ip nvr recorder 8 channel ziet ip camera's niet
beste liefhebbers,
hoop dat jullie mijn van dit probleem kunnen verlossen.
ik heb 1 nvr recorder.
Video Input/Output
IP video input 4/8/16 channel IP camera inputs
HDMI output 1 HDMI
VGA output 1 channel
Recording resolution 1080P
Compression H.264
Record rate 120/240/480fps
Multi screen display 1024×768@60Hz, 1280×1024@60Hz
Record Mode Manual / Time Scheduled / Alarm Triggered / Motion Detect
Playback Fast forward / Rewind /Slow Play
Hard Disk Drive
Interface type 1 SATA (3.5")
Capacity Up to 4TB
External Interface
Network interface 1 RJ45 10M/100M self-adaption
USB interface 2 USB 2.0 interfaces
General
Application support Remote configuration, video browse, local recording, local and remote playback
Motion detection Yes
Protocol support TCP/IP, UDP, DNS/DDNS, SMTP, UPNP,DHCP,HTTP,etc.
Alarm Support remote notification
Operating system Linux based
Smart phone iOS 4.3 up, Android 2.2 up
Power supply DC19V,3A
Power consumption <12W (Without hard disks)
Operating temperature −10 °C to 50 °C
Dimensions 220 × 205 × 42mm (8.6" × 8.1" × 1.7")
Weight 1.43lbs
Language 8 languages
1 ip camera van wanscam die ziet hij gelijk en werkt perfect. :)
1 ip camera p2p info hieronder.
Specificaties:
Image Sensor: 1/4 Inch color CMOS
Resolution: 1280x 720
Lens: f: 3.6mm
Viewing Angle: 60 degree
Minimum Illumination: 0.1Lux
Min LUX: IR lights on,0Lux
Pan/Tilt: Pan 270 Degrees Tilt 120 Degrees
Video Compression: H.264
Onvif: Yes
File Stream Resolution H.264 720P 1280x720 / 640x360 / 320x240
Reverse: Vertical/Horizontal
Two Way Audio: Yes
Tone Quality: Adjustable
Amplifier: Can connect with stereo, built-in speaker
Video Storage: max SD card supported: 32GB Not included
Alarm record: Micro SD card / PC
Recording: Support Smart Schedule recording, Continuous recording
Video playback: Video playback software
Data: Support remote, local download Video and capture picture from Micro SD card
Ethernet:10Base -T/100base-TX
Basic Protocol: TCP/IP、HTTP、SMTP、RTSP、FTP、DHCP、DDNS、UPNP、NTP
Mobile phone view: Android, SymbianS60, Windows Mobile, iPhone
Wifi Protocols: 802.11b/g/n
Dual way audio: support
Memory: Snap or video into SD card
Browser SD card: View or download from network
Motion Detection: Yes
Triggered Actions: Email/FTP/SD storage/external alarm/send message to alarm server
Motion detection alert via email or upload image to FTP; It also sends all motion detection, email FTP alarm info to the alarm server
User Setting: Three levels
Date/ Time Setting: Support
DDNS:A free DDNS provided by manufacturer
Wireless security: WEP / WPA / WPA2 encryption
Power Adapter
Power: DC 5V
Power consumption: 6W
Browser: Internet Explorer6.0 and Above or Compatible Browser, Safari, Firefox .
Online visitor: Support 10 visitors at the same time
IP mode: Dynamic IP address, static IP address,; Supporting WPS (Wi-Fi Protected Setup)Client
Main product dimensions: 105x100x130mm(L X W X D)
Main product weight: 324g
1 ip camera :merk airlive Fe-200DM
Ethernet
One RJ45 Port
IEEE 802.3u Compliant 10/100 Mbps Fast Ethernet with Auto-MDIX
PoE IEEE802.3af
Security
Password protection
IP filter
HTTPS
Supported Protocols TCP/IP, UDP, ICMP, DHCP, NTP, DNS, DDNS, SMTP, FTP, HTTP, HTTPs, Samba, PPPoE, UPnP, Bonjour, RTP, RTSP and RTCP
Users Up to 20 simultaneous users
zoals jullie al zien,
de ip camera p2p en de airlive wordt niet automatiche gevonden door de nvr recorder.
