METHOD 1: REPLACING/CHANGING PHONE ID
Note: This method basically turns your device into an international one and allows you to install I firmware the regular way. This method is only meant for the M1 Note, M2 (Note) and MX5. It is confirmed working on the previous mentioned models. Please, apply this at your own risk. You can always use method 2 or 3 which should be safer because they don’t ‘change’ anything. However, this method is much easier and quicker, besides it has been completed successfully numerous times.
1. Enable root or make sure you have root privileges
Enable root by tapping on Settings-> Accounts-> My Flyme-> Personal settings (first option) -> System privileges and set it to open - accept disclaimer and confirm. (In Flyme 5.x system privileges is under fingerprint and security*).
2. Download and copy the correct chid. sh file to your phone ( copy to root of your device).
Click to download file for M2 Note and MX5
Click to download file for M2 (mini)
Click to download file for M1 Note
3. (Download and) Launch an Android Shell Terminal Emulator and type the following commands
su
now wait until the $ sign changes in to # (it should change).
sh /sdcard/chid.sh
4. This should backup your current/original phone ID, replace/change the ID, and reboot the phone.
Now you should be able to install I firmware the regular way, which means via an update.zip and the original Meizu recovery. After applying OTA should work too, which is not the case with methods 1 and 2.
Note: If the command does not work try sh /storage/emulated/0/chid.sh instead. Side-note: if you prefer you can apply this method/command via ADB too.
END OF METHOD 1
https://meizufans.eu/foru...ur-chinese-mainland-meizu
Zou iemand mij vooral stap 3 en 4 van dit proces uit kunnen leggen? Ik snap hier echt heel weinig van.
  • benbaba
Het is eigenlijk heel simpel. Nadat je root geactiveerd hebt en het chid.sh bestandje naar je telefoon hebt gekopieerd moet je de ''installatie'' starten.
Download en installeer een Android Terminal Emulator hiervoor. Open de zojuist geïnstalleerd Terminal en tik op het zwarte veld en type daar in su [en enter]. Wacht even en het logotje achter je toestelnaam moet veranderen van $ naar # . Als dat gebeurd is tik je sh /sdcard/chid.sh [en weer enter]. Het toestel zal dan herstarten en je device ID zal verandert zijn.
Zie ook hier van 3:26 tot 4:18
[ Voor 9% gewijzigd door benbaba op 02-01-2016 17:42 ]
benbaba schreef op zaterdag 02 januari 2016 @ 17:35:
[video]Zie ook hier van 3:26 tot 4:18
En dan dien ik nog de normale rom er op te zetten? :)
  • benbaba
Ja het chid.sh bestandje wijzigt alleen je device ID, waardoor de meizu recovery denkt dat je een internationaal toestel ipv mainland-China hebt.
Je zou daarna dus een international (global) update.zip kunnen installeren zonder dat je een corruption/error melding krijgt.
benbaba schreef op zondag 03 januari 2016 @ 13:09:
Op een of andere manier verandert mijn $ niet in een #?
Weet jij misschien wat ik fout doe?
  • benbaba
Dat betekent dat je geen root hebt of dat het programma (de Terminal) geen root permissies heeft of krijgt.
Zorg dat je root in Flyme geactiveerd hebt. Dubbel check dit door na de activatie en de reboot een Root Checker (zie playstore) te gebruiken om het te verifiëren.
Als je zeker weten root hebt, open je de terminal en geef je het root rechten door op de request popup allow te klikken (2x). Hierna zou het moeten werken.
Dat laatste kan je weer checken door in System privileges (Flyme 4) of fingerprint and security (Flyme 5) bij ROOT permission te kijken of de Terminal Emualtor op ''allow'' staat.
benbaba schreef op zondag 03 januari 2016 @ 13:57:
De playstore werkt niet via mijn mobiel dus doe al mijn apps vanaf mijn laptop op mijn mobiel zetten? Misschien dat dat iets uit maakt? Ik heb ze beide op allow gezet en hij is ook geroot maar het werkt nog steeds niet. :(
  • benbaba
Probeer het met SuperSU en de onderstaande terminal emulator.
APK SuperSU: https://drive.google.com/...zZE1lMjQ/view?usp=sharing
APK terminal: https://drive.google.com/...1xFCo6OJzIaHhFM1VkSXNpSGM
Playstore kan je trouwens hier downloaden. Versie 2.02 of 2.03 zou op alle Flyme versies moeten werken.
benbaba schreef op zondag 03 januari 2016 @ 14:09:
supersu geeft een foutmelding aan bij mij
Ik ga voor de normale binary maar toch lukt het niet om hem werkend te krijgen. Erg frustrerend. :'(
Hierdoor verandert het dollarteken nog steeds niet in een hekje.
  • benbaba
Welke firmware versie heeft je toestel?
benbaba schreef op maandag 04 januari 2016 @ 14:40:
Android versie 5.1
Flyme OS: 4.5.3 A
  • benbaba
Dat is vreemd. Er gaat dan toch iets niet goed bij het rooten of het krijgen van permissie. Het werkt namelijk wel op mijn MX5.
Ik zou een clean install doen naar 4.5.4A met clear data. Eventueel eerst een factory reset met format disk (about>storage). Dit verwijdert wel alles, backup indien nodig.
Let er wel op dat het update.zip bestandje in documenten/file explorer blauw van kleur is. Mocht 'ie oranje zijn dan dien je in recovery mode te starten en hem vanaf daar installeren.
Nadat je een nieuwe en schone rom hebt; activeer je root waardoor het toestel herstart. Installeer hierna de eerder genoemde terminal en voer su uit. Mocht het werken sluit je de terminal, kopieer je het chid.sh voor de M2 Note en doe je weer su met de bijbehorende 2e command.
