Exchange 2013 wil niet installeren
  • BrozzBrozz
  • Registratie: Oktober 2015
  • Laatst online: 26-10 17:09
Bij het voorbereiden van de AD komt hij steeds terug met een error.
De error is als volgt:
[01/15/2016 09:40:45.0259] [0] **********************************************
[01/15/2016 09:40:45.0259] [0] Starting Microsoft Exchange Server 2013 Service Pack 1 Setup
[01/15/2016 09:40:45.0259] [0] Local time zone: (UTC+01:00) Amsterdam, Berlin, Bern, Rome, Stockholm, Vienna.
[01/15/2016 09:40:45.0259] [0] Operating system version: Microsoft Windows NT 6.2.9200.0.
[01/15/2016 09:40:45.0259] [0] Setup version: 15.0.847.32.
[01/15/2016 09:40:45.0259] [0] Logged on user: Domein\administrator.
[01/15/2016 09:40:45.0275] [0] The registry key, HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\ExchangeServer\V15\Setup, wasn't found.
[01/15/2016 09:40:45.0306] [0] Command Line Parameter Name='preparead', Value=''.
[01/15/2016 09:40:45.0306] [0] Command Line Parameter Name='iacceptexchangeserverlicenseterms', Value=''.
[01/15/2016 09:40:45.0306] [0] Command Line Parameter Name='organizationname', Value='Digital United'.
[01/15/2016 09:40:45.0306] [0] Command Line Parameter Name='sourcedir', Value='D:\'.
[01/15/2016 09:40:45.0572] [0] RuntimeAssembly was started with the following command: '/Preparead /IAcceptExchangeServerLicenseTerms /OrganizationName:Digital United /sourcedir:D:"'.
[01/15/2016 09:40:45.0587] [0] The registry key, HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Exchange\v8.0, wasn't found.
[01/15/2016 09:40:45.0587] [0] The registry key, HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\ExchangeServer\v14, wasn't found.
[01/15/2016 09:40:45.0603] [0] The registry key, HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\ExchangeServer\V15\Setup, wasn't found.
[01/15/2016 09:40:45.0603] [0] Copying Files...
[01/15/2016 09:40:45.0619] [0] Starting copy from D:\Setup\ServerRoles\Common to C:\Windows\Temp\ExchangeSetup.
[01/15/2016 09:40:52.0930] [0] Finished copy from D:\Setup\ServerRoles\Common to C:\Windows\Temp\ExchangeSetup.
[01/15/2016 09:40:52.0930] [0] File copy complete. Setup will now collect additional information needed for installation.
[01/15/2016 09:40:52.0961] [0] Assembly dll file location is C:\Windows\Temp\ExchangeSetup\Microsoft.Exchange.Setup.Console.dll
[01/15/2016 09:40:56.0914] [0] Setup is choosing the domain controller to use
[01/15/2016 09:41:03.0461] [0] Setup is choosing a local domain controller...
[01/15/2016 09:41:05.0695] [0] Setup has chosen the local domain controller DC.Domein.nl for initial queries
[01/15/2016 09:41:06.0586] [0] [ERROR] Setup encountered a problem while validating the state of Active Directory: Couldn't find the Enterprise Organization container. See the Exchange setup log for more information on this error.
[01/15/2016 09:41:06.0601] [0] [ERROR] Couldn't find the Enterprise Organization container.
[01/15/2016 09:41:06.0601] [0] Setup will use the domain controller ''.
[01/15/2016 09:41:06.0601] [0] Setup will use the global catalog ''.
[01/15/2016 09:41:06.0617] [0] Exchange configuration container for the organization is 'CN=Microsoft Exchange,CN=Services,CN=Configuration,DC=Domein,DC=nl'.
[01/15/2016 09:41:06.0617] [0] No Exchange organization container was found for the organization. Message: 'Couldn't find the Enterprise Organization container.'.
[01/15/2016 09:41:06.0617] [0] For more information refer to http://go.microsoft.com/fwlink/p/?LinkId=257397.
[01/15/2016 09:41:06.0617] [0] Setup will search for an Exchange Server object for the local machine with name 'Computername'.
[01/15/2016 09:41:06.0742] [0] No Exchange Server with identity 'Computername' was found.
[01/15/2016 09:41:06.0758] [0] The following roles have been unpacked:
[01/15/2016 09:41:06.0758] [0] The following datacenter roles are unpacked:
[01/15/2016 09:41:06.0758] [0] The following roles are installed:
[01/15/2016 09:41:06.0773] [0] The local server does not have any Exchange files installed.
[01/15/2016 09:41:06.0805] [0] Server Name=Computername
[01/15/2016 09:41:06.0883] [0] Setup will use the path 'D:\' for installing Exchange.
[01/15/2016 09:41:06.0898] [0] The installation mode is set to: 'Install'.
[01/15/2016 09:41:24.0242] [0] Setting organization name to 'Digital United'.
[01/15/2016 09:41:24.0242] [0] Active Directory Initialization status : 'False'.
[01/15/2016 09:41:24.0242] [0] Schema Update Required Status : 'False'.
[01/15/2016 09:41:24.0242] [0] Organization Configuration Update Required Status : 'True'.
[01/15/2016 09:41:24.0242] [0] Domain Configuration Update Required Status : 'False'.
[01/15/2016 09:41:24.0289] [0] Applying default role selection state
[01/15/2016 09:41:24.0336] [0] Setup is determining what organization-level operations to perform.
[01/15/2016 09:41:24.0336] [0] The command-line option preparead has been specified.
[01/15/2016 09:41:24.0336] [0] Because the command-line option preparead was specified, setup is adding the argument PrepareOrganization.
[01/15/2016 09:41:24.0336] [0] Because the command-line option preparead was specified, setup is adding the argument PrepareDomain.
[01/15/2016 09:41:24.0336] [0] Because the value was specified, setup is setting the argument OrganizationName to the value Digital United.
[01/15/2016 09:41:24.0336] [0] Setup will run from path 'C:\Windows\Temp\ExchangeSetup'.
[01/15/2016 09:41:24.0351] [0] InstallModeDataHandler has 1 DataHandlers
[01/15/2016 09:41:24.0351] [0] RootDataHandler has 1 DataHandlers
[01/15/2016 09:41:24.0383] [0] Validating options for the 0 requested roles
[01/15/2016 09:41:24.0414] [0] Performing Microsoft Exchange Server Prerequisite Check
[01/15/2016 09:41:24.0445] [0] Setup is determining what organization-level operations to perform.
[01/15/2016 09:41:24.0445] [0] The command-line option preparead has been specified.
[01/15/2016 09:41:24.0445] [0] Because the command-line option preparead was specified, setup is adding the argument PrepareOrganization.
[01/15/2016 09:41:24.0445] [0] Because the command-line option preparead was specified, setup is adding the argument PrepareDomain.
[01/15/2016 09:41:24.0445] [0] Because the value was specified, setup is setting the argument OrganizationName to the value Digital United.
[01/15/2016 09:41:24.0570] [0] **************
[01/15/2016 09:41:24.0570] [0] Setup will run the task 'test-SetupPrerequisites'
[01/15/2016 09:41:24.0570] [1] Setup launched task 'test-SetupPrerequisites -DomainController $null -ExchangeVersion '15.0.847.32' -Roles 'Global' -ScanType 'PrecheckInstall' -SetupRoles 'Global' -PrepareDomain $null -PrepareOrganization $true -ADInitError 'Setup encountered a problem while validating the state of Active Directory: Couldn''t find the Enterprise Organization container. See the Exchange setup log for more information on this error.' -HostingDeploymentEnabled $false'
[01/15/2016 09:41:25.0898] [1] Active Directory session settings for 'test-SetupPrerequisites' are: View Entire Forest: 'True',
[01/15/2016 09:41:25.0945] [1] User specified parameters: -ScanType:'PrecheckInstall' -SetupRoles:'Global' -DomainController:$null -HostingDeploymentEnabled:'False' -PrepareOrganization:'True' -ADInitError:'Setup encountered a problem while validating the state of Active Directory: Couldn''t find the Enterprise Organization container. See the Exchange setup log for more information on this error.' -PrepareDomain:$null -ExchangeVersion:'15.0.847.32' -Roles:'Global'
[01/15/2016 09:41:25.0945] [1] Beginning processing test-SetupPrerequisites
[01/15/2016 09:41:26.0742] [1] Started [Analysis:Prereq]
[01/15/2016 09:41:26.0883] [1] Started [Rule:W2K8R2PrepareAdLdifdeNotInstalled] [Parent:RootAnalysisMember] [RuleType:Error]
[01/15/2016 09:41:26.0883] [1] Started [Rule:SendConnectorException] [Parent:OrgMicrosoftExchServicesConfig] [RuleType:Error]
[01/15/2016 09:41:26.0883] [1] Started [Rule:RebootPending] [Parent:RootAnalysisMember] [RuleType:Error]
[01/15/2016 09:41:26.0883] [1] Started [Rule:RemoteRegException] [Parent:RootAnalysisMember] [RuleType:Error]
[01/15/2016 09:41:26.0883] [1] Started [Rule:W2K8R2PrepareSchemaLdifdeNotInstalled] [Parent:RootAnalysisMember] [RuleType:Error]
[01/15/2016 09:41:26.0883] [1] Started [Rule:PrimaryDNSTestFailed] [Parent:RootAnalysisMember] [RuleType:Warning]
[01/15/2016 09:41:26.0883] [1] Started [Rule:ComputerNotPartofDomain] [Parent:RootAnalysisMember] [RuleType:Error]
[01/15/2016 09:41:26.0883] [1] Started [Rule:OSCheckedBuild] [Parent:RootAnalysisMember] [RuleType:Warning]
[01/15/2016 09:41:26.0883] [1] Started [Rule:PendingRebootWindowsComponents] [Parent:RootAnalysisMember] [RuleType:Error]
[01/15/2016 09:41:26.0883] [1] Started [Rule:Exchange2000or2003PresentInOrg] [Parent:RootAnalysisMember] [RuleType:Error]
[01/15/2016 09:41:26.0898] [1] Started [Rule:RsatAddsToolsInstalled] [Parent:RootAnalysisMember] [RuleType:Error]
[01/15/2016 09:41:26.0898] [1] Started [Rule:PowerShellExecutionPolicyCheckSet] [Parent:RootAnalysisMember] [RuleType:Error]
[01/15/2016 09:41:26.0914] [1] Started [Setting:Exchange200x] [Parent:ExchangeSerialNumber] [ValueType:Boolean]
[01/15/2016 09:41:26.0914] [1] Started [Setting:DebugVersion] [Parent:RootAnalysisMember] [ValueType:Boolean]
[01/15/2016 09:41:26.0914] [1] Started [Setting:OrgMicrosoftExchServicesConfig] [Parent:RootAnalysisMember] [ValueType:ResultPropertyCollection]
[01/15/2016 09:41:26.0914] [1] Started [Setting:ExchangeSerialNumber] [Parent:RootAnalysisMember] [ValueType:String]
[01/15/2016 09:41:26.0914] [1] Started [Setting:PrimaryDNSPortAvailable] [Parent:RootAnalysisMember] [ValueType:Boolean]
[01/15/2016 09:41:26.0930] [1] Started [Setting:MailboxRoleInstalled] [Parent:RootAnalysisMember] [ValueType:Boolean]
[01/15/2016 09:41:26.0930] [1] Started [Setting:PrepareSchema] [Parent:RootAnalysisMember] [ValueType:Boolean]
[01/15/2016 09:41:26.0930] [1] Started [Setting:PowerShellExecutionPolicy] [Parent:RootAnalysisMember] [ValueType:Boolean]
[01/15/2016 09:41:26.0945] [1] Started [Setting:ClientAccessRoleInstalled] [Parent:RootAnalysisMember] [ValueType:Boolean]
[01/15/2016 09:41:26.0961] [1] Started [Setting:CafeRoleInstalled] [Parent:RootAnalysisMember] [ValueType:Boolean]
[01/15/2016 09:41:26.0961] [1] Started [Setting:DomainRole] [Parent:RootAnalysisMember] [ValueType:UInt16]
[01/15/2016 09:41:26.0961] [1] Started [Setting:PendingFileRenames] [Parent:RootAnalysisMember] [ValueType:String[]]
[01/15/2016 09:41:26.0961] [1] Started [Setting:MicrosoftExchServicesConfigDistinguishedName] [Parent:RootAnalysisMember] [ValueType:String]
[01/15/2016 09:41:26.0961] [1] Started [Setting:OrgDistinguishedName] [Parent:RootAnalysisMember] [ValueType:String]
