Schema configuratie kabel UPS
  • 123 views sinds 30-01-2008
  • Diamon
  • Laatst online: 27-08 13:00
Diamon
The Weird One
Een kennis van mij heeft een configuratie kabeltje nodig voor zijn UPS (APC)
Tis een Smart-UPS 1000
Ik ben al bezig geweest met verschillende schema's, maar geen werkt.
Wie is in het bezit van zo'n kabeltje, en kan daar effe een schema van maken.
Of wie heeft een link naar zo'n schema.
Kan APC wel bellen, maar dat zal wel weer veel geld gaan kosten :(
And The Only One
Van usenet :)
I succesfully use my APC Smart 2000 UPS on cuaa0 on 4.1 with my own home
soldered _special_ cable, (but an upgrade from 3.4 is not what I'm suggesting,
though of course you might want to try 4.1 anyway).
An APC, is Not a normal PC type plug, but totaly non PC standard pinout
with back compatability for non Smart models that don't use serial but
do use 3 wire DC state output ! Do not use APC cables between 2 normal
non APC devices. Do not use normal serial cables with an APC.
I got my pdf format of the APC manual from Web August 2000:
http://www.apc.com
http://answers.apcc.com/cgi-bin/apc/solved
http://www.apcc.com/support/
http://159.215.19.5/techref.nsf/umanuals
http://159.215.19.5/techref.nsf/umanuals?OpenView&Start=1&Count=500&Expand=29#29
http://159.215.19.5/techref.nsf/umanuals/128C9E5051B779BD852567A70057E436?OpenDocument
ports/graphics/xpdf will display it.
All pinouts for PC, APC UPS, cable I made to work between etc are on my
http://bim.bsn.com/~jhs/standards/rs232.v24
which I'm also emailing you a private copy of.
You might possibly have damaged your serial port if you connected a normal
cable between the UPS & PC. Did you use a straight cable (PC to modem type)
or a 'crossed' (= `rolled') cable used to normally connect 2 PCs together ?
Ask yourself this question, add the information from my pin out diagram,
& you can figure out which signals you connected where.
After that, if still have have questions, mail me.
If you really want to know what's going on, you probably need to use an
RS232/V24 Serial Breakout Box, a small cheapish thing with 9 LEDs, lots of
switches & jumper cables, & [multiple] male & female 25 or 9 pin plugs &
sockets each side of the box.
(Mine had a single 25 female + 25 male, but I extended it to have M+F 25+9
each side)
Julian
Julian Staceyhttp://bim.bsn.com/~jhs/
Succes!
  • Diamon
Diamon
The Weird One
iig bedankt voor de link.
Maar ik kom de UPS niet tegen die ik hier heb.
Gezien er nogal wat verschillende zijn, weet ik niet welke ik moet hebben.
Iemand een idee, of ook zo'm UPS en kabel
And The Only One
  • FragDaddy
  • Laatst online: 10-09 11:59
bel gewoon APC even. met een beetje geluk sturen ze je die kabel gewoon gratis toe.. (je hebt al genoeg betaald voor die UPS)
Have a wheelie good weekend!
  • Diamon
Diamon
The Weird One
Op maandag 25 juni 2001 00:03 schreef FragDaddy het volgende:
2 meijer aan nieuwe accu's >:)
And The Only One
  • Diamon
Diamon
The Weird One
^^^^UP^^^^
Niemand :'(
And The Only One
  • NiGeLaToR
  • Laatst online: 20:50
NiGeLaToR
Luister Kophi Podcast!
Op dinsdag 26 juni 2001 20:52 schreef Diamon het volgende:
^^^^UP^^^^
Niemand :'(
Ken ook niet veel mensen met een UPS, sorry...
Maakt reviews bij IOTDomotica.nl . Podcast bij Kophi: ook op YT.
  • Diamon
Diamon
The Weird One
^^Update^^
APC is wat mij betreft een zeer goed bedrijf, plus een pluim van * Diamon .
Why, wel ik heb ze maandag gebeld.
En voor deze keer, zou hij als uitzondering een configuratie kabeltje opsturen.
Is dit Service of is dit Service, van veel andere bedrijven kun je dit niet zeggen.
Kortom, * Diamon is zeer blij
And The Only One
