Hallo allemaal,
Op mijn Windows Server 2012 probeer ik nu Exchange 2016 te installeren. Dit lukt alleen niet helemaal. Tijdens de installatie krijg ik steeds het volgende probleem:
Error:
The following error was generated when "$error.Clear();
          $vdirName = "PowerShell";
          $InternalPowerShellUrl="http://" + $RoleFqdnOrName + "/powershell";
          new-PowerShellVirtualDirectory $vdirName -Role Mailbox -InternalUrl $InternalPowerShellUrl -DomainController $RoleDomainController -BasicAuthentication:$false -WindowsAuthentication:$false -RequireSSL:$false -WebSiteName "Default Web Site" -AppPoolId "MSExchangePowerShellFrontEndAppPool";
          new-PowerShellVirtualDirectory $vdirName -Role Mailbox -DomainController $RoleDomainController -BasicAuthentication:$false -WindowsAuthentication:$true -RequireSSL:$true -WebSiteName "Exchange Back End" -Path ($RoleInstallPath + "ClientAccess\PowerShell-Proxy");
        " was run: "System.ArgumentException: The Web site 'Default Web Site' on server 'JOCHEMPLUIM-MC.soundvisionvelp.nl' doesn't exist. Web site names are case sensitive.
Parameter name: WebSiteName
   at Microsoft.Exchange.Configuration.Tasks.Task.WriteError(Exception exception, ErrorCategory category, Object target, Boolean reThrow, String helpUrl)
   at Microsoft.Exchange.Configuration.Tasks.Task.WriteError(Exception exception, ErrorCategory category, Object target)
   at Microsoft.Exchange.Management.SystemConfigurationTasks.NewExchangeVirtualDirectory`1.InternalValidate()
   at Microsoft.Exchange.Configuration.Tasks.Task.<ProcessRecord>b__b()
   at Microsoft.Exchange.Configuration.Tasks.Task.InvokeRetryableFunc(String funcName, Action func, Boolean terminatePipelineIfFailed)".
Error:
        " was run: "System.ArgumentException: The Web site 'Exchange Back End' on server 'JOCHEMPLUIM-MC.soundvisionvelp.nl' doesn't exist. Web site names are case sensitive.
Ik maak hieruit op dat twee sites niet gevonden worden binnen IIS, maar dat kan ik mis hebben. Maakt de installatie niet zelf de benodigde sites aan?
Ben benieuwd naar jullie ideeën c.q. oplossingen.
Groet, Jochem
  • Dennism
  • Registratie: September 1999
  • Laatst online: 21:26
Paar mogelijkheden waar ik aan zou denken:
1. Is Exchange 2016 al wel supported op Server 2016 (gezien deze nog in preview is). Test bijv. eens met 2012 R2 om te kijken of je dezelfde foutmelding krijgt.
2. Zijn alle Pre-Req's voor exchange 2016 uitgevoerd voordat de installatie gestart is?
o.a. domain / forest prep, alle benodigde serverroles / features geinstalleerd
Install-WindowsFeature AS-HTTP-Activation, Desktop-Experience, NET-Framework-45-Features, RPC-over-HTTP-proxy, RSAT-Clustering, RSAT-Clustering-CmdInterface, RSAT-Clustering-Mgmt, RSAT-Clustering-PowerShell, Web-Mgmt-Console, WAS-Process-Model, Web-Asp-Net45, Web-Basic-Auth, Web-Client-Auth, Web-Digest-Auth, Web-Dir-Browsing, Web-Dyn-Compression, Web-Http-Errors, Web-Http-Logging, Web-Http-Redirect, Web-Http-Tracing, Web-ISAPI-Ext, Web-ISAPI-Filter, Web-Lgcy-Mgmt-Console, Web-Metabase, Web-Mgmt-Console, Web-Mgmt-Service, Web-Net-Ext45, Web-Request-Monitor, Web-Server, Web-Stat-Compression, Web-Static-Content, Web-Windows-Auth, Web-WMI, Windows-Identity-Foundation
.net 4.5.2 en Microsoft Unified Communications Managed API 4.0, Core Runtime 64-bit
De default website zou namelijk zondemeer moeten bestaan als IIS correct is geïnstalleerd.