[01/15/2016 09:41:26.0961] [1] Started [Setting:PrimaryDns] [Parent:RootAnalysisMember] [ValueType:String]
[01/15/2016 09:41:26.0961] [1] Started [Setting:FrontendTransportRoleInstalled] [Parent:RootAnalysisMember] [ValueType:Boolean]
[01/15/2016 09:41:26.0976] [1] Started [Setting:UnifiedMessagingRoleInstalled] [Parent:RootAnalysisMember] [ValueType:Boolean]
[01/15/2016 09:41:26.0976] [1] Started [Setting:MicrosoftExchServicesConfig] [Parent:RootAnalysisMember] [ValueType:ResultPropertyCollection]
[01/15/2016 09:41:26.0976] [1] Started [Setting:ConfigurationNamingContext] [Parent:RootAnalysisMember] [ValueType:String]
[01/15/2016 09:41:26.0976] [1] Started [Setting:RootDSEProperties] [Parent:RootAnalysisMember] [ValueType:List`1]
[01/15/2016 09:41:26.0976] [1] Started [Setting:DnsAddress] [Parent:NicConfiguration] [ValueType:String]
[01/15/2016 09:41:26.0992] [1] Started [Setting:NicConfiguration] [Parent:NicCaption] [ValueType:Dictionary`2]
[01/15/2016 09:41:26.0992] [1] Started [Setting:NicCaption] [Parent:RootAnalysisMember] [ValueType:String]
[01/15/2016 09:41:26.0992] [1] Started [Setting:SetupRoles] [Parent:RootAnalysisMember] [ValueType:String]
[01/15/2016 09:41:26.0992] [1] Started [Setting:ExchangeCurrentServerRoles] [Parent:RootAnalysisMember] [ValueType:Int32]
[01/15/2016 09:41:26.0992] [1] Evaluated [Setting:PrepareSchema] [HasException:False] [Value:"False"] [ParentValue:"<NULL>"] [Thread:22] [Duration:00:00:00.0312226]
[01/15/2016 09:41:26.0992] [1] Evaluated [Rule:PendingRebootWindowsComponents] [HasException:False] [Value:"False"] [ParentValue:"<NULL>"] [Thread:21] [Duration:00:00:00.0781225]
[01/15/2016 09:41:26.0992] [1] Evaluated [Setting:SetupRoles] [HasException:False] [Value:"Global"] [ParentValue:"<NULL>"] [Thread:19] [Duration:00:00:00]
[01/15/2016 09:41:26.0992] [1] Evaluated [Setting:PendingFileRenames] [HasException:False] [Value:"<NULL>"] [ParentValue:"<NULL>"] [Thread:18] [Duration:00:00:00.0312509]
[01/15/2016 09:41:27.0008] [1] Started [Setting:BridgeheadRoleInstalled] [Parent:RootAnalysisMember] [ValueType:Boolean]
[01/15/2016 09:41:27.0008] [1] Finished [Setting:PrepareSchema] [Duration:00:00:00.0624735]
[01/15/2016 09:41:27.0008] [1] Finished [Rule:PendingRebootWindowsComponents] [Duration:00:00:00.1249990]
[01/15/2016 09:41:27.0008] [1] Finished [Setting:PendingFileRenames] [Duration:00:00:00.0312509]
[01/15/2016 09:41:27.0008] [1] Finished [Setting:SetupRoles] [Duration:00:00:00.0156256]
[01/15/2016 09:41:27.0008] [1] Started [Setting:PrepareOrganization] [Parent:RootAnalysisMember] [ValueType:Boolean]
[01/15/2016 09:41:27.0008] [1] Started [Setting:GatewayRoleInstalled] [Parent:RootAnalysisMember] [ValueType:Boolean]
[01/15/2016 09:41:27.0008] [1] Started [Setting:ServerIsProvisioned] [Parent:RootAnalysisMember] [ValueType:Boolean]
[01/15/2016 09:41:27.0008] [1] Evaluated [Setting:PrepareOrganization] [HasException:False] [Value:"True"] [ParentValue:"<NULL>"] [Thread:22] [Duration:00:00:00]
[01/15/2016 09:41:27.0008] [1] Finished [Setting:PrepareOrganization] [Duration:00:00:00]
[01/15/2016 09:41:27.0008] [1] Started [Setting:IsRsatAddsToolsInstalled] [Parent:RootAnalysisMember] [ValueType:Boolean]
[01/15/2016 09:41:27.0023] [1] Started [Rule:UpdateNeedsReboot] [Parent:RootAnalysisMember] [RuleType:None]
[01/15/2016 09:41:27.0023] [1] Started [Setting:InstalledWindowsFeatures] [Parent:RootAnalysisMember] [ValueType:Object[]]
[01/15/2016 09:41:27.0023] [1] Started [Setting:ExchangeConfigurationUnitsConfiguration] [Parent:RootAnalysisMember] [ValueType:String]
[01/15/2016 09:41:27.0023] [1] Started [Setting:ExchangeConfigurationUnitsDomain] [Parent:RootAnalysisMember] [ValueType:String]
[01/15/2016 09:41:27.0023] [1] Evaluated [Rule:UpdateNeedsReboot] [HasException:False] [Value:"False"] [ParentValue:"<NULL>"] [Thread:18] [Duration:00:00:00]
[01/15/2016 09:41:27.0023] [1] Finished [Rule:UpdateNeedsReboot] [Duration:00:00:00]
[01/15/2016 09:41:27.0023] [1] Started [Setting:GlobalCatalog] [Parent:RootAnalysisMember] [ValueType:String]
[01/15/2016 09:41:27.0023] [1] Evaluated [Setting:GlobalCatalog] [HasException:False] [Value:""] [ParentValue:"<NULL>"] [Thread:19] [Duration:00:00:00]
[01/15/2016 09:41:27.0023] [1] Finished [Setting:GlobalCatalog] [Duration:00:00:00]
[01/15/2016 09:41:27.0023] [1] Started [Setting:SMOSchemaSiteName] [Parent:RootAnalysisMember] [ValueType:String]
[01/15/2016 09:41:27.0023] [1] Started [Setting:ShortProvisionedName] [Parent:RootAnalysisMember] [ValueType:String]
[01/15/2016 09:41:27.0023] [1] Started [Setting:DnsHostName] [Parent:RootAnalysisMember] [ValueType:String]
[01/15/2016 09:41:27.0023] [1] Started [Setting:MicrosoftExchServicesAdminGroupsConfig] [Parent:RootAnalysisMember] [ValueType:ResultPropertyCollection]
[01/15/2016 09:41:27.0039] [1] Started [Setting:SmoSchemaDN] [Parent:RootAnalysisMember] [ValueType:ResultPropertyCollection]
[01/15/2016 09:41:27.0055] [1] Started [Setting:RootNamingContext] [Parent:RootAnalysisMember] [ValueType:String]
[01/15/2016 09:41:27.0055] [1] Evaluated [Setting:RootDSEProperties] [HasException:False] [Value:"<NULL>"] [ParentValue:"<NULL>"] [Thread:19] [Duration:00:00:00.0781235]
[01/15/2016 09:41:27.0055] [1] Finished [Setting:RootDSEProperties] [Duration:00:00:00.0781235]
[01/15/2016 09:41:27.0055] [1] Evaluated [Setting:ConfigurationNamingContext] [HasException:False] [Value:""] [ParentValue:"<NULL>"] [Thread:19] [Duration:00:00:00.0781235]
[01/15/2016 09:41:27.0055] [1] Finished [Setting:ConfigurationNamingContext] [Duration:00:00:00.0781235]
[01/15/2016 09:41:27.0055] [1] Evaluated [Setting:MicrosoftExchServicesConfig] [HasException:False] [Value:"<NULL>"] [ParentValue:"<NULL>"] [Thread:19] [Duration:00:00:00.0781235]
[01/15/2016 09:41:27.0055] [1] Finished [Setting:MicrosoftExchServicesConfig] [Duration:00:00:00.0781235]
[01/15/2016 09:41:27.0055] [1] Evaluated [Setting:MicrosoftExchServicesConfigDistinguishedName] [HasException:False] [Value:""] [ParentValue:"<NULL>"] [Thread:19] [Duration:00:00:00.0937493]
[01/15/2016 09:41:27.0055] [1] Finished [Setting:MicrosoftExchServicesConfigDistinguishedName] [Duration:00:00:00.0937493]
[01/15/2016 09:41:27.0055] [1] Evaluated [Setting:ExchangeConfigurationUnitsConfiguration] [HasException:False] [Value:""] [ParentValue:"<NULL>"] [Thread:33] [Duration:00:00:00.0312490]
[01/15/2016 09:41:27.0055] [1] Finished [Setting:ExchangeConfigurationUnitsConfiguration] [Duration:00:00:00.0312490]
[01/15/2016 09:41:27.0055] [1] Evaluated [Setting:OrgMicrosoftExchServicesConfig] [HasException:False] [Value:"<NULL>"] [ParentValue:"<NULL>"] [Thread:19] [Duration:00:00:00.1406234]
[01/15/2016 09:41:27.0055] [1] Finished [Setting:OrgMicrosoftExchServicesConfig] [Duration:00:00:00.1406234]
[01/15/2016 09:41:27.0055] [1] Evaluated [Setting:OrgDistinguishedName] [HasException:False] [Value:""] [ParentValue:"<NULL>"] [Thread:17] [Duration:00:00:00.0937493]
[01/15/2016 09:41:27.0055] [1] Finished [Setting:OrgDistinguishedName] [Duration:00:00:00.0937493]
[01/15/2016 09:41:27.0055] [1] Evaluated [Setting:MicrosoftExchServicesAdminGroupsConfig] [HasException:False] [Value:"<NULL>"] [ParentValue:"<NULL>"] [Thread:24] [Duration:00:00:00.0312490]
[01/15/2016 09:41:27.0055] [1] Finished [Setting:MicrosoftExchServicesAdminGroupsConfig] [Duration:00:00:00.0312490]
[01/15/2016 09:41:27.0055] [1] Finished [Setting:ExchangeSerialNumber] [Duration:00:00:00.1406234]
[01/15/2016 09:41:27.0055] [1] Finished [Setting:Exchange200x] [Duration:00:00:00.1406234]
[01/15/2016 09:41:27.0055] [1] Evaluated [Rule:Exchange2000or2003PresentInOrg] [HasException:False] [Value:"False"] [ParentValue:"<NULL>"] [Thread:17] [Duration:00:00:00.1718718]
[01/15/2016 09:41:27.0055] [1] Finished [Rule:Exchange2000or2003PresentInOrg] [Duration:00:00:00.1718718]
[01/15/2016 09:41:27.0055] [1] Evaluated [Setting:RootNamingContext] [HasException:False] [Value:""] [ParentValue:"<NULL>"] [Thread:34] [Duration:00:00:00]
[01/15/2016 09:41:27.0055] [1] Finished [Setting:RootNamingContext] [Duration:00:00:00]
[01/15/2016 09:41:27.0055] [1] Evaluated [Setting:ExchangeConfigurationUnitsDomain] [HasException:False] [Value:""] [ParentValue:"<NULL>"] [Thread:34] [Duration:00:00:00.0312490]
[01/15/2016 09:41:27.0055] [1] Finished [Setting:ExchangeConfigurationUnitsDomain] [Duration:00:00:00.0312490]
[01/15/2016 09:41:27.0070] [1] Finished [Setting:ShortProvisionedName] [Duration:00:00:00.0468853]
[01/15/2016 09:41:27.0070] [1] Started [Setting:SmoRoleOwner] [Parent:RootAnalysisMember] [ValueType:String]
[01/15/2016 09:41:27.0070] [1] Started [Setting:SchemaDN] [Parent:RootAnalysisMember] [ValueType:ResultPropertyCollection]
[01/15/2016 09:41:27.0070] [1] Evaluated [Rule:SendConnectorException] [HasException:False] [Value:"False"] [ParentValue:"<NULL>"] [Thread:19] [Duration:00:00:00.1875081]
[01/15/2016 09:41:27.0070] [1] Finished [Rule:SendConnectorException] [Duration:00:00:00.1875081]
[01/15/2016 09:41:27.0070] [1] Started [Rule:HostingModeNotAvailable] [Parent:RootAnalysisMember] [RuleType:Error]
[01/15/2016 09:41:27.0070] [1] Evaluated [Rule:HostingModeNotAvailable] [HasException:False] [Value:"False"] [ParentValue:"<NULL>"] [Thread:6] [Duration:00:00:00]
[01/15/2016 09:41:27.0070] [1] Finished [Rule:HostingModeNotAvailable] [Duration:00:00:00]
[01/15/2016 09:41:27.0070] [1] Started [Rule:AdUpdateRequired] [Parent:RootAnalysisMember] [RuleType:Error]
[01/15/2016 09:41:27.0070] [1] Started [Rule:NotLocalAdmin] [Parent:RootAnalysisMember] [RuleType:Error]
[01/15/2016 09:41:27.0070] [1] Started [Rule:ProvisionedUpdateRequired] [Parent:RootAnalysisMember] [RuleType:Error]
[01/15/2016 09:41:27.0070] [1] Started [Rule:ForestLevelNotWin2003Native] [Parent:RootAnalysisMember] [RuleType:Error]
[01/15/2016 09:41:27.0070] [1] Started [Rule:InstallWatermark] [Parent:Watermarks] [RuleType:Error]
[01/15/2016 09:41:27.0070] [1] Started [Rule:E15E12CoexistenceMinVersionRequirement] [Parent:RootAnalysisMember] [RuleType:Error]
[01/15/2016 09:41:27.0070] [1] Started [Setting:SchemaNamingContext] [Parent:RootAnalysisMember] [ValueType:String]
[01/15/2016 09:41:27.0070] [1] Evaluated [Setting:ExchangeCurrentServerRoles] [HasException:False] [Value:"0"] [ParentValue:"<NULL>"] [Thread:24] [Duration:00:00:00.0781347]
[01/15/2016 09:41:27.0070] [1] Started [Setting:Watermarks] [Parent:ServerRoleUnpacked] [ValueType:String]
[01/15/2016 09:41:27.0070] [1] Started [Setting:ServerRoleUnpacked] [Parent:Roles] [ValueType:String]
[01/15/2016 09:41:27.0070] [1] Started [Setting:Roles] [Parent:RootAnalysisMember] [ValueType:String]
