CDT
Type (VIS)
19" (18") - FST
Pitch
0.26 mm Dot Pitch
Focus
Dynamic
Face Plate Treatment
Anti-Static & E-Coating
Display Size
Fullscan (Max.)
365.8 x 274.3 mm
Max. Resolution
1600 x 1200 @ 75 Hz
H-Frequency
30 ~ 96 KHz
V-Frequency
50 ~ 160 Hz
Pixel Frequency
180 MHz
Memory Modes
5 Factory Set, 26 User Settable
Signal Input
Video
RGB Analog/0.7 Vp-p/75 ohms
Sync
Separate
User Control
Type
Digital Microprocessor OSD Control
Front
Power/Set (1)/OSD On; Off (1)/Select (2)/Up-Down (2)
OSD Function
Brightness/Contrast
Color
Preset (6500K, 9300K) TEMP, RED, GREEN, BLUE
Position
H/V Position
Size
H/V Size
Shape
Side Pincushion/Side Pincushion Balance/Trapezoid/Parallelogram
Setup
Video Level/DDC/Language/OSD Position/Clamp
Special
Degauss/Recall/Moire/Convergence
Video Connector
15-Pin D-Sub
Communication
DDC 1/2B
Power Requirements
AC 100 - 240 V, 50/60 Hz, 2.0 A
DPM Power
130 W (Normal)/8 W (Standby, Suspend)/3 W (Off)
Dimensions
(W x D x H)
Set
(With T/S)
448 x 476 x 465 mm
Box
(Outer Size)
570 x 640 x 630 mm
Weight
21.5 kg (47.4 lbs)
Standards (Certifications)
Safety
UL/CSA/TUV-GS/SEMKO/NEMKO/DEMKO/FIMKO
EMC
FCC CLASS B/CE
X-RAY
DHHS/HWC/ROV
Low Radiation
MPR-II, TCO-99
Ergonomic
ISO 9241-3/ISO 9241-8
Power Saving
NUTEK/EPA
VCCI-2/GOST/CCIB/C-TICK
Stuffing
108 (20 ft), 216 (40 ft)
dit zijn de specs van een scherm; is dit wat ?! want ik ken er echt niets van...
thanx
Type (VIS)
19" (18") - FST
Pitch
0.26 mm Dot Pitch
Focus
Dynamic
Display Size
Fullscan (Max.)
365.8 x 274.3 mm
Max. Resolution
1600 x 1200 @ 75 Hz
H-Frequency
30 ~ 96 KHz
V-Frequency
50 ~ 160 Hz
Pixel Frequency
180 MHz
Memory Modes
Signal Input
Video
Sync
Separate
User Control
Type
Front
OSD Function
Brightness/Contrast
Color
Position
H/V Position
Size
H/V Size
Shape
Setup
Special
Video Connector
15-Pin D-Sub
Communication
DDC 1/2B
Power Requirements
DPM Power
Dimensions
(W x D x H)
Set
(With T/S)
448 x 476 x 465 mm
Box
(Outer Size)
570 x 640 x 630 mm
Weight
21.5 kg (47.4 lbs)
Safety
EMC
FCC CLASS B/CE
X-RAY
DHHS/HWC/ROV
Low Radiation
MPR-II, TCO-99
Ergonomic
Power Saving
NUTEK/EPA
Stuffing
thanx
