OpenVPN Windows7 geen verbinding
  • plizz
  • Laatst online: 22:19
Sinds 2 a 3 dagen kan ik geen OpenVPN verbinding maken. OpenVPN initialization sequence stopt bij "read TCPv4_CLIENT: Connection timed out (WSAETIMEDOUT) (code=10060)". En daarna probeert ie weer opnieuw.
Ik gebruik Windows 7 SP1 met nieuwste OpenVPN software 2.38. Alleen Windows 7 heeft deze issue. Ubuntu kan die OpenVPN verbinding opzetten.
Tue Nov 03 22:31:05 2015 OpenVPN 2.3.8 x86_64-w64-mingw32 [SSL (OpenSSL)] [LZO]
[PKCS11] [IPv6] built on Aug  4 2015
Tue Nov 03 22:31:05 2015 library versions: OpenSSL 1.0.1p 9 Jul 2015, LZO 2.08
Tue Nov 03 22:31:05 2015 WARNING: No server certificate verification method has
been enabled.  See http://openvpn.net/howto.html#mitm for more info.
Enter Private Key Password:
Tue Nov 03 22:31:29 2015 WARNING: this configuration may cache passwords in memo
ry -- use the auth-nocache option to prevent this
Tue Nov 03 22:31:29 2015 Control Channel Authentication: using 'ta.key' as a Ope
nVPN static key file
Tue Nov 03 22:31:29 2015 Outgoing Control Channel Authentication: Using 160 bit
message hash 'SHA1' for HMAC authentication
Tue Nov 03 22:31:29 2015 Incoming Control Channel Authentication: Using 160 bit
Tue Nov 03 22:31:29 2015 Socket Buffers: R=[8192->8192] S=[8192->8192]
Tue Nov 03 22:31:29 2015 Attempting to establish TCP connection with [AF_INET]141.138.x.x:80 [nonblock]
Tue Nov 03 22:31:30 2015 TCP connection established with [AF_INET]141.138.x.x:80
Tue Nov 03 22:31:30 2015 TCPv4_CLIENT link local: [undef]
Tue Nov 03 22:31:30 2015 TCPv4_CLIENT link remote: [AF_INET]141.138.x.x:80
Tue Nov 03 22:31:51 2015 read TCPv4_CLIENT: Connection timed out (WSAETIMEDOUT)
(code=10060)
Tue Nov 03 22:31:51 2015 Connection reset, restarting [-1]
  • Yariva
  • Laatst online: 02-10 15:14
Yariva
Moderator Internet & Netwerken
Power to the people!
Is dit vanaf de zelfde machine, zelfde locatie etc? Zit je achter de zelfde router / fw?
Mensen zijn gelijk, maar sommige zijn gelijker dan andere | Humans need not apply
  • plizz
Yariva schreef op woensdag 04 november 2015 @ 09:39:
Ja. Als ik het thuis test, krijg ik ook het zelfde resultaat. Dus het lijk me dat het aan OpenVPN i.c.m. Windows 7.
  • Yariva
Yariva
Een connectie die timed out aangeeft lijkt mij aan te geven dat iets wordt geblokt... Kan je een exceptie aanmaken op je windows 7 FW voor uitgaand verkeer over poortje 1194 UDP (tenzij je dit zelf heb aangepast naar een andere poort)?
  • plizz
Uitgaand verkeer gaat over poort 80, zodat ik overal OpenVPN kan gebruiken.
  • Yariva
Yariva
Zou het kunnen dat je nu een andere service op poort 80 aan het gebruiken ben? Bijv. Skype, torrent of standaard www verkeer?
