Gaming pc 600 euro
  • 2.602 views
  • Jente_Cremer
  • Registratie: Oktober 2015
  • Laatst online: 14-07-2024
Game pc 600 euro
I want a gaming pc for 600 euro, i wanna game on it cause its a game pc and I have to edit clips with it. I use on this moment windows 10 but all above windows 7 is gooed for me.
my budget is between 500 and 600 euro.
My ultimate max. is 600 euro cause im a beginner with pc builds.
I want 8gb of ram in it and a good graphics card that can run gta 5 at medium or high settings I was thinking about the MSI Radeon R7 370 4Gb
I dont have a specific brandure I just want a good pc for my money.
I think I need 1 tb harddisk and 8 gb of ram.
I have made an Build in my head but i dont know of it is good these are the specs: Intel Pentium G3258 / 3.2 Ghz - 3 MB cache, Ballistix sport 8gb, Msi Radeon R7 gaming 370 4GB, MSI H81M-P33 LGA1150, WD Blue WD10EZEX 1 TB, Corsair Builder Series CX430 and as case the Bitfenix Comrade White with a windows. the price of this all is 570 euro.
I dont have a specific Brandure
I want a good pc but cheap so maybe AMD but intel is quicker so I dont know. The only thing what I found of intel is the motherboard in my build and from amd the graphics card.
My wish is a gaming pc for max 600 euro that can run gta 5 on medium till high settings.
if the build can overclock than maybe but it is not an must.
Ofcourse i want the max out of my pc but Overclock isnt a must.
I hope you can help me with a good build.
Do you know a good gaming pc for max 600 euro plz react than and if you think that i have to cange someting in my build react also, thank you
Your price seems a bit off, or did you get them from one store:
#ProductPrijsSubtotaal
1Intel Pentium G3258 Boxed€ 67,-€ 67,-
1MSI H81M-P33€ 38,50€ 38,50
1MSI R7 370 Gaming 4GB€ 185,95€ 185,95
1WD Blue WD10EZEX, 1TB€ 50,95€ 50,95
1BitFenix Comrade Window Wit€ 36,51€ 36,51
1Crucial Ballistix BLS2CP4G3D1609DS1S00CEU€ 40,95€ 40,95
1Corsair Builder CX430 Bronze€ 44,50€ 44,50
Bekijk collectie
Importeer producten
Totaal€ 464,36
Considering your budget, you could spend some more on your GPU and CPU. Doing one without the other is kind of pointless. If you want faster boot times, you could consider a small SSD (120GB) for Windows.
  • Flaat
  • Laatst online: 26-11-2025
Another idea is tot buy an old workstation of eBay, marktplaats or Tweakers and put a good gpu in there.
This is a pretty sweet deal for example
Www.ebay.de/itm/HP-Z210-W...-/252068200051?nav=SEARCH
The bad part about this deal is that the psu and case have a non standart form factor so upgrading either of thse in the future will be more complex. The good thing is that it had a 400w psu in there that can deal with a reasonable gpu. Especially on a budget buying a complete PC and adding parts tot that makes allot of sense
  • Larkinzzz
  • Laatst online: 28-09 18:14
If it has to be below €600 you would be best off with this:
1AMD Athlon X4 860K Boxed€ 70,95€ 70,95
1ASRock FM2A88M Extreme4+€ 62,95€ 62,95
1Cooler Master N300 (KKN1, closed)€ 38,90€ 38,90
1Antec VPF Series 450W€ 49,95€ 49,95
1Crucial BX100 250GB€ 79,95€ 79,95
Bekijk collectie
Importeer producten
Totaal€ 580,55
If you would like some more performance though, you could consider buying a second hand R9 280X for around €150 instead of a new GPU.
If you are willing to go a bit above your budget, this would be a nice build:
1Intel Core i5-4460 Boxed€ 178,50€ 178,50
1ASRock B85M Pro4€ 61,95€ 61,95
Bekijk collectie
Importeer producten
Totaal€ 687,10
Here it's the same again, the best option would be to go for a second hand 280X GPU.
