is dit een goeie monitor ?
hier wat meer gegevens:
High Contrast 17 (16 viewable) Shadow Mask FST screen
0,27mm (0,23mm horizontal) dot pitch, dual focus CRT, for a crisp clear, dynamic display
Simply to operate 4 push button controls
High resolution On-screen Display for ease of set up and use
Plug-and-play DDC1/2B compatible
TCO'99 approved
Ecologically manufactured,
Model LS702UT Vision Master 1402
CRT 17", High Contrast FST CRT, (16", 41cm viewable)
Surface processing Anti-reflection & Anti-static coating
Dot pitch 0,27mm (0,23mm horizontal, 0,13mm vertical)
Sync Frequentie Horizontaal: 30,0-70,0kHz, Verticaal: 50-160Hz
Input Sync Signal Separate sync: TTL, pos. or neg.
Input Video Signal Analog: 0,7Vp-p (standard, 75, pos.)
Video bandwidth 110Mhz dot clock
Resolution 640 x 480 @ 140Hz
800 x 600 @ 111Hz
1024 x 0768 @ 86Hz
1152 x 0864 @ 76Hz
1280 x 1024 @ 65Hz
Input connectors 15 pin D-sub fixed
Plug & Play VESA DDC1/2B
Number of signal storage Factory-presets: 9, User memory locations: 20, Automatically saved
Dimensions 410mm x 404mm x 420mm (W x H x D)
Net weight 16kg
Controls High resolution on-screen display menus
Power management VESA DPMS, EPA Energy star and Nutek
Power consumption 80W maximum in normal use, <=15W in suspend mode, <= 5W in active-off mode
Power supply AC 90-132/198 - 264V (Worldwide), Frequency: 50/60Hz
Screen controls Contrast, Brightness, H-Center, H-Size, V-Center, V-Size, Zoom, Pincushion, Trapezoid, Pin-balance, Parallelogram, Rotation, OSD Center, User Color: Red/Blue, Temperature for 9300K/6500K/5000K, Degauss, H-moire reduce, H-Convergence, Exit, Language: Eng/Deu/Fra/Esp/Ita/Por
Approvals TCO'99, CE, TÜV-GS, MPRII, PTB, FCC-B, UL, CSA, DHHS, dep. Of Health (Canada)
en een plaatje
TCO'99 approved
800 x 600 @ 111Hz
1024 x 0768 @ 86Hz
1152 x 0864 @ 76Hz
1280 x 1024 @ 65Hz
Net weight 16kg
en een plaatje
XP2600+ @ 2500mhz 1024mb Twinmos PC2700 @ CS2 WD1800JB Plextor 40x CDRW Ti 4600 ULTRA
