Poker/game PC
  • -Sybren
  • Laatst online: 10-06-2024
Surfen, video's kijken, af en toe gamen bijv. GTA V (hoeft niet op high/ultra settings, medium is genoeg) en pokeren met hiernaast Pokertracker 4 draaiend
Tussen de 800 en 850 euro inclusief monitor
Windows licentie, toetsenbord en muis ga ik ook nog aanschaffen maar daar heb ik een apart budget voor. Ik ga de pc zelf in elkaar zetten.
Op de site van Pokertracker staan de volgende systeemeisen:
What are the Minimum System Requirements to run PokerTracker 4?
Computer Hardware
Minimum Requirement: Windows: Intel Core 2 Duo (or AMD equivalent) processor with 3GB of RAM. Mac: Almost any Mac that runs OS X 10.6 or later released in 2009+ with 3GB of RAM.
Recommended: Windows: Modern quad-core processor with 4GB of RAM or greater. This includes the Intel Core 2 Quad and Intel Core i3, i5, and i7 processor lines (or their equivalent AMD processors). Mac: Almost any Mac that runs OS X 10.7 or later released in 2011+ with 3GB of RAM.
Optimal: Windows: Intel Core i5 or i7 multi-core 64-bit processor with 8GB of RAM or greater. Mac: Any Mac released in 2012+ with an SSD hard disk such as the Macbook Pro Retina line of laptops with 8GB of RAM or greater.
Not Recommended: Windows: Intel Pentium 4, Atom or other low power processors such as ARM.
Operating System
Minimum Requirement: Windows: Windows Vista, Windows 7, Windows 8 or Windows 8.1. Mac: OS X Snow Lepard 10.6, OS X Lion 10.7, or OS X Mountain Lion 10.8
Recommended: Windows: Windows 8, Windows 7 or Windows Vista. Mac: OS X Lion 10.7, or OS X Mountain Lion 10.8
Optimal: Windows: Windows 8 64 Bit or Windows 7 64 Bit with PostgreSQL 64 Bit 9.3.x manually installed. Mac: OS X 10.8 with PostgreSQL 64 Bit 9.3.x manually installed
PostgreSQL
Minimum Requirement: PostgreSQL 8.3.18 or greater (Windows only) / PostgreSQL 8.4.12 or greater / PostgreSQL 9.0.7 or greater
Recommended: Manually install the latest version of PostgreSQL 9.3.x.
Optimal: Manually install the 64 Bit version of PostgreSQL 9.3 or later. This requires a 64 bit processor and Operating System, with 8 Gigs or ram or better for optimal performance.
Not Supported: PostgreSQL 9.4 is not supported due to potential database errors, for the best performance please use PostgreSQL 9.3 or greater.
Hard Drive
The number one factor for speed performance is hard drive speed, the PostgreSQL Server which powers the PokerTracker database commonly moves gigabytes of data to allow PokerTracker 4 to perform it's reporting duties. PokerTracker recommends at least a 7200RPM hard drive or faster, Solid State Drives (SSDs) are currently the fastest drives available for optimal performance. The optimal solution for Mac users are computers that contains a built in SSD drive such as 2012's Macbook Airs (idealy with 4Gigs Ram or greater) or Macbook Pro Retina laptops.
Extra belangrijk zijn dus: SSD, HDD, CPU en RAM. Videokaart is minder belangrijk.
Geen voorkeuren
Een stille pc en een monitor van goede kwaliteit vind ik extra belangrijk. Wil alles nieuw aanschaffen
Ga je overklokken?
Nee
Wat verwacht je van ons?
Ik ben benieuwd of in mijn build nog dingen goedkoper kunnen zonder veel in te leveren op kwaliteit/performance, in de build zit namelijk nog geen videokaart en om niet ver over het budget te gaan zou ik graag nog wat besparen zodat er meer geld overblijft voor een videokaart. Ben verder benieuwd of alles compatible is en of dingen overkill zijn. Andere tips zijn natuurlijk ook welkom.