[01/15/2016 09:41:27.0070] [1] Finished [Setting:ExchangeCurrentServerRoles] [Duration:00:00:00.0781347]
[01/15/2016 09:41:27.0086] [1] Started [Setting:E12ServersNotMinVersionRequirement] [Parent:RootAnalysisMember] [ValueType:String]
[01/15/2016 09:41:27.0086] [1] Evaluated [Setting:SchemaNamingContext] [HasException:False] [Value:""] [ParentValue:"<NULL>"] [Thread:35] [Duration:00:00:00.0156173]
[01/15/2016 09:41:27.0086] [1] Finished [Setting:SchemaNamingContext] [Duration:00:00:00.0156173]
[01/15/2016 09:41:27.0086] [1] Evaluated [Setting:SchemaDN] [HasException:False] [Value:"<NULL>"] [ParentValue:"<NULL>"] [Thread:35] [Duration:00:00:00.0156173]
[01/15/2016 09:41:27.0086] [1] Finished [Setting:SchemaDN] [Duration:00:00:00.0156173]
[01/15/2016 09:41:27.0086] [1] Evaluated [Setting:SmoRoleOwner] [HasException:False] [Value:""] [ParentValue:"<NULL>"] [Thread:35] [Duration:00:00:00.0156173]
[01/15/2016 09:41:27.0086] [1] Finished [Setting:SmoRoleOwner] [Duration:00:00:00.0156173]
[01/15/2016 09:41:27.0086] [1] Evaluated [Setting:SmoSchemaDN] [HasException:False] [Value:"<NULL>"] [ParentValue:"<NULL>"] [Thread:35] [Duration:00:00:00.0468780]
[01/15/2016 09:41:27.0086] [1] Finished [Setting:SmoSchemaDN] [Duration:00:00:00.0468780]
[01/15/2016 09:41:27.0086] [1] Evaluated [Setting:DnsHostName] [HasException:False] [Value:""] [ParentValue:"<NULL>"] [Thread:35] [Duration:00:00:00.0625026]
[01/15/2016 09:41:27.0086] [1] Finished [Setting:DnsHostName] [Duration:00:00:00.0625026]
[01/15/2016 09:41:27.0086] [1] Started [Setting:MsDSBehaviorVersion] [Parent:RootAnalysisMember] [ValueType:Int32]
[01/15/2016 09:41:27.0086] [1] Evaluated [Setting:Roles] [HasException:False] [Value:"Transport"] [ParentValue:"<NULL>"] [Thread:38] [Duration:00:00:00.0156173]
[01/15/2016 09:41:27.0086] [1] Started [Setting:LocalAdmin] [Parent:RootAnalysisMember] [ValueType:Boolean]
[01/15/2016 09:41:27.0086] [1] Started [Setting:HasExtendedRightsCreateChildPerms] [Parent:RootAnalysisMember] [ValueType:Boolean]
[01/15/2016 09:41:27.0086] [1] Started [Setting:ExtendedRightsNtSecurityDescriptor] [Parent:RootAnalysisMember] [ValueType:String]
[01/15/2016 09:41:27.0086] [1] Evaluated [Setting:ServerRoleUnpacked] [HasException:False] [Value:"Transport"] [ParentValue:"Transport"] [Thread:38] [Duration:00:00:00.0156173]
[01/15/2016 09:41:27.0101] [1] Started [Setting:NewProvisionedServerName] [Parent:RootAnalysisMember] [ValueType:String]
[01/15/2016 09:41:27.0101] [1] Evaluated [Setting:NewProvisionedServerName] [HasException:False] [Value:""] [ParentValue:"<NULL>"] [Thread:8] [Duration:00:00:00]
[01/15/2016 09:41:27.0101] [1] Finished [Setting:NewProvisionedServerName] [Duration:00:00:00]
[01/15/2016 09:41:27.0101] [1] Evaluated [Rule:ProvisionedUpdateRequired] [HasException:False] [Value:"False"] [ParentValue:"<NULL>"] [Thread:8] [Duration:00:00:00.0312398]
[01/15/2016 09:41:27.0101] [1] Finished [Rule:ProvisionedUpdateRequired] [Duration:00:00:00.0312398]
[01/15/2016 09:41:27.0101] [1] Evaluated [Setting:LocalAdmin] [HasException:False] [Value:"True"] [ParentValue:"<NULL>"] [Thread:9] [Duration:00:00:00.0156225]
[01/15/2016 09:41:27.0101] [1] Finished [Setting:LocalAdmin] [Duration:00:00:00.0156225]
[01/15/2016 09:41:27.0101] [1] Evaluated [Rule:NotLocalAdmin] [HasException:False] [Value:"False"] [ParentValue:"<NULL>"] [Thread:9] [Duration:00:00:00.0312398]
[01/15/2016 09:41:27.0101] [1] Finished [Rule:NotLocalAdmin] [Duration:00:00:00.0312398]
[01/15/2016 09:41:27.0101] [1] Evaluated [Setting:MsDSBehaviorVersion] [HasException:False] [Value:"0"] [ParentValue:"<NULL>"] [Thread:5] [Duration:00:00:00.0156225]
[01/15/2016 09:41:27.0101] [1] Finished [Setting:MsDSBehaviorVersion] [Duration:00:00:00.0156225]
[01/15/2016 09:41:27.0101] [1] Evaluated [Setting:ExtendedRightsNtSecurityDescriptor] [HasException:False] [Value:""] [ParentValue:"<NULL>"] [Thread:10] [Duration:00:00:00.0156225]
[01/15/2016 09:41:27.0101] [1] Finished [Setting:ExtendedRightsNtSecurityDescriptor] [Duration:00:00:00.0156225]
[01/15/2016 09:41:27.0101] [1] Evaluated [Setting:Watermarks] [HasException:False] [Value:"<NULL>"] [ParentValue:"Transport"] [Thread:38] [Duration:00:00:00.0312398]
[01/15/2016 09:41:27.0101] [1] Evaluated [Rule:InstallWatermark] [HasException:False] [Value:"False"] [ParentValue:"<NULL>"] [Thread:38] [Duration:00:00:00.0312398]
[01/15/2016 09:41:27.0101] [1] Finished [Setting:Roles] [Duration:00:00:00.0312398]
[01/15/2016 09:41:27.0101] [1] Finished [Setting:ServerRoleUnpacked] [Duration:00:00:00.0312398]
[01/15/2016 09:41:27.0101] [1] Finished [Setting:Watermarks] [Duration:00:00:00.0312398]
[01/15/2016 09:41:27.0101] [1] Finished [Rule:InstallWatermark] [Duration:00:00:00.0312398]
[01/15/2016 09:41:27.0101] [1] Evaluated [Setting:SMOSchemaSiteName] [HasException:False] [Value:"Default-First-Site-Name"] [ParentValue:"<NULL>"] [Thread:35] [Duration:00:00:00.0781251]
[01/15/2016 09:41:27.0101] [1] Finished [Setting:SMOSchemaSiteName] [Duration:00:00:00.0781251]
[01/15/2016 09:41:27.0101] [1] Evaluated [Setting:E12ServersNotMinVersionRequirement] [HasException:False] [Value:""] [ParentValue:"<NULL>"] [Thread:37] [Duration:00:00:00.0156225]
[01/15/2016 09:41:27.0101] [1] Finished [Setting:E12ServersNotMinVersionRequirement] [Duration:00:00:00.0156225]
[01/15/2016 09:41:27.0101] [1] Evaluated [Rule:E15E12CoexistenceMinVersionRequirement] [HasException:False] [Value:"False"] [ParentValue:"<NULL>"] [Thread:37] [Duration:00:00:00.0312398]
[01/15/2016 09:41:27.0101] [1] Finished [Rule:E15E12CoexistenceMinVersionRequirement] [Duration:00:00:00.0312398]
[01/15/2016 09:41:27.0117] [1] Evaluated [Rule:RebootPending] [HasException:False] [Value:"False"] [ParentValue:"<NULL>"] [Thread:18] [Duration:00:00:00.2343751]
[01/15/2016 09:41:27.0117] [1] Finished [Rule:RebootPending] [Duration:00:00:00.2343751]
[01/15/2016 09:41:27.0117] [1] Started [Rule:E15E14CoexistenceMinVersionRequirementForDC] [Parent:RootAnalysisMember] [RuleType:Warning]
[01/15/2016 09:41:27.0117] [1] Started [Setting:FileVersionLdifde] [Parent:RootAnalysisMember] [ValueType:Version]
[01/15/2016 09:41:27.0117] [1] Started [Rule:SchemaFSMONotWin2003SPn] [Parent:RootAnalysisMember] [RuleType:Error]
[01/15/2016 09:41:27.0117] [1] Started [Rule:CannotAccessAD] [Parent:RootAnalysisMember] [RuleType:Error]
[01/15/2016 09:41:27.0117] [1] Evaluated [Rule:W2K8R2PrepareSchemaLdifdeNotInstalled] [HasException:False] [Value:"False"] [ParentValue:"<NULL>"] [Thread:15] [Duration:00:00:00.2343751]
[01/15/2016 09:41:27.0117] [1] Finished [Rule:W2K8R2PrepareSchemaLdifdeNotInstalled] [Duration:00:00:00.2343751]
[01/15/2016 09:41:27.0117] [1] Started [Rule:ExchangeVersionBlock] [Parent:RootAnalysisMember] [RuleType:Error]
[01/15/2016 09:41:27.0117] [1] Evaluated [Rule:E15E14CoexistenceMinVersionRequirementForDC] [HasException:False] [Value:"False"] [ParentValue:"<NULL>"] [Thread:37] [Duration:00:00:00]
[01/15/2016 09:41:27.0117] [1] Finished [Rule:E15E14CoexistenceMinVersionRequirementForDC] [Duration:00:00:00]
[01/15/2016 09:41:27.0117] [1] Started [Rule:WindowsServer2008CoreServerEdition] [Parent:RootAnalysisMember] [RuleType:Error]
[01/15/2016 09:41:27.0117] [1] Evaluated [Rule:CannotAccessAD] [HasException:False] [Value:"True"] [ParentValue:"<NULL>"] [Thread:38] [Duration:00:00:00]
[01/15/2016 09:41:27.0117] [1] Finished [Rule:CannotAccessAD] [Duration:00:00:00]
[01/15/2016 09:41:27.0117] [1] Started [Rule:ConfigDCHostNameMismatch] [Parent:RootAnalysisMember] [RuleType:Error]
[01/15/2016 09:41:27.0117] [1] Started [Setting:WindowsPath] [Parent:RootAnalysisMember] [ValueType:String]
[01/15/2016 09:41:27.0117] [1] Evaluated [Setting:WindowsPath] [HasException:False] [Value:"C:\Windows"] [ParentValue:"<NULL>"] [Thread:16] [Duration:00:00:00]
[01/15/2016 09:41:27.0117] [1] Finished [Setting:WindowsPath] [Duration:00:00:00]
[01/15/2016 09:41:27.0117] [1] Started [Setting:ConfigDCHostName] [Parent:RootAnalysisMember] [ValueType:String]
[01/15/2016 09:41:27.0117] [1] Started [Rule:SetADSplitPermissionWhenExchangeServerRolesOnDC] [Parent:RootAnalysisMember] [RuleType:Error]
[01/15/2016 09:41:27.0117] [1] Started [Setting:Win2003FSMOSchemaServer] [Parent:RootAnalysisMember] [ValueType:Boolean]
[01/15/2016 09:41:27.0117] [1] Evaluated [Setting:GatewayRoleInstalled] [HasException:False] [Value:"False"] [ParentValue:"<NULL>"] [Thread:31] [Duration:00:00:00.1093761]
[01/15/2016 09:41:27.0117] [1] Finished [Setting:GatewayRoleInstalled] [Duration:00:00:00.1093761]
[01/15/2016 09:41:27.0117] [1] Evaluated [Rule:ForestLevelNotWin2003Native] [HasException:False] [Value:"True"] [ParentValue:"<NULL>"] [Thread:5] [Duration:00:00:00.0468670]
[01/15/2016 09:41:27.0117] [1] Finished [Rule:ForestLevelNotWin2003Native] [Duration:00:00:00.0468670]
[01/15/2016 09:41:27.0117] [1] Started [Rule:PrepareDomainNotFound] [Parent:RootAnalysisMember] [RuleType:Error]
[01/15/2016 09:41:27.0133] [1] Evaluated [Setting:ServerIsProvisioned] [HasException:False] [Value:"False"] [ParentValue:"<NULL>"] [Thread:32] [Duration:00:00:00.1093761]
[01/15/2016 09:41:27.0133] [1] Finished [Setting:ServerIsProvisioned] [Duration:00:00:00.1249995]
[01/15/2016 09:41:27.0133] [1] Evaluated [Setting:FrontendTransportRoleInstalled] [HasException:False] [Value:"False"] [ParentValue:"<NULL>"] [Thread:28] [Duration:00:00:00.1718760]
[01/15/2016 09:41:27.0133] [1] Started [Setting:SmoOperatingSystemVersion] [Parent:RootAnalysisMember] [ValueType:String]
[01/15/2016 09:41:27.0133] [1] Finished [Setting:FrontendTransportRoleInstalled] [Duration:00:00:00.1718760]
[01/15/2016 09:41:27.0133] [1] Started [Setting:WindowsVersion] [Parent:RootAnalysisMember] [ValueType:String]
[01/15/2016 09:41:27.0133] [1] Evaluated [Setting:MailboxRoleInstalled] [HasException:False] [Value:"False"] [ParentValue:"<NULL>"] [Thread:24] [Duration:00:00:00.2030986]
[01/15/2016 09:41:27.0133] [1] Finished [Setting:MailboxRoleInstalled] [Duration:00:00:00.2030986]
[01/15/2016 09:41:27.0133] [1] Started [Setting:ActiveDirectorySplitPermissions] [Parent:RootAnalysisMember] [ValueType:Boolean]
[01/15/2016 09:41:27.0133] [1] Evaluated [Setting:CafeRoleInstalled] [HasException:False] [Value:"False"] [ParentValue:"<NULL>"] [Thread:27] [Duration:00:00:00.1718760]
[01/15/2016 09:41:27.0133] [1] Started [Setting:PrepareDomain] [Parent:RootAnalysisMember] [ValueType:String]
[01/15/2016 09:41:27.0133] [1] Finished [Setting:CafeRoleInstalled] [Duration:00:00:00.1718760]
[01/15/2016 09:41:27.0133] [1] Evaluated [Setting:ConfigDCHostName] [HasException:True] [Value:
Expected failure for ConfigDCHostName:The registry key, HKEY_LOCAL_MACHINE\System\CurrentControlSet\Services\MSExchange ADAccess\Instance0, wasn't found.