via mijn webbrowser kan ik ze allemaal benaderen.geen probleem.
ik heb ze ook allemaal een vats ip adres gegeven,maar geen resultaat.
als ik de ip adres invoer handmatig in de nvr geeft hij automatisch al het mac adres door,maar hij geeft foutmelding connect fallied,of ipc fallied.
hoop dat er iemand hier precies weet wat er fout is.
alvast bedankt Richard
  • Tazzios
  • Laatst online: 15:12
Tazzios
De ene IPcam is niet hetzelfde als de ander verschil in protocollen, en ondersteunde codecs.
Je bericht is ook wat warig met 3x 1 IP camera waarbij je de specs van de werkende NIET vernoemt.
Verdere nuttige info om er bij te zetten:
Welke nvr recorder? Welk protocollen en codes ondersteund deze?
Situatie thuisnetwerk, meerdere routers?
hoi
bovenaan het bericht staat de nvr recorder specificaties.
ook welke protocoolen het ondersteund.
dit zijn de specificaties van de camera die wel werkt,
Specificaties:
Image sensor: 1/4 Inch Color CMOS Sensor
Lens: f: 2.8-12mm
Min lux: 0.1
IR-CUT: Yes
Infrared Light: 42 IR LEDs, Night visibility up to 40 Meters
Pan/Tilt Angle: Horizontal:360 degrees Vertical: 90 degrees
Resolution: 1280x720(720p); 640x480(VGA), 320x240(QVGA)
Image Frame Rate: 30 FPS (720p); 30 FPS (VGA),30 FPS (QVGA)
Image compression: H.264
Processor: Hi3518E
Flip Mirror Images: Vertical / Horizontal
Refresh Rate: 50Hz, 60Hz
Video Parameters: Brightness, Contrast
WiFi: IEEE 802.11b/g/n
DDNS server: support
Ethernet: RJ-45 Interface 10/100Mbps
Supported Protocol: HTTP/DHCP/IP/TCP/UDP/FTP/SMTP/DDNS/UPnP/RTSP
Code rate:720p 30 frames 4Mbps; VGA 15 frames 512Kbps; QVGA 8 frames 200Kbps
Wireless Security: 64/128 bit WEP Encryption
Mobile phone browser: Android and Apple
Dimensions: 125x124mm (HxW)
Weight: 1655g
Operation Temperature: 0-55 Degree Celcius (14-122 Degree Farenheit)
Operation Humidity: 20%-85%
Storage Temperature: -10-60 Degree Celcius (14-140 Degree Farenheit)
Power: DC 5V/2A
Inhoud verpakking:
IP camera
Screws
Antenna
CD-ROM
Power adapter
Cable
Ik heb de router van telfort eperia KPN Experia Box v8
heb er geen andere router opzitten.
hopende je voldoende info hebt.
met vriendelijke groet,
richard
  • bregweb
  • Laatst online: 21-11 17:10
Een NVR heeft een soort DriverPack waarmee een aantal camera's worden herkend. Ik vermoed dat de niet werkende camera's niet in de huidige driverpack zitten. Ga naar de website van je NVR en ga op zoek naar de laatste driverpack en installeer die.
Hattrick: Thorgal Eagles
http://www.e-seenet.com/ dit is de website van ze.
ik heb via de nvr de laatste firmware update gedaan,maar helaas hij ziet ze niet.
ik heb ze ook handmatig erin gezet.maar dan geeft hij wel automatiche het mac adres aan.
maar hij geeft ipc fout of conneet fallied.
gr richard
kan het zo zijn dat het met poorten te maken heeft,alles staat nu op poort 80.maar ja dat moet die ene het ook niet doen.
of met de router .
gr richard
  • corset
  • Laatst online: 20-11 13:23
Wordt de niet werkende camera ondersteund door e-seenet? Zie:
hoi,
bedankt voor je tip,
maar kan die driver pack nergens vinden?
hoop dat iemand mij hierna kan verwijzen
gr richard