#ProductPrijsSubtotaal
1Intel Core i5-6400 Boxed€ 191,95€ 191,95
1MSI B150M PRO-VDH€ 75,95€ 75,95
1WD Blue WD10EZEX, 1TB€ 47,95€ 47,95
1Fractal Design Define R5 Zwart€ 101,95€ 101,95
1Dell Ultrasharp U2414H (860-BBCW) Zilver, Zwart€ 235,80€ 235,80
1Crucial Ballistix Sport BLS2C4G4D240FSA€ 47,95€ 47,95
1Cooler Master GM G450M€ 52,50€ 52,50
1Samsung 850 EVO 250GB€ 81,24€ 81,24
Bekijk collectie
Importeer producten
Totaal€ 835,29
  • Philpend
  • Laatst online: 28-09 10:35
De beste besparingsopties zijn uiteraard de kast en de monitor. Voor rond de 170 euro zijn er legio goede 24" FHD monitoren te krijgen. De kast is uiteraard ook persoonlijke smaak, maar er zijn ook veel kasten voor rond de 60 euro die een mogelijkheid zijn.
Monitoren: http://tweakers.net/categ...qy13SdcWikFQmawyLlWi5s20f
Kasten. http://tweakers.net/categ...LpdhaHSVjc0NkUVMjE6BwbS0A
Als ik kijk naar de specs van je posrgres programma denk ik dat je ook prima uit kunt met een i3 6100.
Zolang je de i3 koppelt aan een GTX 960 of r3 980 zul je denk ik prima GTA V op medium kunnen spelen.
Edit: ja gaat prima lukken http://nl.hardware.info/r...taten-core-i3---1920x1080
En dit was nog met een haswell i3, de 6100 skylake is weer een stukje krachtiger.
[ Voor 46% gewijzigd door Philpend op 09-01-2016 20:36 ]
  • MightyPenguin
  • Registratie: September 2014
  • Laatst online: 22-09 18:58
MightyPenguin
Ik weet even weinig als jij
Philpend schreef op zaterdag 09 januari 2016 @ 20:15:
Ja, dit allemaal. Moederbord kan ook een stukje goedkoper zonder eigenlijk op I/O in te leveren. pricewatch: Gigabyte GA-H110M-S2H
VB. schermpje zou dit kunnen zijn: pricewatch: LG 24MP47HQ Zwart. Binnen deze prijsrange zul je niet veel verschil tussen kwaliteit vinden. Misschien dat je toch wat duurder moet zoeken en dat je bij deze LG inlevert op kwaliteit, maar zo naar de specificaties kijkend geloof ik daar niks van. Ik moet wel toegeven dat ik niet genoeg over monitoren weet om hier iets zinnigs over te zeggen, maar de reviews op Tweakers en andere bronnen lijken erop te wijzen dat het een goede monitor voor het budget is.
Dit alles meegerekend kom ik op zoiets uit:
1Intel Core i3-6100 Boxed€ 122,95€ 122,95
1Gigabyte GA-H110M-S2H€ 54,95€ 54,95
1Sapphire NITRO R9 380X 4G D5€ 266,60€ 266,60
1Cooler Master Silencio 352€ 58,95€ 58,95
1LG 24MP47HQ Zwart€ 129,-€ 129,-
1Cooler Master GM G550M€ 62,95€ 62,95
Bekijk collectie
Importeer producten
Totaal€ 872,54
Dit is natuurlijk een richtlijn, maar ik denk dat je veel plezier aan zoiets zal kunnen beleven. Dikke videokaart die toekomstgericht is, iets goedkopere, maar nog steeds stijlvolle(naar mijn mening) case die een goede verhouding heeft tussen koelen/geluidsproductie, het goedkopere moederbord en een Skylake i3 dus. Verder een iets krachtigere power supply, omwille de slurpende R9 380X. Redelijk in de buurt van het budget ook nog.
Eventuele kostenbesparingen zouden een iets goedkopere GPU kunnen zijn, zoals een GTX 960 of R9 380. Persoonlijk zou ik dus voor: videokaart>processor gaan, omdat je aan een goede videokaart veel meer lol zal hebben in games. De i3 zal ook lang geen bottleneck zijn, dus lijkt me goed zo.
[ Voor 64% gewijzigd door MightyPenguin op 09-01-2016 21:54 ]
Ryzen 5 3600 | ASRock Fatal1ty B450 Gaming K4 | 16GB DDR4 3000 MHz | Gigabyte GTX 1060 G1 Gaming | Eclipse P400S | MX200 500GB | RM550x | AOC 24G2U | HD558