] [ParentValue:"<NULL>"] [Thread:38] [Duration:00:00:00.0156234]
[01/15/2016 09:41:27.0133] [1] Finished [Setting:ConfigDCHostName] [Duration:00:00:00.0156234]
[01/15/2016 09:41:27.0133] [1] Evaluated [Rule:ConfigDCHostNameMismatch] [HasException:False] [Value:"False"] [ParentValue:"<NULL>"] [Thread:38] [Duration:00:00:00.0156234]
[01/15/2016 09:41:27.0133] [1] Finished [Rule:ConfigDCHostNameMismatch] [Duration:00:00:00.0156234]
[01/15/2016 09:41:27.0133] [1] Started [Rule:WindowsInstallerServiceDisabledOrNotInstalled] [Parent:RootAnalysisMember] [RuleType:Error]
[01/15/2016 09:41:27.0133] [1] Evaluated [Setting:ActiveDirectorySplitPermissions] [HasException:False] [Value:"False"] [ParentValue:"<NULL>"] [Thread:6] [Duration:00:00:00]
[01/15/2016 09:41:27.0133] [1] Finished [Setting:ActiveDirectorySplitPermissions] [Duration:00:00:00]
[01/15/2016 09:41:27.0133] [1] Evaluated [Rule:SetADSplitPermissionWhenExchangeServerRolesOnDC] [HasException:False] [Value:"False"] [ParentValue:"<NULL>"] [Thread:6] [Duration:00:00:00.0156234]
[01/15/2016 09:41:27.0133] [1] Finished [Rule:SetADSplitPermissionWhenExchangeServerRolesOnDC] [Duration:00:00:00.0156234]
[01/15/2016 09:41:27.0133] [1] Started [Rule:LoggedOntoDomain] [Parent:RootAnalysisMember] [RuleType:Error]
[01/15/2016 09:41:27.0133] [1] Evaluated [Setting:PrepareDomain] [HasException:False] [Value:"F63C3A12-7852-4654-B208-125C32EB409A"] [ParentValue:"<NULL>"] [Thread:5] [Duration:00:00:00]
[01/15/2016 09:41:27.0133] [1] Finished [Setting:PrepareDomain] [Duration:00:00:00]
[01/15/2016 09:41:27.0133] [1] Evaluated [Rule:PrepareDomainNotFound] [HasException:False] [Value:"False"] [ParentValue:"<NULL>"] [Thread:5] [Duration:00:00:00.0156234]
[01/15/2016 09:41:27.0133] [1] Finished [Rule:PrepareDomainNotFound] [Duration:00:00:00.0156234]
[01/15/2016 09:41:27.0133] [1] Started [Rule:PrepareDomainModeMixed] [Parent:RootAnalysisMember] [RuleType:Error]
[01/15/2016 09:41:27.0133] [1] Evaluated [Setting:UnifiedMessagingRoleInstalled] [HasException:False] [Value:"False"] [ParentValue:"<NULL>"] [Thread:29] [Duration:00:00:00.1562502]
[01/15/2016 09:41:27.0133] [1] Finished [Setting:UnifiedMessagingRoleInstalled] [Duration:00:00:00.1562502]
[01/15/2016 09:41:27.0133] [1] Evaluated [Setting:BridgeheadRoleInstalled] [HasException:False] [Value:"False"] [ParentValue:"<NULL>"] [Thread:30] [Duration:00:00:00.1249995]
[01/15/2016 09:41:27.0133] [1] Finished [Setting:BridgeheadRoleInstalled] [Duration:00:00:00.1249995]
[01/15/2016 09:41:27.0133] [1] Evaluated [Setting:WindowsVersion] [HasException:False] [Value:"6.3"] [ParentValue:"<NULL>"] [Thread:37] [Duration:00:00:00]
[01/15/2016 09:41:27.0133] [1] Finished [Setting:WindowsVersion] [Duration:00:00:00]
[01/15/2016 09:41:27.0133] [1] Evaluated [Rule:WindowsServer2008CoreServerEdition] [HasException:False] [Value:"False"] [ParentValue:"<NULL>"] [Thread:37] [Duration:00:00:00.0156234]
[01/15/2016 09:41:27.0133] [1] Finished [Rule:WindowsServer2008CoreServerEdition] [Duration:00:00:00.0156234]
[01/15/2016 09:41:27.0133] [1] Started [Rule:ServicesAreMarkedForDeletion] [Parent:RootAnalysisMember] [RuleType:Error]
[01/15/2016 09:41:27.0133] [1] Started [Setting:CurrentLogOn] [Parent:RootAnalysisMember] [ValueType:String]
[01/15/2016 09:41:27.0133] [1] Started [Setting:WindowsInstallerServiceStartMode] [Parent:RootAnalysisMember] [ValueType:Int32]
[01/15/2016 09:41:27.0133] [1] Started [Setting:SmoRoleSchemaRef] [Parent:RootAnalysisMember] [ValueType:ResultPropertyCollection]
[01/15/2016 09:41:27.0148] [1] Evaluated [Setting:WindowsInstallerServiceStartMode] [HasException:False] [Value:"3"] [ParentValue:"<NULL>"] [Thread:38] [Duration:00:00:00]
[01/15/2016 09:41:27.0148] [1] Finished [Setting:WindowsInstallerServiceStartMode] [Duration:00:00:00.0156267]
[01/15/2016 09:41:27.0148] [1] Started [Setting:NtMixedDomainPrepareDomain] [Parent:RootAnalysisMember] [ValueType:Int32]
[01/15/2016 09:41:27.0148] [1] Evaluated [Rule:WindowsInstallerServiceDisabledOrNotInstalled] [HasException:False] [Value:"False"] [ParentValue:"<NULL>"] [Thread:38] [Duration:00:00:00.0156267]
[01/15/2016 09:41:27.0148] [1] Finished [Rule:WindowsInstallerServiceDisabledOrNotInstalled] [Duration:00:00:00.0156267]
[01/15/2016 09:41:27.0148] [1] Started [Rule:WinRMServiceDisabledOrNotInstalled] [Parent:RootAnalysisMember] [RuleType:Error]
[01/15/2016 09:41:27.0148] [1] Evaluated [Setting:ClientAccessRoleInstalled] [HasException:False] [Value:"False"] [ParentValue:"<NULL>"] [Thread:26] [Duration:00:00:00.1874959]
[01/15/2016 09:41:27.0148] [1] Finished [Setting:ClientAccessRoleInstalled] [Duration:00:00:00.2031226]
[01/15/2016 09:41:27.0148] [1] Started [Setting:ServiceMarkedForDeletion] [Parent:RootAnalysisMember] [ValueType:String]
[01/15/2016 09:41:27.0148] [1] The revision level is unknown
[01/15/2016 09:41:27.0148] [1] Started [Setting:WinRMServiceStartMode] [Parent:RootAnalysisMember] [ValueType:Int32]
[01/15/2016 09:41:27.0148] [1] Evaluated [Setting:WinRMServiceStartMode] [HasException:False] [Value:"2"] [ParentValue:"<NULL>"] [Thread:38] [Duration:00:00:00]
[01/15/2016 09:41:27.0148] [1] Finished [Setting:WinRMServiceStartMode] [Duration:00:00:00]
[01/15/2016 09:41:27.0148] [1] Evaluated [Rule:WinRMServiceDisabledOrNotInstalled] [HasException:False] [Value:"False"] [ParentValue:"<NULL>"] [Thread:38] [Duration:00:00:00]
[01/15/2016 09:41:27.0148] [1] Finished [Rule:WinRMServiceDisabledOrNotInstalled] [Duration:00:00:00]
[01/15/2016 09:41:27.0148] [1] Started [Rule:E15E14CoexistenceMinVersionRequirement] [Parent:RootAnalysisMember] [RuleType:Warning]
[01/15/2016 09:41:27.0164] [1] Started [Setting:E14ServersNotMinVersionRequirement] [Parent:RootAnalysisMember] [ValueType:String]
[01/15/2016 09:41:27.0164] [1] Evaluated [Setting:HasExtendedRightsCreateChildPerms] [HasException:False] [Value:"False"] [ParentValue:"<NULL>"] [Thread:10] [Duration:00:00:00.0781678]
[01/15/2016 09:41:27.0164] [1] Finished [Setting:HasExtendedRightsCreateChildPerms] [Duration:00:00:00.0781678]
[01/15/2016 09:41:27.0164] [1] Started [Rule:GlobalUpdateRequired] [Parent:RootAnalysisMember] [RuleType:Error]
[01/15/2016 09:41:27.0164] [1] Started [Setting:PrepareDomainNCNameConfig] [Parent:RootAnalysisMember] [ValueType:ResultPropertyCollection]
[01/15/2016 09:41:27.0164] [1] Started [Setting:ServerReference] [Parent:RootAnalysisMember] [ValueType:String]
[01/15/2016 09:41:27.0164] [1] Evaluated [Setting:CurrentLogOn] [HasException:False] [Value:"Domein\administrator"] [ParentValue:"<NULL>"] [Thread:6] [Duration:00:00:00.0312947]
[01/15/2016 09:41:27.0164] [1] Finished [Setting:CurrentLogOn] [Duration:00:00:00.0312947]
[01/15/2016 09:41:27.0164] [1] Started [Setting:LocalServerName] [Parent:RootAnalysisMember] [ValueType:String]
[01/15/2016 09:41:27.0164] [1] Started [Setting:EnterpriseAdmin] [Parent:RootAnalysisMember] [ValueType:Boolean]
[01/15/2016 09:41:27.0183] [1] Started [Setting:SidRootDomain] [Parent:RootAnalysisMember] [ValueType:String]
[01/15/2016 09:41:27.0183] [1] Evaluated [Setting:ServerReference] [HasException:False] [Value:""] [ParentValue:"<NULL>"] [Thread:8] [Duration:00:00:00.0191807]
[01/15/2016 09:41:27.0183] [1] Finished [Setting:ServerReference] [Duration:00:00:00.0191807]
[01/15/2016 09:41:27.0183] [1] Evaluated [Setting:SmoRoleSchemaRef] [HasException:False] [Value:"<NULL>"] [ParentValue:"<NULL>"] [Thread:8] [Duration:00:00:00.0504754]
[01/15/2016 09:41:27.0183] [1] Finished [Setting:SmoRoleSchemaRef] [Duration:00:00:00.0504754]
[01/15/2016 09:41:27.0183] [1] Evaluated [Setting:SmoOperatingSystemVersion] [HasException:False] [Value:""] [ParentValue:"<NULL>"] [Thread:8] [Duration:00:00:00.0504754]
[01/15/2016 09:41:27.0183] [1] Finished [Setting:SmoOperatingSystemVersion] [Duration:00:00:00.0504754]
[01/15/2016 09:41:27.0183] [1] Evaluated [Setting:Win2003FSMOSchemaServer] [HasException:False] [Value:"False"] [ParentValue:"<NULL>"] [Thread:8] [Duration:00:00:00.0660988]
[01/15/2016 09:41:27.0183] [1] Finished [Setting:Win2003FSMOSchemaServer] [Duration:00:00:00.0660988]
[01/15/2016 09:41:27.0183] [1] Evaluated [Rule:SchemaFSMONotWin2003SPn] [HasException:False] [Value:"False"] [ParentValue:"<NULL>"] [Thread:8] [Duration:00:00:00.0660988]
[01/15/2016 09:41:27.0183] [1] Finished [Rule:SchemaFSMONotWin2003SPn] [Duration:00:00:00.0660988]
[01/15/2016 09:41:27.0183] [1] Started [Setting:PrepareDomainNCName] [Parent:RootAnalysisMember] [ValueType:String]
[01/15/2016 09:41:27.0183] [1] Started [Rule:DomainControllerIsOutOfSite] [Parent:RootAnalysisMember] [RuleType:Error]
[01/15/2016 09:41:27.0183] [1] Evaluated [Setting:E14ServersNotMinVersionRequirement] [HasException:False] [Value:""] [ParentValue:"<NULL>"] [Thread:38] [Duration:00:00:00.0191807]
[01/15/2016 09:41:27.0183] [1] Finished [Setting:E14ServersNotMinVersionRequirement] [Duration:00:00:00.0191807]
[01/15/2016 09:41:27.0183] [1] Evaluated [Rule:E15E14CoexistenceMinVersionRequirement] [HasException:False] [Value:"False"] [ParentValue:"<NULL>"] [Thread:38] [Duration:00:00:00.0348487]
[01/15/2016 09:41:27.0183] [1] Finished [Rule:E15E14CoexistenceMinVersionRequirement] [Duration:00:00:00.0348487]
[01/15/2016 09:41:27.0183] [1] Started [Rule:E15E14CoexistenceMinMajorVersionRequirement] [Parent:RootAnalysisMember] [RuleType:Error]
[01/15/2016 09:41:27.0183] [1] Started [Setting:E14ServersNotMinMajorVersionRequirement] [Parent:RootAnalysisMember] [ValueType:String]
[01/15/2016 09:41:27.0195] [1] Started [Setting:SiteName] [Parent:RootAnalysisMember] [ValueType:String]
[01/15/2016 09:41:27.0195] [1] Started [Setting:ExchangeVersionPrefix] [Parent:RootAnalysisMember] [ValueType:Single]
