hard disk write protected
  • htca
  • Laatst online: 28-09 11:19
Ik heb een interne hard schijf welke op onverklaarbare wijze write-protected is geraakt (voor alle users en admins). CHKDSK geeft geen issues, CHKDSK /F geeft een melding dat dat de volume write-protected is. Het terug zetten van readonly op verschillende lokaties werkt niet.
Geprobeerd:
- rechten voor de user hetzelfde als admin
- attributes te modificeren vanaf de command line
- DISKPART als adminstrator te draaien en de volgende sequence: attributes disk set readonly
disk-type: WDC WD10JPVX-22J3CT0
OS: win 7 64 bit
Uitvoer van chkdsk:
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
D:\>chkdsk
The type of the file system is NTFS.
The volume is in use by another process. Chkdsk
might report errors when no corruption is present.
Volume label is D drive.
WARNING!  F parameter not specified.
Running CHKDSK in read-only mode.
CHKDSK is verifying files (stage 1 of 3)...
  170496 file records processed.
File verification completed.
  12 large file records processed.
  0 bad file records processed.
  0 EA records processed.
  0 reparse records processed.
CHKDSK is verifying indexes (stage 2 of 3)...
  198076 index entries processed.
Index verification completed.
  0 unindexed files scanned.
  0 unindexed files recovered.
CHKDSK is verifying security descriptors (stage 3 of 3)...
  170496 file SDs/SIDs processed.
Security descriptor verification completed.
  13791 data files processed.
CHKDSK is verifying Usn Journal...
  34643696 USN bytes processed.
Usn Journal verification completed.
Windows has checked the file system and found no problems.
 976758783 KB total disk space.
 327433756 KB in 153462 files.
     57916 KB in 13792 indexes.
         0 KB in bad sectors.
    297187 KB in use by the system.
     65536 KB occupied by the log file.
 648969924 KB available on disk.
      4096 bytes in each allocation unit.
 244189695 total allocation units on disk.
 162242481 allocation units available on disk.
D:\>chkdsk /F
Cannot lock current drive.
Windows cannot run disk checking on this volume because it is write protected.
D:\>
Iemand nog een idee?
  • G-bird
  • Laatst online: 21-12-2017
  • htca
Die had ik al geprobeerd (DISKPART)
Ik draai nu de lifeguard diagnostics. Die geeft vooralsnog op de quickscan geen meldingen. Op de extended test wordt nu geploegd.
  • Jorseal
  • Laatst online: 08-09 20:49
Mijn kristallen bol zegt dat je pagefile.sys of een ander systeem bestand op de D schijf hebt staan.
Vooral omdat chkdsk zegt "The volume is in use by another process."
Er is dus een systeembestand of anders een programma die de schijf claimt.
Je zou nog een poging kunnen doen met /x /f ... maar als er een systeembestand op staat gaat je Windows het niet leuk vinden als hij niet meer mag lezen en schijven naar dit bestand.
Chkdsk op je C schijf is hij nog wel slim genoeg om de scan in te plannen bij de volgende reboot.
  • htca
Jorseal schreef op woensdag 10 februari 2016 @ 13:19:
Het is mijn D schijf niet mijn systeem schijf. Er staat voornamelijk data op. Ik denk dat ik maar een backup ga maken. -> die pagefile.sys, is die middels een linux boot weg te halen? (live CD of USB en dan een rm op die file?). Ik had geprobeerd veilig op te starten, maar dat mocht ook niet baten (kon ik de schijf niet benaderen)
  • htca
Vaag, schijf is weer toegankelijk nadat ik een backup had gemaakt.
