GTX 970 Displayport. Pc start, monitor and peripherals not
  • 216 views
  • maxbulder
  • Laatst online: 23-09-2024
Pc starts, LED, HD start but mouse keyboard and monitor not (display port monitor G-Sync)
There is something wrong with the startup of my pc.
There are 2 way’s my pc stars:
1. Normal start every peripherals start.
2. Pc starts, fan’s, LED, HD start but mouse and keyboard don’t light up and my monitor won’t turn on. "There is no signal".
Fix for the second problem is; long press on the power button (force shutdown). Then restart immediately. If I do that a copple of times my pc start like normal.
I tried;
I removed my GPU, plugt HDMI in the motherboard and pc didn't start.
Reseated the GPU
Updating windows 10, Did a Display Driver Uninstaller, Checked for updates in Nvidia Geforce, Updated Motherboard and CPU
Clear BIOS
USB only work with my External HD, Mic and music mixer. Mouse and keyboard don't work on any USB.
Do you guy’s have a solution to just start my pc in a normal way?
About PC:
PC: partpicker link: http://pcpartpicker.com/user/TheOfficialMax/saved/8XhJ7...
CPU: Intel Core i7-3770K 3.5GHz Quad-Core Processor
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler
Thermal Compound: Gelid Solutions GC-Extreme 3.5g Thermal Paste
Motherboard: MSI Z77A-G45 ATX LGA1155 Motherboard
Memory: Corsair Vengeance 16GB (4 x 4GB) DDR3-1600 Memory
Storage: Intel 520 Series Cherryville 120GB 2.5" Solid State Drive
Storage: Samsung 850 Pro Series 128GB 2.5" Solid State Drive
Storage: Seagate Barracuda Green 2TB 3.5" 5900RPM Internal Hard Drive
Video Card: MSI GTX 970 Gaming 4G
Case: NZXT S340 (White) ATX Mid Tower Case
Power Supply: Corsair 650W 80+ Gold Certified Fully-Modular ATX Power Supply
Operating System: Microsoft Windows 10 Home OEM (64-bit)
Case Fan: be quiet! Pure Wings 2 61.2 CFM 140mm Fan
Keyboard: Razer Blackwidow Ultimate 2014 Wired Gaming Keyboard
Mouse: Razer Razer Naga 2013 Wired Laser Mouse
Headphones: Audio-Technica M50x Headphones
Monitor: Acer Predator XB270H (1920 x 1080, 144Hz, 1ms, TN)
Speakers: Behringer MS16 Active Digital Monitors
NZXT Grid+ Fan Controler
DIY Led stip, with a molex connector solder job to the LED box
Microphone: Samson Meteor
Mousemat: Corsair Gaming MM200 Extended Edition
Audio Mixer: Behringer XENYX 302USB
  • br00ky
  • Laatst online: 23:24
br00ky
Op tweakers gaan we altijd uit van eigen inzet. Als ik dan in Linustech dezelfde tekst tegenkomen en je gewoon Nederlands spreekt komt dat wel erg gemakkelijk over hier. Dicht bij gebrek aan eigen inzet.