[01/15/2016 09:41:27.0195] [1] Evaluated [Setting:SiteName] [HasException:False] [Value:"Default-First-Site-Name"] [ParentValue:"<NULL>"] [Thread:8] [Duration:00:00:00]
[01/15/2016 09:41:27.0195] [1] Finished [Setting:SiteName] [Duration:00:00:00]
[01/15/2016 09:41:27.0195] [1] Started [Setting:DomainControllerSiteName] [Parent:RootAnalysisMember] [ValueType:String]
[01/15/2016 09:41:27.0195] [1] Started [Setting:RootDN] [Parent:RootAnalysisMember] [ValueType:ResultPropertyCollection]
[01/15/2016 09:41:27.0195] [1] Started [Setting:DomainController] [Parent:RootAnalysisMember] [ValueType:String]
[01/15/2016 09:41:27.0195] [1] Evaluated [Setting:DomainController] [HasException:False] [Value:""] [ParentValue:"<NULL>"] [Thread:8] [Duration:00:00:00]
[01/15/2016 09:41:27.0195] [1] Finished [Setting:DomainController] [Duration:00:00:00]
[01/15/2016 09:41:27.0195] [1] Evaluated [Setting:DomainControllerSiteName] [HasException:False] [Value:"Default-First-Site-Name"] [ParentValue:"<NULL>"] [Thread:8] [Duration:00:00:00]
[01/15/2016 09:41:27.0195] [1] Finished [Setting:DomainControllerSiteName] [Duration:00:00:00]
[01/15/2016 09:41:27.0195] [1] Evaluated [Rule:DomainControllerIsOutOfSite] [HasException:False] [Value:"False"] [ParentValue:"<NULL>"] [Thread:8] [Duration:00:00:00.0120242]
[01/15/2016 09:41:27.0195] [1] Finished [Rule:DomainControllerIsOutOfSite] [Duration:00:00:00.0120242]
[01/15/2016 09:41:27.0195] [1] Started [Rule:DidTenantSettingCreatedAnException] [Parent:RootAnalysisMember] [RuleType:Error]
[01/15/2016 09:41:27.0211] [1] Evaluated [Setting:PrepareDomainNCName] [HasException:False] [Value:""] [ParentValue:"<NULL>"] [Thread:5] [Duration:00:00:00.0276955]
[01/15/2016 09:41:27.0211] [1] Finished [Setting:PrepareDomainNCName] [Duration:00:00:00.0276955]
[01/15/2016 09:41:27.0211] [1] Evaluated [Setting:PrepareDomainNCNameConfig] [HasException:False] [Value:"<NULL>"] [ParentValue:"<NULL>"] [Thread:5] [Duration:00:00:00.0468762]
[01/15/2016 09:41:27.0211] [1] Finished [Setting:PrepareDomainNCNameConfig] [Duration:00:00:00.0468762]
[01/15/2016 09:41:27.0211] [1] Evaluated [Setting:NtMixedDomainPrepareDomain] [HasException:False] [Value:"0"] [ParentValue:"<NULL>"] [Thread:5] [Duration:00:00:00.0625442]
[01/15/2016 09:41:27.0211] [1] Finished [Setting:NtMixedDomainPrepareDomain] [Duration:00:00:00.0625442]
[01/15/2016 09:41:27.0211] [1] Evaluated [Rule:PrepareDomainModeMixed] [HasException:False] [Value:"False"] [ParentValue:"<NULL>"] [Thread:5] [Duration:00:00:00.0781709]
[01/15/2016 09:41:27.0211] [1] Finished [Rule:PrepareDomainModeMixed] [Duration:00:00:00.0781709]
[01/15/2016 09:41:27.0211] [1] Started [Rule:RusMissing] [Parent:RootAnalysisMember] [RuleType:Warning]
[01/15/2016 09:41:27.0211] [1] Evaluated [Setting:E14ServersNotMinMajorVersionRequirement] [HasException:False] [Value:""] [ParentValue:"<NULL>"] [Thread:38] [Duration:00:00:00.0276955]
[01/15/2016 09:41:27.0211] [1] Finished [Setting:E14ServersNotMinMajorVersionRequirement] [Duration:00:00:00.0276955]
[01/15/2016 09:41:27.0211] [1] Evaluated [Rule:E15E14CoexistenceMinMajorVersionRequirement] [HasException:False] [Value:"False"] [ParentValue:"<NULL>"] [Thread:38] [Duration:00:00:00.0276955]
[01/15/2016 09:41:27.0211] [1] Finished [Rule:E15E14CoexistenceMinMajorVersionRequirement] [Duration:00:00:00.0276955]
[01/15/2016 09:41:27.0211] [1] Started [Rule:InvalidADSite] [Parent:RootAnalysisMember] [RuleType:Error]
[01/15/2016 09:41:27.0211] [1] Evaluated [Setting:RootDN] [HasException:False] [Value:"<NULL>"] [ParentValue:"<NULL>"] [Thread:10] [Duration:00:00:00.0156713]
[01/15/2016 09:41:27.0211] [1] Finished [Setting:RootDN] [Duration:00:00:00.0156713]
[01/15/2016 09:41:27.0211] [1] Evaluated [Setting:SidRootDomain] [HasException:False] [Value:""] [ParentValue:"<NULL>"] [Thread:10] [Duration:00:00:00.0276955]
[01/15/2016 09:41:27.0211] [1] Finished [Setting:SidRootDomain] [Duration:00:00:00.0276955]
[01/15/2016 09:41:27.0211] [1] Evaluated [Rule:InvalidADSite] [HasException:False] [Value:"False"] [ParentValue:"<NULL>"] [Thread:38] [Duration:00:00:00]
[01/15/2016 09:41:27.0211] [1] Finished [Rule:InvalidADSite] [Duration:00:00:00]
[01/15/2016 09:41:27.0211] [1] Started [Rule:SchemaUpdateRequired] [Parent:RootAnalysisMember] [RuleType:Error]
[01/15/2016 09:41:27.0211] [1] The security ID structure is invalid
[01/15/2016 09:41:27.0211] [1] Evaluated [Setting:EnterpriseAdmin] [HasException:False] [Value:"False"] [ParentValue:"<NULL>"] [Thread:10] [Duration:00:00:00.0468762]
[01/15/2016 09:41:27.0211] [1] Finished [Setting:EnterpriseAdmin] [Duration:00:00:00.0468762]
[01/15/2016 09:41:27.0211] [1] Evaluated [Rule:GlobalUpdateRequired] [HasException:False] [Value:"True"] [ParentValue:"<NULL>"] [Thread:10] [Duration:00:00:00.0468762]
[01/15/2016 09:41:27.0211] [1] Finished [Rule:GlobalUpdateRequired] [Duration:00:00:00.0468762]
[01/15/2016 09:41:27.0211] [1] Evaluated [Rule:AdUpdateRequired] [HasException:False] [Value:"False"] [ParentValue:"<NULL>"] [Thread:10] [Duration:00:00:00.1406613]
[01/15/2016 09:41:27.0211] [1] Finished [Rule:AdUpdateRequired] [Duration:00:00:00.1406613]
[01/15/2016 09:41:27.0211] [1] Started [Setting:IsHybridObjectFoundOnPremises] [Parent:RootAnalysisMember] [ValueType:Boolean]
[01/15/2016 09:41:27.0211] [1] Started [Rule:DomainPrepWithoutADUpdate] [Parent:RootAnalysisMember] [RuleType:Error]
[01/15/2016 09:41:27.0211] [1] Evaluated [Rule:SchemaUpdateRequired] [HasException:False] [Value:"False"] [ParentValue:"<NULL>"] [Thread:38] [Duration:00:00:00]
[01/15/2016 09:41:27.0211] [1] Finished [Rule:SchemaUpdateRequired] [Duration:00:00:00]
[01/15/2016 09:41:27.0211] [1] Started [Rule:LocalDomainPrep] [Parent:RootAnalysisMember] [RuleType:Error]
[01/15/2016 09:41:27.0211] [1] Started [Setting:WasSetupStartedFromGUI] [Parent:RootAnalysisMember] [ValueType:Boolean]
[01/15/2016 09:41:27.0211] [1] Started [Setting:RusName] [Parent:RootAnalysisMember] [ValueType:String]
[01/15/2016 09:41:27.0226] [1] Started [Setting:LocalDomainAdmin] [Parent:RootAnalysisMember] [ValueType:Boolean]
[01/15/2016 09:41:27.0226] [1] Started [Setting:LocalDomainNtSecurityDescriptor] [Parent:RootAnalysisMember] [ValueType:String]
[01/15/2016 09:41:27.0226] [1] Started [Setting:LocalComputerDomainDN] [Parent:RootAnalysisMember] [ValueType:ResultPropertyCollection]
[01/15/2016 09:41:27.0226] [1] Evaluated [Setting:ExchangeVersionPrefix] [HasException:False] [Value:"0"] [ParentValue:"<NULL>"] [Thread:9] [Duration:00:00:00.0312513]
[01/15/2016 09:41:27.0226] [1] Finished [Setting:ExchangeVersionPrefix] [Duration:00:00:00.0312513]
[01/15/2016 09:41:27.0242] [1] Evaluated [Setting:RusName] [HasException:False] [Value:""] [ParentValue:"<NULL>"] [Thread:5] [Duration:00:00:00.0312681]
[01/15/2016 09:41:27.0242] [1] Finished [Setting:RusName] [Duration:00:00:00.0312681]
[01/15/2016 09:41:27.0242] [1] Evaluated [Rule:RusMissing] [HasException:False] [Value:"False"] [ParentValue:"<NULL>"] [Thread:5] [Duration:00:00:00.0312681]
[01/15/2016 09:41:27.0242] [1] Finished [Rule:RusMissing] [Duration:00:00:00.0312681]
[01/15/2016 09:41:27.0242] [1] Started [Rule:ServerFQDNMatchesSMTPPolicy] [Parent:RootAnalysisMember] [RuleType:Error]
[01/15/2016 09:41:27.0242] [1] Started [Setting:GatewayProxy] [Parent:RootAnalysisMember] [ValueType:String]
[01/15/2016 09:41:27.0242] [1] Evaluated [Rule:ExchangeVersionBlock] [HasException:False] [Value:"False"] [ParentValue:"<NULL>"] [Thread:9] [Duration:00:00:00.1250624]
[01/15/2016 09:41:27.0242] [1] Finished [Rule:ExchangeVersionBlock] [Duration:00:00:00.1250624]
[01/15/2016 09:41:27.0242] [1] Started [Rule:AdInitErrorRule] [Parent:RootAnalysisMember] [RuleType:Error]
[01/15/2016 09:41:27.0242] [1] Evaluated [Rule:RemoteRegException] [HasException:False] [Value:"False"] [ParentValue:"<NULL>"] [Thread:20] [Duration:00:00:00.3594375]
[01/15/2016 09:41:27.0242] [1] Finished [Rule:RemoteRegException] [Duration:00:00:00.3594375]
[01/15/2016 09:41:27.0242] [1] Started [Setting:ComputerDomainDN] [Parent:RootAnalysisMember] [ValueType:String]
[01/15/2016 09:41:27.0242] [1] Started [Setting:AdInitError] [Parent:RootAnalysisMember] [ValueType:String]
[01/15/2016 09:41:27.0242] [1] Evaluated [Setting:AdInitError] [HasException:False] [Value:"Setup encountered a problem while validating the state of Active Directory: Couldn't find the Enterprise Organization container. See the Exchange setup log for more information on this error."] [ParentValue:"<NULL>"] [Thread:9] [Duration:00:00:00]
[01/15/2016 09:41:27.0242] [1] Finished [Setting:AdInitError] [Duration:00:00:00]
[01/15/2016 09:41:27.0242] [1] Evaluated [Rule:AdInitErrorRule] [HasException:False] [Value:"True"] [ParentValue:"<NULL>"] [Thread:9] [Duration:00:00:00]
[01/15/2016 09:41:27.0242] [1] Finished [Rule:AdInitErrorRule] [Duration:00:00:00]
[01/15/2016 09:41:27.0242] [1] Started [Setting:ExchangeRecipientPolicyConfiguration] [Parent:RootAnalysisMember] [ValueType:ResultPropertyCollection]
[01/15/2016 09:41:27.0242] [1] Started [Rule:DuplicateShortProvisionedName] [Parent:RootAnalysisMember] [RuleType:Error]
[01/15/2016 09:41:27.0242] [1] Evaluated [Setting:ComputerDomainDN] [HasException:False] [Value:""] [ParentValue:"<NULL>"] [Thread:38] [Duration:00:00:00]
[01/15/2016 09:41:27.0242] [1] Finished [Setting:ComputerDomainDN] [Duration:00:00:00]
[01/15/2016 09:41:27.0242] [1] Evaluated [Setting:LocalComputerDomainDN] [HasException:False] [Value:"<NULL>"] [ParentValue:"<NULL>"] [Thread:38] [Duration:00:00:00.0156881]
[01/15/2016 09:41:27.0242] [1] Finished [Setting:LocalComputerDomainDN] [Duration:00:00:00.0156881]
[01/15/2016 09:41:27.0242] [1] Evaluated [Setting:LocalDomainNtSecurityDescriptor] [HasException:False] [Value:""] [ParentValue:"<NULL>"] [Thread:38] [Duration:00:00:00.0156881]
