osmc & limelight installeren
  • 254 views
  • klen_ghost
  • Laatst online: 13-07 08:11
vandaag eens geprobeerd limelight te installeren op mijn pi2 welke ik vanmorge een schone osmc installatie heb gegeven.
helaas lukt het maar niet om limelight te installeren. heb de how to gevolgd en letterlijk gedaan wat daarin stond maar ergens kom ik niet verder.
deze how to bedoel ik
https://discourse.osmc.tv...ded-former-limelight/5848
hier is de input en de resultaten van wat er uitkwam
root@osmc:/home/osmc# cat /boot/config.txt
gpu_mem_1024=256
hdmi_ignore_cec_init=1
disable_overscan=1
start_x=1
disable_splash=1
dtoverlay=lirc-rpi:gpio_out_pin=17,gpio_in_pin=18
root@osmc:/home/osmc# sudo "dtparam=audio=on" | tee -a /boot/config.txt
usage: sudo -h | -K | -k | -V
usage: sudo -v [-AknS] [-g group] [-h host] [-p prompt] [-u user]
usage: sudo -l [-AknS] [-g group] [-h host] [-p prompt] [-U user] [-u user]
[command]
usage: sudo [-AbEHknPS] [-r role] [-t type] [-C num] [-g group] [-h host] [-p
prompt] [-u user] [VAR=value] [-i|-s] [<command>]
usage: sudo -e [-AknS] [-r role] [-t type] [-C num] [-g group] [-h host] [-p
prompt] [-u user] file ...\
root@osmc:/home/osmc# sudo -s
echo "deb http://archive.itimmer.nl/raspbian/moonlight jessie main" > /etc/apt/sources.list.d/moonlight.list
root@osmc:/home/osmc# sudo apt-get update && sudo apt-get install -y moonlight-embedded\
Hit http://security.debian.org jessie/updates InRelease
Ign http://archive.itimmer.nl jessie InRelease
Hit http://ftp.debian.org jessie-updates InRelease
Ign http://archive.itimmer.nl jessie Release.gpg
Hit http://archive.itimmer.nl jessie Release
Hit http://apt.osmc.tv jessie InRelease
Hit http://security.debian.org jessie/updates/non-free armhf Packages
Ign http://archive.itimmer.nl jessie/main armhf Packages/DiffIndex
Hit http://security.debian.org jessie/updates/non-free Translation-en
Hit http://security.debian.org jessie/updates/main armhf Packages
Get:1 http://ftp.debian.org jessie-updates/main armhf Packages/DiffIndex [367 B]
Hit http://security.debian.org jessie/updates/contrib armhf Packages
Hit http://security.debian.org jessie/updates/contrib Translation-en
Hit http://ftp.debian.org jessie-updates/contrib armhf Packages
Hit http://ftp.debian.org jessie-updates/non-free armhf Packages
Hit http://security.debian.org jessie/updates/main Translation-en
Hit http://ftp.debian.org jessie-updates/contrib Translation-en
Hit http://ftp.debian.org jessie-updates/non-free Translation-en
Hit http://ftp.debian.org jessie-updates/main Translation-en
Get:2 http://apt.osmc.tv jessie/main armhf Packages/DiffIndex [2023 B]
Ign http://apt.osmc.tv jessie/main Translation-en
Err http://archive.itimmer.nl jessie/maindeb armhf Packages
404 Not Found
Err http://archive.itimmer.nl jessie/http://archive.itimmer.nl/raspbian/moonlight armhf Packages
404 Not Found
Err http://archive.itimmer.nl jessie/jessie armhf Packages
404 Not Found
Err http://archive.itimmer.nl jessie/http://ftp.debian.org/debian armhf Packages
404 Not Found
Get:3 http://archive.itimmer.nl jessie/main armhf Packages [601 B]
Err http://archive.itimmer.nl jessie/contrib armhf Packages
404 Not Found
Err http://archive.itimmer.nl jessie/non-free armhf Packages
404 Not Found
Ign http://archive.itimmer.nl jessie/contrib Translation-en
Ign http://archive.itimmer.nl jessie/http://archive.itimmer.nl/raspbian/moonlight Translation-en
Ign http://archive.itimmer.nl jessie/http://ftp.debian.org/debian Translation-en
Ign http://archive.itimmer.nl jessie/jessie Translation-en
Ign http://archive.itimmer.nl jessie/main Translation-en
Ign http://archive.itimmer.nl jessie/maindeb Translation-en
Ign http://archive.itimmer.nl jessie/non-free Translation-en
Fetched 2390 B in 1s (1534 B/s)
W: Failed to fetch http://archive.itimmer.nl...deb/binary-armhf/Packages 404 Not Found
W: Failed to fetch http://archive.itimmer.nl...ght/binary-armhf/Packages 404 Not Found
W: Failed to fetch http://archive.itimmer.nl...sie/binary-armhf/Packages 404 Not Found
W: Failed to fetch http://archive.itimmer.nl...ian/binary-armhf/Packages 404 Not Found
W: Failed to fetch http://archive.itimmer.nl...rib/binary-armhf/Packages 404 Not Found
W: Failed to fetch http://archive.itimmer.nl...ree/binary-armhf/Packages 404 Not Found
W: Failed to fetch http://archive.itimmer.nl...ain/binary-armhf/Packages Hash Sum mismatch
E: Some index files failed to download. They have been ignored, or old ones used instead.
  • CAPSLOCK2000
  • Laatst online: 02-10 16:00
CAPSLOCK2000
zie teletekst pagina 888
Wat heb je zelf al gedaan om het probleem op te lossen? Zie je waar het fout gaat?
klen_ghost schreef op zaterdag 20 februari 2016 @ 13:54:
Dit slaat nergens op, het kan niet werken. Ik snap wat ze willen maar dit is onzin. Gebruik een teksteditor om dtparam=audio=on toe te voegen aan config.txt
Hier op Tweakers verwachten we eigen inzet. We denken graag mee over interessante problemen maar we gaan het niet voorkauwen. We zijn een discussieforum, het is niet de bedoeling dat je problemen hier neerkwakt zonder er zelf moeite voor te doen. Misschien heb je dat wel gedaan maar dat blijkt niet uit je post. Volgens mij hebben we het hier vorige maand ook al over gehad. Omdat er over deze fout geen discussie te voeren valt sluit ik dit topic.
This post is warranted for the full amount you paid me for it.
