallocated_Event_Count 0x0032   100   100   000    Old_age   Always       -       0
No Errors Logged
# 1  Short offline       Completed without error       00%      1724         -
    1        0        0  Not_testing
    2        0        0  Not_testing
    3        0        0  Not_testing
    4        0        0  Not_testing
    5        0        0  Not_testing
  • TommieW
  • Laatst online: 21:03
TommieW
Numa numa.
Je moet eigenlijk niet kijken naar of SMART vindt of de disk "passed" is. Je kan beter kijken naar de waardes en aan de hand daarvan zelf bepalen of je de disk nog goed vindt.
Je eerste disk heeft 589 reallocated sectors. Dat is voor mij reden genoeg om de disk niet meer te vertrouwen.
1700X@3,9GHZ - Asus Crosshair VI Hero - 32GB Corsair LPX - GTX 1070Ti
iPhone 17 Pro Max - Macbook Pro 16" M1 Pro
  • McKaamos
McKaamos
Master of the Edit-button
TommieW schreef op woensdag 23 november 2016 @ 15:19:
Je eerste disk 589 reallocated sectors. Dat is voor mij reden genoeg om de disk niet meer te vertrouwen.
Dat wou ik ook al gaan zeggen.
Reallocated Sectors zijn altijd slecht, maar er wordt pas alarm gegeven als de grenswaarde overschreden wordt.
Sowieso is dat een waarde die alleen maar groeit en steeds meer vaart gaat maken al naar gelang er meer stuk gaan over tijd.
Bij de eerste reallocated sector mag je al vast gaan zorgen dat je de centen hebt voor en nieuwe disk.
  • jan99999
  • Laatst online: 27-09 07:48
Je software in je nas zou melding moeten geven.
In de bios moet dit aan staan en in je nas software, dan zou er alarm moeten komen.
Schijf is dus niet meer goed.
  • dcm360
dcm360
Moderator Discord
HD7767 powered
McKaamos schreef op woensdag 23 november 2016 @ 15:22:
Dat is dan ook weer overdreven. Schijven met hooguit enkele reallocated sectors kunnen vaak nog jaren zonder problemen mee. Het gevaar is meer als het aantal vlot oploopt, dat wijst er op dat er mechanisch iets mis is in de schijf en dat vervanging wel noodzakelijk is. Ook in dit geval is vervanging wel noodzakelijk, want 589 is wel meer dan enkele.
  • Olaf van der Spek
Is er in Linux ook niks dat een melding geeft als IO requests veel langer dan normaal duren?
  • McKaamos
McKaamos
dcm360 schreef op woensdag 23 november 2016 @ 16:05:
Njah ok, misschien is het iets te voorbarig, maar het is mij al te vaak overkomen dat het wel oploopt en de schijf uiteindelijk kaduuk is.
Ik vertrouw het persoonlijk gewoon niet als die teller niet meer op 0 staat.
Olaf van der Spek schreef op woensdag 23 november 2016 @ 16:08:
Ja, de terminal.
Als er rare dingen gebeuren met schijfinteracties, dan vliegt dat over je console/terminal.
Nadeel bij headless systemen is dat je dat dus nooit te zien krijgt en er een ander mechanisme aanwezig moet zijn om dergelijke meldingen kenbaar te maken.
B.v. een piepertje of mailnotificatie op een NAS.
[ Voor 28% gewijzigd door McKaamos op 23-11-2016 16:11 ]
  • Olaf van der Spek
$ cat /proc/mdstat
Device:         rrqm/s   wrqm/s     r/s     w/s    rkB/s    wkB/s avgrq-sz avgqu-sz   await r_await w_await  svctm  %util
sda               0.20  1615.40    2.40   31.80   316.80  6585.60   403.65    90.96  153.61  134.67  155.04  29.12  99.60
sdb               0.00  1615.40    4.40   57.60   138.40  6690.40   220.28     8.08  130.34   16.73  139.01   3.32  20.56
md1               0.00     0.00    3.60    0.00    32.00     0.00    17.78     0.00    0.00    0.00    0.00   0.00   0.00
md2               0.00     0.00    3.40 1680.60   374.40  6720.80     8.43     0.00    0.00    0.00    0.00   0.00   0.00
sda1 is 'down' maar sda2 is nog up. %util van sda is toch veel hoger dan sdb, duid dat er niet op dat sda veel langer over requests doet?
  • Renault
  • Laatst online: 22:19
Ik vermoed dat er geen warning komt omdat elke slechte sector succesvol is vervangen: daardoor is geen dataverlies ontstaan. Dit i.c.m. RAID1 is vermoedelijke geen warning waard.
En dat is terecht, want een NAS heeft primair een "data-availability" waarde en niet secundair een "data-storage/backup" waarde. Zolang jij je data perfect backupt op een ander medium (bv. offline opslagmedia) is er voor de NAS niets aan de hand: die loopt en liep perfect.
Mocht deze harddisk het alsnog begeven, dan prik je er een verse in, herstelt RAID1 en je draait met enige offline tijd en enige tijd met een slechte performance (tijdens rebuild) ongehinderd door zonder enig dataverlies.