[01/15/2016 09:41:27.0242] [1] Finished [Setting:LocalDomainNtSecurityDescriptor] [Duration:00:00:00.0156881]
[01/15/2016 09:41:27.0258] [1] Started [Setting:SchemaVersionRangeUpper] [Parent:RootAnalysisMember] [ValueType:Nullable`1]
[01/15/2016 09:41:27.0258] [1] The security ID structure is invalid
[01/15/2016 09:41:27.0258] [1] Evaluated [Rule:DuplicateShortProvisionedName] [HasException:False] [Value:"False"] [ParentValue:"<NULL>"] [Thread:9] [Duration:00:00:00.0155642]
[01/15/2016 09:41:27.0258] [1] Evaluated [Setting:LocalDomainAdmin] [HasException:False] [Value:"False"] [ParentValue:"<NULL>"] [Thread:38] [Duration:00:00:00.0312523]
[01/15/2016 09:41:27.0258] [1] Finished [Setting:LocalDomainAdmin] [Duration:00:00:00.0312523]
[01/15/2016 09:41:27.0258] [1] Finished [Rule:DuplicateShortProvisionedName] [Duration:00:00:00.0155642]
[01/15/2016 09:41:27.0258] [1] Evaluated [Rule:LocalDomainPrep] [HasException:False] [Value:"True"] [ParentValue:"<NULL>"] [Thread:38] [Duration:00:00:00.0468323]
[01/15/2016 09:41:27.0258] [1] Finished [Rule:LocalDomainPrep] [Duration:00:00:00.0468323]
[01/15/2016 09:41:27.0258] [1] Started [Rule:InconsistentlyConfiguredDomain] [Parent:RootAnalysisMember] [RuleType:Error]
[01/15/2016 09:41:27.0258] [1] Started [Rule:PrepareDomainNotAdmin] [Parent:RootAnalysisMember] [RuleType:Error]
[01/15/2016 09:41:27.0258] [1] Evaluated [Setting:ExchangeRecipientPolicyConfiguration] [HasException:False] [Value:"<NULL>"] [ParentValue:"<NULL>"] [Thread:5] [Duration:00:00:00.0155642]
[01/15/2016 09:41:27.0258] [1] Finished [Setting:ExchangeRecipientPolicyConfiguration] [Duration:00:00:00.0155642]
[01/15/2016 09:41:27.0258] [1] Evaluated [Setting:GatewayProxy] [HasException:False] [Value:""] [ParentValue:"<NULL>"] [Thread:5] [Duration:00:00:00.0155642]
[01/15/2016 09:41:27.0258] [1] Finished [Setting:GatewayProxy] [Duration:00:00:00.0155642]
[01/15/2016 09:41:27.0258] [1] Started [Setting:ComputerNameDnsFullyQualified] [Parent:RootAnalysisMember] [ValueType:String]
[01/15/2016 09:41:27.0258] [1] Evaluated [Rule:PrepareDomainNotAdmin] [HasException:False] [Value:"False"] [ParentValue:"<NULL>"] [Thread:38] [Duration:00:00:00]
[01/15/2016 09:41:27.0258] [1] Finished [Rule:PrepareDomainNotAdmin] [Duration:00:00:00]
[01/15/2016 09:41:27.0258] [1] Started [Rule:NoE12ServerWarning] [Parent:RootAnalysisMember] [RuleType:Warning]
[01/15/2016 09:41:27.0273] [1] Started [Setting:NonAuthoritativeDomainsArray] [Parent:RootAnalysisMember] [ValueType:String[]]
[01/15/2016 09:41:27.0273] [1] Started [Setting:ExchNonAuthoritativeDomains] [Parent:RootAnalysisMember] [ValueType:String]
[01/15/2016 09:41:27.0273] [1] Started [Setting:E12ServerInTopology] [Parent:RootAnalysisMember] [ValueType:String]
[01/15/2016 09:41:27.0273] [1] Evaluated [Setting:ExchNonAuthoritativeDomains] [HasException:False] [Value:""] [ParentValue:"<NULL>"] [Thread:9] [Duration:00:00:00]
[01/15/2016 09:41:27.0273] [1] Finished [Setting:ExchNonAuthoritativeDomains] [Duration:00:00:00]
[01/15/2016 09:41:27.0273] [1] Evaluated [Setting:NonAuthoritativeDomainsArray] [HasException:False] [Value:"System.String[]"] [ParentValue:"<NULL>"] [Thread:9] [Duration:00:00:00]
[01/15/2016 09:41:27.0273] [1] Finished [Setting:NonAuthoritativeDomainsArray] [Duration:00:00:00]
[01/15/2016 09:41:27.0273] [1] Evaluated [Rule:InconsistentlyConfiguredDomain] [HasException:False] [Value:"False"] [ParentValue:"<NULL>"] [Thread:9] [Duration:00:00:00.0156247]
[01/15/2016 09:41:27.0273] [1] Finished [Rule:InconsistentlyConfiguredDomain] [Duration:00:00:00.0156247]
[01/15/2016 09:41:27.0273] [1] Started [Rule:ExchangeAlreadyInstalled] [Parent:RootAnalysisMember] [RuleType:Error]
[01/15/2016 09:41:27.0273] [1] Evaluated [Setting:ComputerNameDnsFullyQualified] [HasException:False] [Value:"Computername.Domein.nl"] [ParentValue:"<NULL>"] [Thread:5] [Duration:00:00:00.0156247]
[01/15/2016 09:41:27.0273] [1] Finished [Setting:ComputerNameDnsFullyQualified] [Duration:00:00:00.0156247]
[01/15/2016 09:41:27.0273] [1] Evaluated [Rule:ServerFQDNMatchesSMTPPolicy] [HasException:False] [Value:"False"] [ParentValue:"<NULL>"] [Thread:5] [Duration:00:00:00.0311889]
[01/15/2016 09:41:27.0273] [1] Finished [Rule:ServerFQDNMatchesSMTPPolicy] [Duration:00:00:00.0311889]
[01/15/2016 09:41:27.0289] [1] Started [Rule:SmtpAddressLiteral] [Parent:RootAnalysisMember] [RuleType:Error]
[01/15/2016 09:41:27.0289] [1] Started [Setting:NewestBuild] [Parent:RootAnalysisMember] [ValueType:Nullable`1]
[01/15/2016 09:41:27.0289] [1] Evaluated [Rule:SmtpAddressLiteral] [HasException:False] [Value:"False"] [ParentValue:"<NULL>"] [Thread:5] [Duration:00:00:00]
[01/15/2016 09:41:27.0289] [1] Finished [Rule:SmtpAddressLiteral] [Duration:00:00:00.0156257]
[01/15/2016 09:41:27.0289] [1] Started [Rule:RootDomainModeMixed] [Parent:RootAnalysisMember] [RuleType:Error]
[01/15/2016 09:41:27.0289] [1] Evaluated [Setting:E12ServerInTopology] [HasException:False] [Value:""] [ParentValue:"<NULL>"] [Thread:38] [Duration:00:00:00.0156257]
[01/15/2016 09:41:27.0289] [1] Finished [Setting:E12ServerInTopology] [Duration:00:00:00.0156257]
[01/15/2016 09:41:27.0289] [1] Started [Setting:NtMixedDomainRoot] [Parent:RootAnalysisMember] [ValueType:Int32]
[01/15/2016 09:41:27.0289] [1] Started [Setting:E15ServerInTopology] [Parent:RootAnalysisMember] [ValueType:String]
[01/15/2016 09:41:27.0289] [1] Evaluated [Setting:NewestBuild] [HasException:True] [Value:
Expected failure for NewestBuild:The registry key, HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\ExchangeServer\v15\Setup, wasn't found.
[01/15/2016 09:41:27.0289] [1] Finished [Setting:NewestBuild] [Duration:00:00:00]
[01/15/2016 09:41:27.0305] [1] Evaluated [Setting:NtMixedDomainRoot] [HasException:False] [Value:"0"] [ParentValue:"<NULL>"] [Thread:5] [Duration:00:00:00.0156283]
[01/15/2016 09:41:27.0305] [1] Finished [Setting:NtMixedDomainRoot] [Duration:00:00:00.0156283]
[01/15/2016 09:41:27.0305] [1] Evaluated [Rule:RootDomainModeMixed] [HasException:False] [Value:"False"] [ParentValue:"<NULL>"] [Thread:5] [Duration:00:00:00.0156283]
[01/15/2016 09:41:27.0305] [1] Finished [Rule:RootDomainModeMixed] [Duration:00:00:00.0156283]
[01/15/2016 09:41:27.0305] [1] Evaluated [Rule:ExchangeAlreadyInstalled] [HasException:False] [Value:"False"] [ParentValue:"<NULL>"] [Thread:9] [Duration:00:00:00.0312540]
[01/15/2016 09:41:27.0305] [1] Finished [Rule:ExchangeAlreadyInstalled] [Duration:00:00:00.0312540]
[01/15/2016 09:41:27.0305] [1] Evaluated [Setting:SchemaVersionRangeUpper] [HasException:False] [Value:"<NULL>"] [ParentValue:"<NULL>"] [Thread:10] [Duration:00:00:00.0312504]
[01/15/2016 09:41:27.0305] [1] Finished [Setting:SchemaVersionRangeUpper] [Duration:00:00:00.0468787]
[01/15/2016 09:41:27.0305] [1] Evaluated [Rule:DomainPrepWithoutADUpdate] [HasException:False] [Value:"False"] [ParentValue:"<NULL>"] [Thread:10] [Duration:00:00:00.0937110]
[01/15/2016 09:41:27.0305] [1] Finished [Rule:DomainPrepWithoutADUpdate] [Duration:00:00:00.0937110]
[01/15/2016 09:41:27.0305] [1] Evaluated [Setting:E15ServerInTopology] [HasException:False] [Value:""] [ParentValue:"<NULL>"] [Thread:38] [Duration:00:00:00.0156283]
[01/15/2016 09:41:27.0305] [1] Finished [Setting:E15ServerInTopology] [Duration:00:00:00.0156283]
[01/15/2016 09:41:27.0305] [1] Evaluated [Rule:NoE12ServerWarning] [HasException:False] [Value:"True"] [ParentValue:"<NULL>"] [Thread:38] [Duration:00:00:00.0468787]
[01/15/2016 09:41:27.0305] [1] Finished [Rule:NoE12ServerWarning] [Duration:00:00:00.0468787]
[01/15/2016 09:41:27.0305] [1] Started [Rule:NoE14ServerWarning] [Parent:RootAnalysisMember] [RuleType:Warning]
[01/15/2016 09:41:27.0305] [1] Started [Setting:E14ServerInTopology] [Parent:RootAnalysisMember] [ValueType:String]
[01/15/2016 09:41:27.0320] [1] Evaluated [Setting:E14ServerInTopology] [HasException:False] [Value:""] [ParentValue:"<NULL>"] [Thread:38] [Duration:00:00:00.0156279]
[01/15/2016 09:41:27.0320] [1] Finished [Setting:E14ServerInTopology] [Duration:00:00:00.0156279]
[01/15/2016 09:41:27.0320] [1] Evaluated [Rule:NoE14ServerWarning] [HasException:False] [Value:"True"] [ParentValue:"<NULL>"] [Thread:38] [Duration:00:00:00.0156279]
[01/15/2016 09:41:27.0320] [1] Finished [Rule:NoE14ServerWarning] [Duration:00:00:00.0156279]
[01/15/2016 09:41:27.0320] [1] Started [Rule:NotInSchemaMasterDomain] [Parent:RootAnalysisMember] [RuleType:Error]
[01/15/2016 09:41:27.0320] [1] Started [Setting:SmoSchemaDomain] [Parent:RootAnalysisMember] [ValueType:String]
[01/15/2016 09:41:27.0336] [1] Evaluated [Setting:SmoSchemaDomain] [HasException:False] [Value:""] [ParentValue:"<NULL>"] [Thread:38] [Duration:00:00:00.0156182]
[01/15/2016 09:41:27.0336] [1] Finished [Setting:SmoSchemaDomain] [Duration:00:00:00.0156182]
[01/15/2016 09:41:27.0336] [1] Evaluated [Rule:NotInSchemaMasterDomain] [HasException:False] [Value:"False"] [ParentValue:"<NULL>"] [Thread:38] [Duration:00:00:00.0156182]
[01/15/2016 09:41:27.0336] [1] Finished [Rule:NotInSchemaMasterDomain] [Duration:00:00:00.0156182]
[01/15/2016 09:41:27.0336] [1] Started [Rule:NotInSchemaMasterSite] [Parent:RootAnalysisMember] [RuleType:Error]
[01/15/2016 09:41:27.0336] [1] Evaluated [Rule:NotInSchemaMasterSite] [HasException:False] [Value:"False"] [ParentValue:"<NULL>"] [Thread:38] [Duration:00:00:00]
[01/15/2016 09:41:27.0336] [1] Finished [Rule:NotInSchemaMasterSite] [Duration:00:00:00]
[01/15/2016 09:41:27.0633] [1] Evaluated [Setting:WasSetupStartedFromGUI] [HasException:False] [Value:"False"] [ParentValue:"<NULL>"] [Thread:8] [Duration:00:00:00.4218343]
[01/15/2016 09:41:27.0633] [1] Finished [Setting:WasSetupStartedFromGUI] [Duration:00:00:00.4218343]
[01/15/2016 09:41:27.0648] [1] Running the on-premises test.