  • wagenveld
wagenveld
Windows Server 2016 is idd nog niet ondersteund, maar zou in theorie wel moeten werken. Zou het overigens niet in productie gaan gebruiken.
Dat gezegd hebbende lijkt het er op dat je een eerder mislukte installatie niet lekker opgeschoond hebt, de 'Default Website' is verwijderd. Probeer die eens terug te zetten:
http://geekswithblogs.net...ive/2005/12/09/62737.aspx
Alternatief (kan zo snel ook geen meer recente instructies vinden), verwijder IIS helemaal, verwijder de inetpub folder en draai script hierboven om alle prereqs opnieuw te installeren.
Dennism schreef op zondag 06 maart 2016 @ 16:04:
Foutje, bedoelde Windows Server 2012 R2... Aangepast in eerste bericht. Ik krijg deze fout dus op 2012 R2.
Voor zover ik weet zijn alle pre-req's correct van te voren uitgevoerd. Ik ga nu proberen Windows Server helemaal opnieuw te installeren en dan kijken of het werkt.
  • Turdie
  • Laatst online: 20-04 14:54
Turdie
De foutmelding is toch best duidelijk:
"System.ArgumentException: The Web site 'Default Web Site' on server 'JOCHEMPLUIMMC.soundvisionvelp.nl' doesn't exist. Web site names are case sensitive.
In principe zou ik dan IIS verwijderen, en met dit stuk PowerShell opnieuw aanmaken:
PowerShell:
[ Voor 151% gewijzigd door Turdie op 06-03-2016 22:13 ]
  • Jazzy
Jazzy
Moderator SSC/PB/AI
Moooooh!
wagenveld schreef op zondag 06 maart 2016 @ 16:18:
Nee hoor.
Wat ik mis is of de sites wel aangemaakt zijn, is makkelijk te controleren in IIS Manager.
[ Voor 18% gewijzigd door Jazzy op 07-03-2016 13:49 ]
  • Dennism
Jazzy schreef op maandag 07 maart 2016 @ 13:45:
Nee hoor.
Is dit "Nee hoor" als in "Exchange 2016 is nog niet supported en werkt ook nog niet op 2016" of als in "Het is volledig supported door Microsoft op Server 2016"
  • Jazzy
Jazzy
Moderator SSC/PB/AI
Moooooh!
Server 2016 is nog pre-release software en niet RTM. Zowel Server 2016 in de huidige versies als de ingebakken WMF 5.0 en .Net Framework worden nog niet voor Exchange ondersteund. 'Het zou moeten werken' lijkt me dus een beetje voorbarig.
  • Dennism
Jazzy schreef op maandag 07 maart 2016 @ 15:02:
Dank, dat vermoedde ik al, zie ook mijn eerste post in deze thread maar toch handig om even zeker te weten.
[ Voor 4% gewijzigd door Dennism op 07-03-2016 15:23 ]
  • Turdie
Turdie
Dennism schreef op maandag 07 maart 2016 @ 15:22:
Maar dit gaat over Server 2012 en Exchange Server 2016, en daarin wordt Server 2012 en Server 2012 R2 gewoon ondersteund. Inderdaad, TS, check of die sites al uberhaupt aangemaakt zijn.
[ Voor 78% gewijzigd door Turdie op 07-03-2016 22:08 ]
  • Dennism
shadowman12 schreef op maandag 07 maart 2016 @ 22:06:
Dan heb je de post van TS voor zijn edit niet gelezen, zie ook zijn 2de post. In zijn originele post stond Exchange 2016 op Windows Server 2016 :) Alle posts voor zijn 2de posts haken dus ook in op Exchange 2016 op Windows 2016 :)
[ Voor 8% gewijzigd door Dennism op 07-03-2016 23:15 ]
