Snapraid maakt sync niet af?
  • sdk1985
  • Laatst online: 20:08
Ik ben voor het eerst een snapraid aan het opzetten. Ik heb hiervoor de GUI tool Elucidate gebruikt. In eerste instantie heb ik één folder op de C schijf gedaan. Dat ging prima, recoveren ook.
Nu heb ik hem vannacht twee oudere harde schijven in een pool laten zetten. Echter op 27% is hij ermee opgehouden.
2016-09-20 06:14:10.0102[6] INFO Elucidate.Elucidate: StdOut[27%, 886740 MB, 183 MB/s, CPU 2%, 3:33 ETA          ]
2016-09-20 06:14:48.4518[11] INFO Elucidate.Elucidate: Exited.
2016-09-20 06:14:48.9674[6] INFO Elucidate.Elucidate: StdOut[27%, 886881 MB, 183 MB/s, CPU 2%, 3:33 ETA          ]
2016-09-20 06:14:49.4519[11] INFO Elucidate.Elucidate: ExitCode=[-1073741790]
2016-09-20 06:14:49.4519[11] INFO Elucidate.Elucidate: We are exiting the status thread
2016-09-20 06:14:49.4519[1] INFO Elucidate.Elucidate: Completed
Config is niks bijzonders
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
# Configuration for snapraid via Elucidate
# Defines the file to use as Parity storage
# It must NOT be in a data disk
parity z:\parity\SnapRAID.parity
# Defines the file to use as Q-Parity storage
# If specified, it enables a double failures protection like RAID6
#q-parity F:\qar\q-parity\SnapRAID.Q.parity
# Defines the file to use as content list
# You can use multiple specification to store more copies of the file
# It's suggested to have at least N+1 copies of the file, where N is the number of parity files.
# It can be in a data disk
# It can be in the disks used for parity storage
content G:\SnapRAID.content
content H:\SnapRAID.content
content z:\parity\SnapRAID.content
# Defines the data disks to use
# The order is relevant for parity, do not change it
disk d0 G:\
disk d1 H:\
# Excludes hidden files and directories (uncomment to enable).
# nohidden
# Defines files and directories to exclude
# Remember that all the paths are relative at the mount points
# Format: "exclude FILE"
# Format: "exclude DIR\"
# Format: "exclude \PATH\FILE"
# Format: "exclude \PATH\DIR\"
exclude \$RECYCLE.BIN\
exclude \System Volume Information\
exclude *.bak
exclude Thumbs.db
# Defines the block size in kibi bytes (1024 bytes).
# Default value is 256 -> 256 kibi bytes -> 262144 bytes
block_size 256
# Automatically save the state when synching after the specied amount of GiB processed.
# This option is useful to avoid to restart from scratch long 'sync'
# commands interrupted by a machine crash.
# The SIZE argument is specified in gibi bytes -> 1073741824 bytes
# Default value is 0, meaning disabled.
# Format: "autosave SIZE_IN_GiB"
autosave 250
Systeem heeft 8 GB ram, doelschijven zijn 1 en 2 TB. Parity disk is 8TB.
Op de error code kon ik niets vinden. Iemand enig idee wat ik nu moet doen?
[ Voor 36% gewijzigd door sdk1985 op 20-09-2016 15:11 ]
  • sdk1985
Update:
Nog eens op sync gedrukt:
2016-09-20 15:08:29.8353[10] DEBUG Elucidate.Elucidate: actionWorker_DoWork
2016-09-20 15:08:29.8353[10] INFO Elucidate.Elucidate: Using: "C:\snapraid\snapraid.exe"
2016-09-20 15:08:29.8353[10] INFO Elucidate.Elucidate: with:  -c "C:\snapraid\snapraid2.conf" sync
2016-09-20 15:08:29.8353[10] ERROR Elucidate.Elucidate: Thread closing abnormally System.ComponentModel.Win32Exception (0x80004005): The system cannot find the file specified
   at System.Diagnostics.Process.StartWithCreateProcess(ProcessStartInfo startInfo)
   at Elucidate.Elucidate.actionWorker_DoWork(Object sender, DoWorkEventArgs e)
2016-09-20 15:08:29.8473[10] INFO Elucidate.Elucidate: We are exiting the status thread
2016-09-20 15:08:29.8473[1] ERROR Elucidate.Elucidate: Thread threw:  System.ComponentModel.Win32Exception (0x80004005): The system cannot find the file specified
   at System.ComponentModel.BackgroundWorker.OnDoWork(DoWorkEventArgs e)
   at System.ComponentModel.BackgroundWorker.WorkerThreadStart(Object argument)
De snapraid.exe is dus verdwenen 8)7 .
