  • Bunyamin
  • Registratie: Maart 2014
  • Laatst online: 27-11 00:41
Dear Community,
I have been messing around with my Plex Client and Server for a while now but I did not manage to solve this specific problem I am experiencing, maybe u guys recognize this and can help me out or suggest an alternative.
My setup:
Plex Server Synology Server
Plex Client Android TV box with LolliPop 5.1 OS (Tronsmart R68 with Octa-Core RockChip)
Plex Client is connected to an AV Receiver which supports DD, DD+ and DTS-HD .
Plex Client settings are defined configuration:
Video:
Video quality over wifi original
Audio boost - no
Device supports Dolby digital, plus, & DTs - yes
Burn subtitles - automatic
Advanced - use android media player - yes
Advanced:
Direct stream - yes
Direct play - auto
H264 max - 5.1
Use external player - no
The issue:
When I turn on subtitles (mostly .SRT but other files like .SPG don't work either) in the Plex Client the movies shortens to 01:08:16 (Doesn't matter what kind of extension it has) see red markings in screenshot.
https://15254b2dcaab7f547...ditor/do/41j8fkpb1yof.png
https://15254b2dcaab7f547...ditor/fx/74pdu7n16pkf.png
But when I turn the subtitles off the movies returns to its original length and I am not having any playback issues, see screenshot.
https://15254b2dcaab7f547...ditor/hm/xhp5uy14pcbb.png
https://15254b2dcaab7f547...ditor/2g/7dr7hrk8gdxn.png
Notes:
  1. The main reason for using the 'android media player' is because my AV Receiver recognizes the DD, DD+ and DTS-HD sounds directly. (Android TV Box sound management is set to HDMI Bitstream)
  2. When I turn off DD, DD+ and DTS-HD and 'use android media player" in the client settings it work fine, but my AV Receiver doesn't recognize the DD, DD+ and DTS-HD that is played from the Plex Player.
  3. I did experiemt with other players on the android like MX Player but that has the same effect as playing it from the Plex Player
Thanks in advance for the replies!
  • Koffie
  • Laatst online: 06:18
Koffie
Koffiebierbrouwer
Braaimeneer
Sorry, dit is een Nederlands forum waar we ook gewoon in het Nederlands posten.
Daarnaast heeft dit probleem niets met Netwerken te maken maar met de Plex software.
Graag een nieuw topic in het Nederlands in het juiste forum plaatsen.
Braaikamer - Smoke&BBQ - Huis
