Hi tweakers :)
-I'm not Dutch, I don't master it that good yet; therefore I shall use English (commenting in Dutch is fine)-
My mobo arrived today, along with some other components. Everything else will arrive friday, that's when I'm going to build. Was planning on pre-downloading all my drivers to a USBstick for convenience.
When I was checking out the motherboard drivers I stumbled upon some things I don't quite understand.
Here you can find all the drivers found for this mobo.
Do I need them all? I understood the 'Intel SATA Preinstall driver' is only when my pc doesn't see any partitions and stuff. How about the others? Which one will download automatically by installing Windows and which don't?
Thomas
-edit-
Windows 10 btw
Install Windows 10 and afterwards check device manager, most of the drivers will be installed automatically by win 10.
The only one you'll need is the Realtek audio driver since the win 10 driver sometimes causes issues, but check first, maybe they got that solved.
  • Emiel1984
  • Laatst online: 00:52
Emiel1984
Made in NL
I would just have some trust in that gigabyte only includes the best working drivers on there website.
Therefore install them all. If windows already installed the same or a newer version it will tell you.
[ Voor 57% gewijzigd door Emiel1984 op 30-09-2015 22:43 ]
[LTS][MTS][HTS]