Na even zoeken bleek Norton hem te hebben verwijderd. Ik heb dit nu opgelost (en snapraid.exe aan de exception list toegevoegd). Echter het lukt me nog niet om het proces voor te zetten.
-09-20 15:11:24.2451[10] INFO Elucidate.Elucidate: StdOut[Using 351 MiB of memory for the FileSystem.]
2016-09-20 15:11:26.2455[10] INFO Elucidate.Elucidate: StdOut[Initializing...]
2016-09-20 15:11:26.4276[7] WARN Elucidate.Elucidate: Verbose[WARNING! The Parity file z:/parity/SnapRAID.parity has data only 0 blocks instead of 1430511.]
2016-09-20 15:11:26.4276[7] WARN Elucidate.Elucidate: Verbose[DANGER! One or more the parity files are smaller than expected!]
2016-09-20 15:11:26.4276[7] WARN Elucidate.Elucidate: Verbose[It's possible that the parity disks are not mounted.]
2016-09-20 15:11:26.4276[7] WARN Elucidate.Elucidate: Verbose[If instead you are adding a new parity level, you can 'sync' using]
2016-09-20 15:11:26.4276[7] WARN Elucidate.Elucidate: Verbose['snapraid --force-full sync' to force a full rebuild of the parity.]
2016-09-20 15:11:26.4516[3] INFO Elucidate.Elucidate: Exited.
2016-09-20 15:11:27.4526[13] INFO Elucidate.Elucidate: ExitCode=[1]
2016-09-20 15:11:27.4526[13] INFO Elucidate.Elucidate: We are exiting the status thread
2016-09-20 15:11:27.4526[1] INFO Elucidate.Elucidate: Completed
Zo ver ik heb begrepen moet de auto-save ervoor zorgen dat je het in delen kunt doen. Het parity bestand is echter slechts 147MB. Uit de status bleek dat 886881 MB was verwerkt = 3x 250 GB. Vreemd!
  • Outerspace
  • Laatst online: 22:32
Outerspace
Admin General Chat
Gebruik je het op een professionele manier of is dit voor thuis? Indien het laatste, kan je de virusscanner eens helemaal uitschakelen? Ik heb negatieve ervaringen met Norton en het cancelen van bepaalde threads van applicaties.
Over parity:
https://sourceforge.net/p.../1677233/thread/af415eed/
[ Voor 16% gewijzigd door Outerspace op 20-09-2016 15:18 ]
Wauw, een sig!
  • sdk1985
Ik gebruik het thuis voor mijn privé NAS (zakelijk is uitbesteed aan het datacenter):
#ProductPrijsSubtotaal
1Intel Pentium G4400 Boxed€ 56,-€ 56,-
1ASRock Z170 Pro4€ 116,-€ 116,-
1Samsung Spinpoint F1 HD103UJ, 1TB€ 0,-€ 0,-
1Samsung Spinpoint F3 HD103SJ, 1TB€ 0,-€ 0,-
1Samsung Spinpoint F4 EcoGreen HD155UI, 1,5TB€ 0,-€ 0,-
1Seagate Archive HDD v2 ST8000AS0002, 8TB€ 260,-€ 260,-
1Seagate Desktop HDD, 3TB€ 94,95€ 94,95
1Seagate NAS HDD, 8TB€ 314,60€ 314,60
1be quiet! Silent Base 800 Zwart/Oranje€ 120,-€ 120,-
1Cooler Master TX3 i€ 19,95€ 19,95
1Kingston HyperX Fury black HX424C15FBK2/8€ 44,95€ 44,95
1Cooler Master V Series V550€ 90,95€ 90,95
Bekijk collectie
Importeer producten
Totaal€ 1.117,40
Ik ga eerst even kijken of de exclude helpt (heb de hele snapraid map in exclude van SONAR gezet). Werkt dat niet dan probeer ik het nog een keer zonder Norton. Ik zie in ieder geval al direct een groot verschil: Het .parity bestand is nu direct 1.5 TB, dat was 0 KB. Alleen het .content bestand was gisteren gevuld.
