[Windows 10 x64] Update's willen niet meer installeren
  • Jessez
  • Laatst online: 15-09 11:39
Sinds 1 1/2 maand kan ik geen updates installeren. Het gaat om de updates "kb3093266" en "KB3105210"
Wat heb ik ge probeert:
C:\Windows\system32>Dism /Online /Cleanup-Image /RestoreHealth
Deployment Image Servicing and Management tool
Version: 10.0.10240.16384
Image Version: 10.0.10240.16384
[==========================100.0%==========================]
The restore operation completed successfully.
The operation completed successfully.
Daarna
C:\Windows\system32>sfc /scannow
Beginning system scan. This process will take some time.
Beginning verification phase of system scan.
Verification 100% complete.
Windows Resource Protection did not find any integrity violations.
Verder heb ik dit script gedraaid
29
30
31
32
33
34
35
36
37
38
@ECHO OFF
echo.
echo =============================================
echo Simple Script to Reset / Clear Windows Update
echo.
echo Created by "Vishal Gupta" for AskVG.com
echo.
echo Thanks to DTM for sharing the commands
echo.
PAUSE
echo.
attrib -h -r -s %windir%\system32\catroot2
attrib -h -r -s %windir%\system32\catroot2\*.*
echo Stopping Windows Update related services...
echo.
net stop wuauserv
net stop CryptSvc
net stop BITS
echo Done!
echo.
echo Renaming Windows Update related folders...
echo.
ren %windir%\system32\catroot2 catroot2.old
ren %windir%\SoftwareDistribution sold.old
ren "%ALLUSERSPROFILE%\application data\Microsoft\Network\downloader" downloader.old
echo Done!
echo.
echo Starting Windows Update related services...
echo.
net Start BITS
net start CryptSvc
net start wuauserv
echo Done!
echo.
Maar helaas geen resultaat
Cumulative Update for Windows 10 for x64-based Systems (KB3105210)
Failed to install on 30-10-2015
Dit staat in de event viewer:
errorCode 0x80070011
updateTitle Cumulative Update for Windows 10 for x64-based Systems (KB3105210)
updateGuid {98EFF918-2B3D-409E-BF0D-C2FF9F55B7A3}
updateRevisionNumber 203
serviceGuid {7971F918-A847-4430-9279-4A52D1EFE18D}
Heeft hier iemand nog een idee?
  • Reepje
Je hebt in ieder geval een systeem dat erg rap is, want updatexxx5210 is bij mij 1 dag geleden pas voor het eerst aangeboden. En is sindsdien enkele malen geinstaleerd, dus hetzelfde euvel.
Samen met xxx266 is dat een cummulatieve update, waarbij werkelijk honderden files worden toegevoegd/vervangen. Is deze update ook nog niet geinstaleerd, want ook deze update staat er bij mij een stuk of 10 keer bij, voordat deze dan eindelijk met suces was geinstaleerd.
Het enige wat ik kan bedenken is, dat het updaten van win10 nog niet altijd foutloos gaat.
Win10 is een fijn systeem, maar het is nog niet foutloos.
  • Jessez
Probleem is opgelost. De oplossing is Windows 10 opnieuw installeren.
De mappen users, program files en program files (x86) staan op een ander schijf dan Windows map.
En dat pikken de Updates niet meer naar het schijnt.
