digikam - welke linux variant werkt probleemloos?
  • thunder7
  • Laatst online: 02-10 17:22
thunder7
houten vaas/schaal nodig?
Debian/Unstable:
root@thinkpad:~# apt-get install digikam
Reading package lists... Done
Building dependency tree
Reading state information... Done
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
 digikam : Depends: digikam-private-libs (= 4:4.4.0-1.1+b2) but it is not going to be installed
           Depends: libopencv-core2.4 but it is not going to be installed
           Depends: libopencv-imgproc2.4 but it is not going to be installed
           Recommends: kipi-plugins but it is not going to be installed
E: Unable to correct problems, you have held broken packages.
Compileren van source is ook een hel, trouwens, het hangt van allerlei zaken af die net niet beschikbaar zijn - en geeft dan fijne foutmeldingen als
CMake Error at extra/CMakeLists.txt:11 (add_subdirectory):
  add_subdirectory given source "libkexiv2" which is not an existing
  directory.
CMake Error at extra/CMakeLists.txt:15 (add_subdirectory):
  add_subdirectory given source "libkdcraw" which is not an existing
  directory.
CMake Error at extra/CMakeLists.txt:19 (add_subdirectory):
  add_subdirectory given source "libkipi" which is not an existing directory.
pogingen om de betreffende libraries te installeren, zelfs vanuit experimental, leveren zonder uitzondering een onbruikbaar systeem op.
Dus heb ik uiteindelijke via Virtualbox een ubuntu-variant geïnstalleerd, 14.04 LTS.
De standaard digikam versie daarin is 3.5 (actueel: 4.12), kennelijk.
sudo add-apt-repository ppa:philip5/extra
sudo apt-get update
sudo apt-get install digikam showfoto
werkt, maar bij het starten van digikam:
Object::connect: No such signal org::freedesktop::Upower::DeviceAdded(QDBusObjectPath)
en nog wat van die fijne meldingen. Ubuntu is het dus ook niet. Weet iemand wat ik wel moet hebben? Wat werkt probleemloos met een recente versie van Digikam?
hout-nerd - www.hetmooistehout.nl of www.houtenschalen.nl
  • houthakker
  • Laatst online: 01-10 10:47
houthakker
Poehé
Er is een reden waarom dat deze nog niet in Testing (Unstable) zitten: zie https://release.debian.or...esting.pl?package=digikam
Heb je de versie van Jessie geprobeerd? Een oudere versie onder debian gebruiken is vaak makkelijker dan een nieuwe.
Anders zou je het beste een KDE based distro kunnen gebruiken, Kubuntu 15.04 oid.
Specs
  • thunder7
thunder7
kubuntu + xfce4 komt aardig in de buurt. Digikam is trouwens wel een lastig pakket, ik ben voor de gein eens lid geworden van hun mailinglist, en 75% van de vragen gaat inderdaad over het al dan niet beschikbaar zijn van libraries om het te compilen. Ze hebben vaak het aller-, allernieuwste nodig, lijkt het, en een build-systeem op basis van cmake lijkt ook heel wat oncomfortabeler dan ik met ./configure gewend ben.
Serieuze tips komen neer op recepten om waarden in tekst-bestanden 2 directories diep aan te passen om de compilatie werkend te krijgen.
  • johnkeates
  • Laatst online: 13-09 22:20
Lijkt er op dat Digikam gewoon crap is. Niet qua programma maar qua dependencies. Ten eerste zou ik je aanraden het op een distro te draaien die sowieso al een KDE omgeving gebruikt by default, en ten tweede zou ik je aanraden niet de nieuwste Digikam te gebruiken zodat de rest van de wereld tijd gehad heeft de dependencies van Digikam mee te leveren met een bepaalde distributieversie.
Je kan ook nog proberen een oudere Digikam van source te bouwen. Alternatief is dat je niet Digikam gebruikt maar een ander programma.
  • Rainmaker
  • Laatst online: 14-07-2024
Rainmaker
RHCDS
Digikam zit in de standaard repo van Arch Linux: https://www.archlinux.org/packages/extra/x86_64/digikam/
Geen garantie, maar dat is meestal toch een teken dat het stabiel is.
Omdat ik een GNOME desktop heb, wil ik liever niet al die KDE crap libs op mn desktop, dus ik heb het eerlijk gezegd niet zelf geprobeerd.
Overigens is CMake cool. Een stuk cooler dan MakeFiles.
Maar, net als MakeFiles, moet de content wel kloppen. En daar lijkt het aan te schorten:
  directory.
Dit is geen fout van jou. Dit betekent simpelweg dat de ontwikkelaar heeft aangegeven dat er software in een directory moet worden gecompileerd, maar dat die directory niet bestaat.
Die is niet boeiend. Dit heeft een wat vreemde history, maar komt erop neer dat dit (naar alle waarschijnlijkheid) geen fatale foutmelding is.
Zie o.a. https://bugzilla.redhat.com/show_bug.cgi?id=1056769.
De fix voor deze foutmelding zou in kde-frameworks 5.5 moeten zitten (Ubuntu Vivid (14.10) of Willy (15.04))
Maar, zoals gezegd, kijk eens of Arch Linux misschien een optie is.
[ Voor 23% gewijzigd door Rainmaker op 24-10-2015 01:15 ]
We are pentium of borg. Division is futile. You will be approximated.
  • thunder7
thunder7
Ik ben inmiddels bezig met kubuntu, en dat werkt, zoals ik al wat onduidelijk opschreef, best aardig. Het doet wel pijn Debian achter te laten, dat wel.
Eerdere versies van digikam hadden een voor mij fatale fout dat sommige crop-acties een ander stuk foto uitsneden dan op het scherm zichtbaar was.
  • DAzN
Je gebruikte unstable, had je dezelfde problemen met stable en testing?