[01/15/2016 09:41:27.0680] [1] Evaluated [Setting:IsHybridObjectFoundOnPremises] [HasException:False] [Value:"False"] [ParentValue:"<NULL>"] [Thread:8] [Duration:00:00:00.4687205]
[01/15/2016 09:41:27.0680] [1] Finished [Setting:IsHybridObjectFoundOnPremises] [Duration:00:00:00.4687205]
[01/15/2016 09:41:27.0680] [1] Evaluated [Rule:DidTenantSettingCreatedAnException] [HasException:False] [Value:"False"] [ParentValue:"<NULL>"] [Thread:8] [Duration:00:00:00.4843918]
[01/15/2016 09:41:27.0680] [1] Finished [Rule:DidTenantSettingCreatedAnException] [Duration:00:00:00.4843918]
[01/15/2016 09:41:27.0680] [1] Started [Rule:DidOnPremisesSettingCreatedAnException] [Parent:RootAnalysisMember] [RuleType:Error]
[01/15/2016 09:41:27.0680] [1] Evaluated [Rule:DidOnPremisesSettingCreatedAnException] [HasException:False] [Value:"False"] [ParentValue:"<NULL>"] [Thread:8] [Duration:00:00:00]
[01/15/2016 09:41:27.0680] [1] Finished [Rule:DidOnPremisesSettingCreatedAnException] [Duration:00:00:00]
[01/15/2016 09:41:27.0680] [1] Started [Rule:HybridIsEnabledAndTenantVersionIsNotUpgraded] [Parent:RootAnalysisMember] [RuleType:Error]
[01/15/2016 09:41:27.0680] [1] Started [Setting:IsExchangeVersionCorrectForTenant] [Parent:RootAnalysisMember] [ValueType:Boolean]
[01/15/2016 09:41:27.0680] [1] Running the Office 365 tenant hybrid test with input file at: .
[01/15/2016 09:41:27.0680] [1] Evaluated [Setting:FileVersionLdifde] [HasException:False] [Value:"6.3.9600.16384"] [ParentValue:"<NULL>"] [Thread:16] [Duration:00:00:00.5625148]
[01/15/2016 09:41:27.0680] [1] Finished [Setting:FileVersionLdifde] [Duration:00:00:00.5625148]
[01/15/2016 09:41:27.0680] [1] Evaluated [Rule:W2K8R2PrepareAdLdifdeNotInstalled] [HasException:False] [Value:"False"] [ParentValue:"<NULL>"] [Thread:16] [Duration:00:00:00.7968899]
[01/15/2016 09:41:27.0680] [1] Finished [Rule:W2K8R2PrepareAdLdifdeNotInstalled] [Duration:00:00:00.7968899]
[01/15/2016 09:41:27.0695] [1] Testing .
[01/15/2016 09:41:27.0695] [1] Evaluated [Setting:IsExchangeVersionCorrectForTenant] [HasException:True] [Value:
Microsoft.Exchange.Management.Deployment.HybridConfigurationDetection.HybridConfigurationDetectionException: A hybrid deployment with Office 365 has been detected. Please ensure that you are running setup with the /TenantOrganizationConfig switch. To use the TenantOrganizationConfig switch you must first connect to your Exchange Online tenant via PowerShell and execute the following command: "Get-OrganizationConfig | Export-Clixml -Path MyTenantOrganizationConfig.XML". Once the XML file has been generated, run setup with the TenantOrganizationConfig switch as follows "/TenantOrganizationConfig MyTenantOrganizationConfig.XML".
If you continue to see this this message then it indicates that either the XML file specified is corrupt, or you are attempting to upgrade your on-premises Exchange installation to a build that isn't compatible with the Exchange version of your Office 365 tenant. Your Office 365 tenant must be upgraded to a compatible version of Exchange before upgrading your on-premises Exchange installation. For more information, see: http://go.microsoft.com/fwlink/?LinkId=262888
at Microsoft.Exchange.Management.Deployment.HybridConfigurationDetection.HybridConfigurationDetection.TestDCConfigFile(String pathToConfigFile)
at Microsoft.Exchange.Management.Deployment.HybridConfigurationDetection.HybridConfigurationDetection.RunTenantHybridTest(String pathToConfigFile)
at Microsoft.Exchange.Management.Analysis.PrereqAnalysis.<.ctor>b__29(Result`1 x)
at Microsoft.Exchange.Management.Analysis.Builders.SettingBuilder`2.<>c__DisplayClass1.<SetValue>b__0(Result x)
] [ParentValue:"<NULL>"] [Thread:8] [Duration:00:00:00.0156152]
[01/15/2016 09:41:27.0695] [1] Finished [Setting:IsExchangeVersionCorrectForTenant] [Duration:00:00:00.0156152]
[01/15/2016 09:41:27.0695] [1] Evaluated [Rule:HybridIsEnabledAndTenantVersionIsNotUpgraded] [HasException:False] [Value:"False"] [ParentValue:"<NULL>"] [Thread:8] [Duration:00:00:00.0156152]
[01/15/2016 09:41:27.0695] [1] Finished [Rule:HybridIsEnabledAndTenantVersionIsNotUpgraded] [Duration:00:00:00.0156152]
[01/15/2016 09:41:27.0695] [1] Started [Rule:AdcFound] [Parent:RootAnalysisMember] [RuleType:Error]
[01/15/2016 09:41:27.0695] [1] Started [Setting:AdcServer] [Parent:RootAnalysisMember] [ValueType:String]
[01/15/2016 09:41:27.0711] [1] Evaluated [Setting:LocalServerName] [HasException:False] [Value:"Computername"] [ParentValue:"<NULL>"] [Thread:6] [Duration:00:00:00.5468346]
[01/15/2016 09:41:27.0711] [1] Finished [Setting:LocalServerName] [Duration:00:00:00.5468346]
[01/15/2016 09:41:27.0711] [1] Evaluated [Rule:LoggedOntoDomain] [HasException:False] [Value:"False"] [ParentValue:"<NULL>"] [Thread:6] [Duration:00:00:00.5781293]
[01/15/2016 09:41:27.0711] [1] Finished [Rule:LoggedOntoDomain] [Duration:00:00:00.5781293]
[01/15/2016 09:41:27.0711] [1] Started [Rule:LocalDomainModeMixed] [Parent:RootAnalysisMember] [RuleType:Error]
[01/15/2016 09:41:27.0711] [1] Finished [Setting:AdcServer] [Duration:00:00:00.0156227]
[01/15/2016 09:41:27.0711] [1] Evaluated [Rule:AdcFound] [HasException:False] [Value:"False"] [ParentValue:"<NULL>"] [Thread:8] [Duration:00:00:00.0156227]
[01/15/2016 09:41:27.0711] [1] Finished [Rule:AdcFound] [Duration:00:00:00.0156227]
[01/15/2016 09:41:27.0711] [1] Started [Setting:NtMixedDomainComputerDomainDN] [Parent:RootAnalysisMember] [ValueType:Int32]
[01/15/2016 09:41:27.0711] [1] Evaluated [Setting:NtMixedDomainComputerDomainDN] [HasException:False] [Value:"0"] [ParentValue:"<NULL>"] [Thread:6] [Duration:00:00:00]
[01/15/2016 09:41:27.0711] [1] Finished [Setting:NtMixedDomainComputerDomainDN] [Duration:00:00:00]
[01/15/2016 09:41:27.0711] [1] Evaluated [Rule:LocalDomainModeMixed] [HasException:False] [Value:"False"] [ParentValue:"<NULL>"] [Thread:6] [Duration:00:00:00]
[01/15/2016 09:41:27.0726] [1] Finished [Rule:LocalDomainModeMixed] [Duration:00:00:00.0156296]
[01/15/2016 09:41:27.0726] [1] Evaluated [Setting:DomainRole] [HasException:False] [Value:"3"] [ParentValue:"<NULL>"] [Thread:13] [Duration:00:00:00.7500053]
[01/15/2016 09:41:27.0726] [1] Finished [Setting:DomainRole] [Duration:00:00:00.7656349]
[01/15/2016 09:41:27.0742] [1] Evaluated [Rule:ComputerNotPartofDomain] [HasException:False] [Value:"False"] [ParentValue:"<NULL>"] [Thread:13] [Duration:00:00:00.8593754]
[01/15/2016 09:41:27.0742] [1] Finished [Rule:ComputerNotPartofDomain] [Duration:00:00:00.8593754]
[01/15/2016 09:41:27.0742] [1] Evaluated [Setting:DebugVersion] [HasException:False] [Value:"False"] [ParentValue:"<NULL>"] [Thread:12] [Duration:00:00:00.8281270]
[01/15/2016 09:41:27.0742] [1] Finished [Setting:DebugVersion] [Duration:00:00:00.8281270]
[01/15/2016 09:41:27.0742] [1] Evaluated [Rule:OSCheckedBuild] [HasException:False] [Value:"False"] [ParentValue:"<NULL>"] [Thread:12] [Duration:00:00:00.8593754]
[01/15/2016 09:41:27.0742] [1] Finished [Rule:OSCheckedBuild] [Duration:00:00:00.8593754]
[01/15/2016 09:41:28.0070] [1] Evaluated [Setting:NicCaption] [HasException:False] [Value:"[00000010] Realtek RTL8139C+ Fast Ethernet NIC"] [ParentValue:"<NULL>"] [Thread:14] [Duration:00:00:01.0781284]
[01/15/2016 09:41:28.0133] [1] Evaluated [Setting:NicConfiguration] [HasException:False] [Value:"System.Collections.Generic.Dictionary`2[System.String,System.Object]"] [ParentValue:"[00000010] Realtek RTL8139C+ Fast Ethernet NIC"] [Thread:14] [Duration:00:00:01.1406302]
[01/15/2016 09:41:28.0133] [1] Evaluated [Setting:DnsAddress] [HasException:False] [Value:"172.25.0.40"] [ParentValue:"System.Collections.Generic.Dictionary`2[System.String,System.Object]"] [Thread:14] [Duration:00:00:01.1562553]
[01/15/2016 09:41:28.0133] [1] Evaluated [Setting:PrimaryDns] [HasException:False] [Value:"172.25.0.40"] [ParentValue:"<NULL>"] [Thread:14] [Duration:00:00:01.1718811]
[01/15/2016 09:41:28.0133] [1] Finished [Setting:PrimaryDns] [Duration:00:00:01.1718811]
[01/15/2016 09:41:28.0148] [1] Evaluated [Setting:PrimaryDNSPortAvailable] [HasException:False] [Value:"True"] [ParentValue:"<NULL>"] [Thread:14] [Duration:00:00:01.2343777]
[01/15/2016 09:41:28.0148] [1] Finished [Setting:PrimaryDNSPortAvailable] [Duration:00:00:01.2343777]
[01/15/2016 09:41:28.0148] [1] Evaluated [Rule:PrimaryDNSTestFailed] [HasException:False] [Value:"False"] [ParentValue:"<NULL>"] [Thread:14] [Duration:00:00:01.2656261]
[01/15/2016 09:41:28.0148] [1] Finished [Rule:PrimaryDNSTestFailed] [Duration:00:00:01.2656261]
[01/15/2016 09:41:28.0242] [1] Evaluated [Setting:ServiceMarkedForDeletion] [HasException:False] [Value:""] [ParentValue:"<NULL>"] [Thread:37] [Duration:00:00:01.0937526]
[01/15/2016 09:41:28.0242] [1] Finished [Setting:ServiceMarkedForDeletion] [Duration:00:00:01.0937526]
[01/15/2016 09:41:28.0242] [1] Evaluated [Rule:ServicesAreMarkedForDeletion] [HasException:False] [Value:"False"] [ParentValue:"<NULL>"] [Thread:37] [Duration:00:00:01.1093793]
[01/15/2016 09:41:28.0242] [1] Finished [Rule:ServicesAreMarkedForDeletion] [Duration:00:00:01.1093793]
[01/15/2016 09:41:35.0023] [1] Evaluated [Setting:InstalledWindowsFeatures] [HasException:False] [Value:"System.Object[]"] [ParentValue:"<NULL>"] [Thread:22] [Duration:00:00:08.0000051]
[01/15/2016 09:41:35.0023] [1] Finished [Setting:InstalledWindowsFeatures] [Duration:00:00:08.0000051]
[01/15/2016 09:41:35.0023] [1] Evaluated [Setting:IsRsatAddsToolsInstalled] [HasException:False] [Value:"True"] [ParentValue:"<NULL>"] [Thread:22] [Duration:00:00:08.0156289]
[01/15/2016 09:41:35.0023] [1] Finished [Setting:IsRsatAddsToolsInstalled] [Duration:00:00:08.0156289]
[01/15/2016 09:41:35.0023] [1] Evaluated [Rule:RsatAddsToolsInstalled] [HasException:False] [Value:"False"] [ParentValue:"<NULL>"] [Thread:22] [Duration:00:00:08.1249859]
[01/15/2016 09:41:35.0023] [1] Finished [Rule:RsatAddsToolsInstalled] [Duration:00:00:08.1249859]
[01/15/2016 09:41:35.0039] [1] Evaluated [Setting:PowerShellExecutionPolicy] [HasException:False] [Value:"False"] [ParentValue:"<NULL>"] [Thread:23] [Duration:00:00:08.1093549]
[01/15/2016 09:41:35.0039] [1] Finished [Setting:PowerShellExecutionPolicy] [Duration:00:00:08.1093549]
[01/15/2016 09:41:35.0039] [1] Evaluated [Rule:PowerShellExecutionPolicyCheckSet] [HasException:False] [Value:"False"] [ParentValue:"<NULL>"] [Thread:23] [Duration:00:00:08.1406128]
[01/15/2016 09:41:35.0039] [1] Finished [Rule:PowerShellExecutionPolicyCheckSet] [Duration:00:00:08.1406128]
[01/15/2016 09:41:35.0055] [1] Finished [Analysis:Prereq] [Duration:00:00:08.3125050]
[01/15/2016 09:41:35.0070] [1] [REQUIRED] Global updates need to be made to Active Directory, and this user account isn't a member of the 'Enterprise Admins' group.
