Ik haal de 64MB DIMM eruit en ik wil beide vrije sloten dan opvullen met allebei 128 MB 133 Mhz DIMM's die je bijvoorbeeld hier: http://www.mti.nl/E-Shop/indexshop2.html kan kopen.<<< Mainboard Information >>>
< General System Information >
Class: IBM PC/AT
System Bus(es): ISA(16-bit), PCI(32-bit), USB, AGP(32-bit)
Fast Windows System: Yes
< Entire System >
Manufacturer: IBM
< System Mainboard >
Manufacturer: IBM
MultiProcessor Support: No
Model: V66M
< Memory Controller >
Error Detection Method: 64-bit ECC
Error Correction Capability: 1-bit
Supported/Current Memory Interleave: 1 way / 1 way
Number of Memory Slots: 3
Maximum Installable Memory: 384MB
Maximum Module Size: 128MB
Supported Memory Types: ECC, DIMM
Supported Memory Voltages: 3.3V
< Physical/BIOS Memory Banks >
DIM1 (RASL-0 RASL-1): 128MB DIMM SDRAM double-bank
DIM2 (RASL-2): 64MB DIMM SDRAM single-bank
DIM3: Empty
< System Chipset >
System Chipset: Intel Corporation 82443BX/ZX 440BX/ZX PCI-Host Bridge
(AGP Implemented)
Front Side Bus Speed: 100MHz
CPU Speed Multiplier: 4.5x
ACPI Support: Yes
SMBus/i2c Support: 1 channel(s)
< Logical/Chipset Memory Banks >
Bank 0 Setting: 64MB SDRAM 8-1-1-1R 6-1-1-1W
Bank 1 Setting: 64MB SDRAM 8-1-1-1R 6-1-1-1W
Bank 2 Setting: 64MB SDRAM 8-1-1-1R 6-1-1-1W
Memory Bus Speed: 100MHz
Mijn systeem is 4 a 5 jaar oud, is er verschil in DIMM's opgetreden in de afgl. 5 jaar?
Kan 133MHz in dit oude systeem (ik weet dat het op nieuwe moederborden geen probleem is om 133MHz op in 100 Mhz mobo te plaatsen).
