Aurous.jar wil niet starten in ubuntu
Hallo heren en dames,
Als ik Aurous wil starten in Ubuntu werkt het niet. Ik heb al geprobeerd om de .jar te starten via de commandline maar hij gaf deze melding terug.
Met voorbaat dank :)
johan@johan-1015BX-1015BX:~/Bureaublad/aurous$ java -jar Aurous.jar
Exception in Application start method
java.lang.reflect.InvocationTargetException
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:497)
at com.sun.javafx.application.LauncherImpl.launchApplicationWithArgs(LauncherImpl.java:389)
at com.sun.javafx.application.LauncherImpl.launchApplication(LauncherImpl.java:328)
at sun.launcher.LauncherHelper$FXHelper.main(LauncherHelper.java:767)
Caused by: java.lang.RuntimeException: Exception in Application start method
at com.sun.javafx.application.LauncherImpl.launchApplication1(LauncherImpl.java:917)
at com.sun.javafx.application.LauncherImpl.lambda$launchApplication$156(LauncherImpl.java:182)
at java.lang.Thread.run(Thread.java:745)
Caused by: com.teamdev.jxbrowser.chromium.internal.ipc.IPCException: IPC process exited. Exit code: 127
at com.teamdev.jxbrowser.chromium.internal.ipc.d.run(Unknown Source)
... 1 more
Exception running application me.aurous.Aurous
Exception in thread "Thread-4" java.lang.NullPointerException
at com.teamdev.jxbrowser.chromium.internal.ipc.IPC.c(Unknown Source)
at com.teamdev.jxbrowser.chromium.internal.ipc.IPC.b(Unknown Source)
at com.teamdev.jxbrowser.chromium.internal.ipc.IPC.a(Unknown Source)
at com.teamdev.jxbrowser.chromium.internal.ipc.b.run(Unknown Source)
... 1 more
johan@johan-1015BX-1015BX:~/Bureaublad/aurous$ sudo -i
[sudo] password for johan:
root@johan-1015BX-1015BX:~# java -jar Aurous.jar
Error: Unable to access jarfile Aurous.jar
  • CAPSLOCK2000
  • Laatst online: 09:55
CAPSLOCK2000
zie teletekst pagina 888
Wat heb je zelf al gedaan om dit probleem op te lossen?
Ik denk dat je dit het beste met de ontwikkelaars van Aurous kan bespreken.
Aangezien dit project versienummer 0.1 Alpha heeft zou ik nog niet te veel verwachten van de kwaliteit.
Waarschijnlijk is het een bug in de code.
PS. Op tweakers begroeten we elkaar niet, het is gewoonte om direct met je verhaal te beginnen.
PS2. Vermeld de volgende keer welke versies je gebruikt, in dit geval dus de versie van Ubunut, Java en Aurous.
This post is warranted for the full amount you paid me for it.
Aurous werkt toch met het BitTorrent-protocol, "de Popcorn Time voor muziek" wordt het wel genoemd. Mag dit dan uberhaupt hier besproken worden?
  • himlims_
himlims_
🐧 Linux HOoligan
even de tool gewonload en geinstalleerd (nu gvd toch java op de desktop staan grrrr)
anyway:
$ sudo add-apt-repository ppa:webupd8team/java
$ sudo apt-get update
$ sudo apt-get install oracle-java8-installer
$ sudo apt-get install libgcrypt11 libgcrypt11-dev gcc
$ sudo chmod +x linux/jxbrowser-chromium
ps; wa da fuck run je dit als root?
[ Voor 5% gewijzigd door himlims_ op 12-10-2015 08:50 ]
  • CAPSLOCK2000
CAPSLOCK2000
Verwijderd schreef op maandag 12 oktober 2015 @ 07:50:
De software en het protocol mogen besproken worden zolang het maar niet over content gaat
PS. Gebruik de volgende keer aub de "Rapporteer"-knop bovenaan de pagina voor dit soort opmerkingen. tnx.
  • redman54200
  • Laatst online: 16-11-2025
himlims_ schreef op maandag 12 oktober 2015 @ 08:48:
anyway:
Linux mint 17.2 cinnamon....
Alles geinstalleerd wat moest.....
System-Product-Name ~/aurous $ java -jar Aurous.jar
Update finished
Check finished
Launching aurous...
UTF-8
Geen verdere foutmelding... start gewoon niet op.