[01/15/2016 09:41:35.0070] [1] Help URL: http://technet.microsoft....GlobalUpdateRequired.aspx
[01/15/2016 09:41:35.0070] [1] Failed [Rule:GlobalUpdateRequired] [Message:Global updates need to be made to Active Directory, and this user account isn't a member of the 'Enterprise Admins' group.]
[01/15/2016 09:41:35.0070] [1] Failed [Rule:LocalDomainPrep] [Message:The local domain needs to be updated. You must be a member of the 'Domain Admins' group and 'Organization Management' role group, or 'Enterprise Admins' group to continue.]
[01/15/2016 09:41:35.0070] [1] Failed [Rule:AdInitErrorRule] [Message:Setup encountered a problem while validating the state of Active Directory: Couldn't find the Enterprise Organization container. See the Exchange setup log for more information on this error.]
[01/15/2016 09:41:35.0070] [1] Failed [Rule:ForestLevelNotWin2003Native] [Message:The forest functional level of the current Active Directory forest is not Windows Server 2003 native or later. To install Exchange Server 2013, the forest functional level must be at least Windows Server 2003 native.]
[01/15/2016 09:41:35.0070] [1] Failed [Rule:CannotAccessAD] [Message:Either Active Directory doesn't exist, or it can't be contacted.]
[01/15/2016 09:41:35.0086] [1] [REQUIRED] The local domain needs to be updated. You must be a member of the 'Domain Admins' group and 'Organization Management' role group, or 'Enterprise Admins' group to continue.
[01/15/2016 09:41:35.0086] [1] Help URL: http://technet.microsoft....ness.LocalDomainPrep.aspx
[01/15/2016 09:41:35.0086] [1] [RECOMENDED] Setup will prepare the organization for Exchange 2013 by using 'Setup /PrepareAD'. No Exchange 2007 server roles have been detected in this topology. After this operation, you will not be able to install any Exchange 2007 servers.
[01/15/2016 09:41:35.0101] [1] [RECOMENDED] Setup will prepare the organization for Exchange 2013 by using 'Setup /PrepareAD'. No Exchange 2010 server roles have been detected in this topology. After this operation, you will not be able to install any Exchange 2010 servers.
[01/15/2016 09:41:35.0117] [1] [REQUIRED] Setup encountered a problem while validating the state of Active Directory: Couldn't find the Enterprise Organization container. See the Exchange setup log for more information on this error.
[01/15/2016 09:41:35.0117] [1] Help URL: http://technet.microsoft....ness.AdInitErrorRule.aspx
[01/15/2016 09:41:35.0117] [1] [REQUIRED] The forest functional level of the current Active Directory forest is not Windows Server 2003 native or later. To install Exchange Server 2013, the forest functional level must be at least Windows Server 2003 native.
[01/15/2016 09:41:35.0117] [1] Help URL: http://technet.microsoft....evelNotWin2003Native.aspx
[01/15/2016 09:41:35.0117] [1] [REQUIRED] Either Active Directory doesn't exist, or it can't be contacted.
[01/15/2016 09:41:35.0117] [1] Help URL: http://technet.microsoft....iness.CannotAccessAD.aspx
[01/15/2016 09:41:36.0430] [1] Ending processing test-SetupPrerequisites
[01/15/2016 09:41:36.0635] [0] CurrentResult console.ProcessRunInternal:136: 1
[01/15/2016 09:41:36.0635] [0] CurrentResult launcherbase.maincore:90: 1
[01/15/2016 09:41:36.0635] [0] CurrentResult console.startmain:52: 1
[01/15/2016 09:41:36.0635] [0] CurrentResult SetupLauncherHelper.loadassembly:452: 1
[01/15/2016 09:41:36.0648] [0] The Exchange Server setup operation didn't complete. More details can be found in ExchangeSetup.log located in the <SystemDrive>:\ExchangeSetupLogs folder.
[01/15/2016 09:41:36.0648] [0] CurrentResult main.run:235: 1
[01/15/2016 09:41:36.0648] [0] The registry key, HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\ExchangeServer\V15\Setup, wasn't found.
[01/15/2016 09:41:36.0648] [0] CurrentResult setupbase.maincore:396: 1
[01/15/2016 09:41:36.0648] [0] End of Setup
[01/15/2016 09:41:36.0648] [0] **********************************************
Beste antwoord (via F_J_K op 17-01-2016 10:36)
  • BrozzBrozz
  • Registratie: Oktober 2015
  • Laatst online: 26-10 17:09
Bedankt voor de snelle reacties en goede hulp.
Uiteindelijk bleken de 2 profielen die aangemaakt waren niet goed te werken.
Ik heb een 3e profiel aangemaakt en deze dezelfde rechten toegekend.
Nu werkt de installatie wel naar behoren.
  • RodeStabilo
Wat dacht je. Ik plemp de errorlog hier neer en dan zoeken de tweakers het wel uit?
Heb je zelf al wat gedaan om het op te lossen?
  • MADG0BLIN
  • Laatst online: 13-11 15:59
De foutmelding staat onderaan:
Voortaan misschien zelf gewoon de foutmelding lezen?
[ Voor 6% gewijzigd door MADG0BLIN op 15-01-2016 11:43 ]
  • RodeStabilo
MADG0BLIN schreef op vrijdag 15 januari 2016 @ 11:42:
Ik zie anders ook problemen met het contacten met AD. Al kan dat ook gerelateerd zijn natuurlijk.
  • MADG0BLIN
Welk forest functional level zit je nu op? Dat is eenvoudig uit te zoeken. Is die hoog genoeg? Anders zou ik daar eerst even naar kijken.
  • BrozzBrozz
Ik heb zelf het een an ander uitgezocht maar kon geen directe oorzaak vinden.
Meermaals een reset uitgevoerd van nics en ad config maar hij blijft dezelfde error melding mee geven.
Het functional level is op dit moment Windows Server 2008 dus dit moet het probleem niet veroorzaken.
  • RodeStabilo
BrozzBrozz schreef op vrijdag 15 januari 2016 @ 11:46:
Is je DNS goed? heb je genoeg rechten? werkt je AD goed?
  • mhoogendam
  • Laatst online: 12-11 09:09
Check deze meldingen even:
[ Voor 5% gewijzigd door mhoogendam op 15-01-2016 11:49 ]
  • BrozzBrozz
De DNS functioneerd goed en er word gebruik gemaakt van het builtin admin account, alle rechten gecontrolleerd maar hij is aanwezig in alle groepen.
  • mhoogendam
"Run as admin" gedaan op de setup?
  • BrozzBrozz
ja heb ik ook geprobeerd en ook als different user om het domein admin account er voor te gebruiken. Zonder succes helaas.
  • mhoogendam
[ERROR] Couldn't find the Enterprise Organization container.
http://exchangeserverpro....e-organization-container/
[ Voor 24% gewijzigd door mhoogendam op 15-01-2016 12:01 ]
  • BrozzBrozz
Helaas heeft dit ook niets uitgehaald.
  • Question Mark
  • Laatst online: 13-11 13:42
Question Mark
Moderator SSC/WOS
F7 - Nee - Ja
Begin gewoon eens met basic AD troubleshooten.Begin eens met de standaard testen zoals DCDIAG en NETDIAG. Dit is de eerste melding die in je log staat, kijk ook vooral hier naar.
[01/15/2016 09:41:06.0586] [0] [ERROR] Setup encountered a problem while validating the state of Active Directory: Couldn't find the Enterprise Organization container. See the Exchange setup log for more information on this error.
Geef voor de rest ook duidelijk aan wat je nu exact gedaan hebt, daar ontbreekt het eigenlijk wel aan.
  • Craven
  • Laatst online: 00:33
* Craven schopt open deur in.
Je installeert het natuurlijk niet op dezelfde machine als je/een DC of wel?
  • Jay-v
Jay-v
Uhhhh......
Volgens mij mis je gewoon de juistte rechten. Je gebruikt geen Enterprise Admin account. Heb je trouwens rechten om het Schema aan te passen? De installer moet een SchemaUpdate doen.
Lukt:
D:\exchangeinstallersource> setup /prepareschema /IacceptExchangeServerLicenseTerms
wel?
[ Voor 25% gewijzigd door Jay-v op 15-01-2016 13:14 ]
  • Jazzy
  • Laatst online: 00:44
Jazzy
Moderator SSC/PB/AI
Moooooh!
En als je daar mee gevorderd bent, pek dan gelijk even de meest recente build en niet die stokoude SP1.
  • BrozzBrozz
Nee hij word niet op dezelfde server geinstalleerd als de dc...
Rechten is het zeker niet is lid van alle groepen en ook een nieuwe gebruiker aangemaakt en alle rechten gegeven om dat uit te sluiten.
  • BrozzBrozz
De licentie heb ik niet veel keus in dit is de licentie die uit het MSDN van Microsoft komt.
Ze bieden daar helaas geen andere versie aan.
  • Jazzy
Jazzy
Moderator SSC/PB/AI
Moooooh!
Download hier de laatste build: https://www.microsoft.com...oad/details.aspx?id=50366 En verder ben ik wel benieuwd hoe de je installatie start, via de wizard of cmdline? En in geval van cmdline, welke opdrachtregel gebruik je?
En los van de logfile, wilke error zie je als de installatie afbreekt?
  • Oogje
Heb je al eerder een Exchange server geinstalleerd (gehad)?
Any errors in spelling, tact, or fact are transmission errors.
  • Beste antwoord ✓
  • BrozzBrozz
  • Rolfie
  • Laatst online: 19:33
BrozzBrozz schreef op vrijdag 15 januari 2016 @ 16:06:
Wat bedoel je exact met profielen?
  • BrozzBrozz
Voor de installatie was in het begin gebruik gemaakt van de default admin van het domein.
Toen liep ik al tegen het probleem aan.
Vervolgens na een tijdje heb ik een nieuwe user aangemaakt om uit te sluiten dat dat het niet was, nog steeds kwam het probleem voor.
Als laatste poging voor een herinstallatie geprobeerd met nogmaals een nieuw account.
Toen kwam hij er ineens wel doorheen. (de rechten van alle accounts waren hetzelfde)
