[Win10] update with error 0x800F0922
  • sdk1985
  • Laatst online: 18:11
Ik krijg momenteel dagelijks dezelfde melding op een computer:
Installation Failure: Windows failed to install the following update with error 0x800F0922: Cumulative Update for Windows 10 Version 1511 for x64-based Systems (KB3156421).
- <Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
- <System>
<Provider Name="Microsoft-Windows-WindowsUpdateClient" Guid="{945A8954-C147-4ACD-923F-40C45405A658}" />
<EventID>20</EventID>
<Version>1</Version>
<Level>2</Level>
<Task>1</Task>
<Opcode>13</Opcode>
<Keywords>0x8000000000000028</Keywords>
<TimeCreated SystemTime="2016-11-21T21:11:26.235767800Z" />
<EventRecordID>12037</EventRecordID>
<Correlation />
<Execution ProcessID="984" ThreadID="5492" />
<Channel>System</Channel>
<Computer>nzxt-win10</Computer>
<Security UserID="S-1-5-18" />
</System>
- <EventData>
<Data Name="errorCode">0x800f0922</Data>
<Data Name="updateTitle">Cumulative Update for Windows 10 Version 1511 for x64-based Systems (KB3156421)</Data>
<Data Name="updateGuid">{9026B8D7-5B46-4615-B987-06C8F420FB37}</Data>
<Data Name="updateRevisionNumber">203</Data>
<Data Name="serviceGuid">{7971F918-A847-4430-9279-4A52D1EFE18D}</Data>
</EventData>
</Event>
Installation Failure: Windows failed to install the following update with error 0x80248007: Windows Malicious Software Removal Tool for Windows 8, 8.1, 10 and Windows Server 2012, 2012 R2 x64 Edition - May 2016 (KB890830).
- <System>
<Level>2</Level>
<Task>1</Task>
<Opcode>13</Opcode>
<TimeCreated SystemTime="2016-11-21T17:20:43.791102400Z" />
<EventRecordID>11924</EventRecordID>
<Correlation />
<Execution ProcessID="972" ThreadID="2408" />
</System>
- <EventData>
<Data Name="errorCode">0x80248007</Data>
<Data Name="updateTitle">Windows Malicious Software Removal Tool for Windows 8, 8.1, 10 and Windows Server 2012, 2012 R2 x64 Edition - May 2016 (KB890830)</Data>
<Data Name="updateGuid">{324CCE61-6793-4484-976C-96591B980B27}</Data>
<Data Name="updateRevisionNumber">200</Data>
</EventData>
</Event>
De pc heeft een paar maanden uitgestaan. In eerste instanties waren er ook stabiliteitsproblemen. Dat bleek echter door de nvidia driver te komen. Er zat namelijk eerst een GTX 460 in en nu een oudere GTS 250 welke alleen met de legacy driver werkt. Dat probleem is opgelost met de display driver uninstaller vanaf guru3d.com.
In dism lukte het ook niet:
C:\WINDOWS\system32>dism.exe /online /cleanup-image /restorehealth
Deployment Image Servicing and Management tool
Version: 10.0.10586.0
Image Version: 10.0.10586.0
[==========================100.0%==========================]
Error: 14093
The identity string is malformed. This may be due to a trailing comma, more than two unnamed attributes, missing attribute name or missing attribute value.
The DISM log file can be found at C:\WINDOWS\Logs\DISM\dism.log
Autofix bij " fix problems with windows update" deed ook niets. Iemand nog een suggestie?
[ Voor 22% gewijzigd door sdk1985 op 21-11-2016 22:22 ]
  • wagenveld
Build 1607 downloaden op USB:
https://www.microsoft.com/nl-nl/software-download/windows10
En opnieuw installeren.
  • sdk1985
Format C lijkt me niet echt de best passende oplossing hier...
  • Reepje
ver 1607 is een upgrade. Je zit met de oude windows 10 te kijken, is daar een reden voor?
  • sdk1985
De reden is dat het ding 6 maanden uit heeft gestaan en de updates nu weigeren.
Uit je reactie maak ik op dat je blijkbaar ook via die link een update kunt starten. In dat geval ga ik het even proberen.
  • wagenveld
Dat bedoelde ik idd ;)
  • sdk1985
In dat geval bedankt voor de tip :D .
  • Reepje
Of als het niet wil, de windows 10 upgradeassistant instaleren, die fixt de update problemen, en zal ook versie 1607 toepassen
  • sdk1985
Ik heb hem nu even lokaal gedownload en opgestart en hij zit op 76%. USB stick had ik even niet bij de hand (in ieder geval niet mijn sandisk extreme). To be continued...
  • Meg
  • Registratie: September 2016
Meg
418: “I’m a Teapot”
sdk1985 schreef op maandag 21 november 2016 @ 22:37:
Nog maar 24% te gaan, ik heb zo'n vermoeden dat het geen probleem moet geven om de upgrade uit te voeren zoals jij het hebt gedaan. ;-)
"If you lose your left arm your right arm will be left."
"The difference between stupidity and genius is that genius has its limits." - Albert Einstein
"I don't need oxygen, I only need O2."
  • sdk1985
Weet helaas niet hoe het is afgelopen. Ik heb via teamviewer de computer herstart nadat de installatie was voltooid en daarna is hij niet meer online gekomen. Morgen ga ik kijken wat voor melding er staat.
[ Voor 9% gewijzigd door sdk1985 op 22-11-2016 00:40 ]
  • Meg
Meg
418: “I’m a Teapot”
sdk1985 schreef op dinsdag 22 november 2016 @ 00:40:
Waarom doe je zo iets via Teamviewer? Dat is nooit handig omdat je dan niet alles ziet...😂