Als jij je backupregime niet op orde hebt, moet je je wel zorgen maken: als je nas wordt getroffen door de bliksem, hij wordt gejat of de voeding gaat stuk en blaast allebei je harddisks op, is al je data weg.
Dus mijn mening is: niets aan de hand, maar bepaal je strategie i.r.t. datazekerheid.
  • PilatuS
McKaamos schreef op woensdag 23 november 2016 @ 16:09:
Zeker voor grote schijven is het normaal dat er af en toe wat slechte sectoren komen. Een disk die 5 of 10 slechte sectoren heeft is niet onbetrouwbaar. Zodra het echter naar de 100 of meer gaat is het een ander verhaal. Die meer dan 500 van de TS is dan ook te veel.
Renault schreef op woensdag 23 november 2016 @ 17:42:
Meer dan 500 is wel erg veel. Zodra je boven de 100 of 200 komt is de kans dat er constant nieuwe bijkomen heel groot. Je gaat dan ook vaak pending sectors krijgen en die zijn wel een probleem.
[ Voor 24% gewijzigd door PilatuS op 23-11-2016 17:49 ]
  • Guru Evi
  • Laatst online: 21-08 16:35
Sommige schijven hebben zelfs reallocated sectors uit de fabriek. Er zit een kleine 'reserve' waar oa. fabricatie fouten kunnen vervangen worden.
Als er een partitie al uit ligt en een schijf traag dan kan dit inderdaad zijn omdat er enorm veel re-reads zijn. Op mijn SAS schijven kan ik zien hoeveel precies, ik weet niet of jouw SATA schijven die ook weergeven, probeer met de smartctl knopjes te spelen om te zien of je niet meer data krijgt. Maar het duidt inderdaad op een schijf die de geest aan het geven is.
SMART geeft meestal weinig indicatie van problemen omdat er zoveel factoren zijn en een deel ervan zijn proprietary, het is moeilijk uit te rekenen dat er een probleem is. Zodra er onherstelbare problemen komen gaat SMART meestal wel een piepje geven maar zolang de schijf enkel herstelbare fouten heeft is de schijf nog 'goed' volgens de fabrikant.
Pandora FMS - Open Source Monitoring - pandorafms.org
  • jan99999
https://help.ubuntu.com/community/Smartmontools
https://askubuntu.com/que...buntu-14-04-through-16-10
Hoe je in textmode dit kunt installeren, en een mail stuurt als het fout is, zoek met google naar je linux en hoe dit kan ingesteld worden.
  • Olaf van der Spek
The following warning/error was logged by the smartd daemon:
Device: /dev/sda [SAT], Failed SMART usage Attribute: 1 Raw_Read_Error_Rate.
Device info:
TOSHIBA DT01ACA100, S/N:13OWMKRFS, WWN:5-000039-ff2e8be7f, FW:MS2OA750, 1.00 TB
Device: /dev/sda [SAT], FAILED SMART self-check. BACK UP DATA NOW!
Device info:
Smartmontools was al geinstalleerd maar deze emails heb ik niet eerder gehad.
  • Olaf van der Spek
Toch die schijf maar eens laten vervangen ;)
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
SATA Version is:  SATA 3.0, 6.0 Gb/s (current: 1.5 Gb/s)
Local Time is:    Tue Jan 17 09:10:38 2017 CET
SMART overall-health self-assessment test result: FAILED!
Drive failure expected in less than 24 hours. SAVE ALL DATA.
See vendor-specific Attribute list for failed Attributes.
                                        been run.
                                        command.
                                        power-saving mode.
  1 Raw_Read_Error_Rate     0x000b   056   056   016    Pre-fail  Always       -       543825510
  5 Reallocated_Sector_Ct   0x0033   001   001   005    Pre-fail  Always   FAILING_NOW 2005
  8 Seek_Time_Performance   0x0005   115   115   020    Pre-fail  Offline      -       34
  9 Power_On_Hours          0x0012   096   096   000    Old_age   Always       -       32898
192 Power-Off_Retract_Count 0x0032   100   100   000    Old_age   Always       -       27
193 Load_Cycle_Count        0x0012   100   100   000    Old_age   Always       -       27
194 Temperature_Celsius     0x0002   253   253   000    Old_age   Always       -       17 (Min/Max 13/43)
196 Reallocated_Event_Count 0x0032   001   001   000    Old_age   Always       -       2067
No Errors Logged
    1        0        0  Not_testing
    2        0        0  Not_testing
    3        0        0  Not_testing
    4        0        0  Not_testing
    5        0        0  Not_testing
  • rikadoo
Lijkt me idd verstandig, zijn er nu weer 1500 bij gekomen.
AMD Ryzen 7 5900x | Custom WC | ASUS ROG Strix X570-E Gaming | 32GB Corsair DDR4-3600MHz | Samsung 970 nvme 1TB | Samsung 860 EVO 2TB | AMD RX 6900XT 16GB | 1x Asus RoG XG27AQDMG | 1x LG UltraGear 27GL850
  • Olaf van der Spek
Raw_Read_Error_Rate is ook iets gestegen.. 99 -> 543825510