Over een uurtje of 6 zou het geheel klaar moeten zijn. Ik zie dat het vooral de 2 TB ecogreen schijf is die de boel ophoudt. De 8 TB Archive hdd is slechts 25% belast (parity disk) en de 1 TB spinpoint komt weg met circa 50% belasting. Maar goed, de totale snelheid van 144 MB/s is nog wel te overzien.
[ Voor 155% gewijzigd door sdk1985 op 20-09-2016 15:37 ]
  • sdk1985
Zo het is gelukt
2016-09-20 20:02:14.4204[5] INFO Elucidate.Elucidate: StdOut[100% completed, 2313783 MB processed in 4:40]
2016-09-20 20:02:16.6237[5] INFO Elucidate.Elucidate: StdOut[     d0 63% | **************************************]
2016-09-20 20:02:16.6237[5] INFO Elucidate.Elucidate: StdOut[     d1 34% | ********************]
2016-09-20 20:02:16.6237[5] INFO Elucidate.Elucidate: StdOut[ parity  0% | ]
2016-09-20 20:02:16.6237[5] INFO Elucidate.Elucidate: StdOut[   raid  0% | ]
2016-09-20 20:02:16.6237[5] INFO Elucidate.Elucidate: StdOut[   hash  1% | ]
2016-09-20 20:02:16.6237[5] INFO Elucidate.Elucidate: StdOut[  sched  0% | ]
2016-09-20 20:02:16.6237[5] INFO Elucidate.Elucidate: StdOut[   misc  0% | ]
2016-09-20 20:02:16.6237[5] INFO Elucidate.Elucidate: StdOut[            |______________________________________________________________]
2016-09-20 20:02:16.6237[5] INFO Elucidate.Elucidate: StdOut[                           wait time (total, less is better)]
2016-09-20 20:02:16.7331[5] INFO Elucidate.Elucidate: StdOut[Everything OK]
2016-09-20 20:02:16.7487[5] INFO Elucidate.Elucidate: StdOut[Saving state to G:/SnapRAID.content...]
2016-09-20 20:02:16.7487[5] INFO Elucidate.Elucidate: StdOut[Saving state to H:/SnapRAID.content...]
2016-09-20 20:02:16.7487[5] INFO Elucidate.Elucidate: StdOut[Saving state to z:/parity/SnapRAID.content...]
2016-09-20 20:02:30.6130[5] INFO Elucidate.Elucidate: StdOut[Verifying G:/SnapRAID.content...]
2016-09-20 20:02:30.6130[5] INFO Elucidate.Elucidate: StdOut[Verifying H:/SnapRAID.content...]
2016-09-20 20:02:30.6130[5] INFO Elucidate.Elucidate: StdOut[Verifying z:/parity/SnapRAID.content...]
2016-09-20 20:02:31.0192[7] INFO Elucidate.Elucidate: Exited.
2016-09-20 20:02:32.0194[7] INFO Elucidate.Elucidate: ExitCode=[0]
2016-09-20 20:02:32.0194[7] INFO Elucidate.Elucidate: We are exiting the status thread
2016-09-20 20:02:32.0194[1] INFO Elucidate.Elucidate: Completed
Recovery ook getest door een map van 2 GB te verwijderen. Binnen een minuut had hij hem teruggezet, indrukwekkend.
  • ari2asem
  • Laatst online: 05-10 00:36
misschien domme vraag....hoe start jij die gui? gewoon op een EXE dubbelklik?
want ik kan nergens een EXE vinden in het zip-file van elucidate....en trouwens....elucidate is niet meer met snapraid v11 compatible. wel met versie 10 van snapraid. omdat een en ander in snapraid v11 flink veranderd is.
verder is snapraid een geweldige programma, als je met commands en filters kan omgaan
[ Voor 12% gewijzigd door ari2asem op 06-05-2018 17:08 ]
  • sdk1985
ari2asem schreef op zondag 6 mei 2018 @ 17:07:
Meer iets voor een apart topic?
Snapraid heeft geen GUI. Er is een Github project met de naam Elucidate wat een Windows GUI geeft: https://github.com/Smurf-IV/Elucidate
  • ari2asem
sdk1985 schreef op donderdag 12 juli 2018 @ 15:22:
yep, en elucidate is niet meer compatible met snapraid v11. elucidate werkt alleen met snapraid tot versie 10. sinds versie 11 snapraid is er functionaliteit dat het SPLIT PARITY heet. waardoor elucidate niet meer werkt
  • sdk1985
ari2asem schreef op donderdag 12 juli 2018 @ 16:23:
De commando's gaan prima. Config bouwen gaat wellicht niet goed.
