I found this system under 500 euro.
  • 507 views
Hi people,
At first: My Dutch isn't that good yet, so it'll be English for now.
I'd like to buy a medium game pc that will run games (examples below) smoothly on lets say medium graphics, maybe with some settings to high (not ultra).
Some examples of games I like to play: World of Tanks, DayZ, Assassins Creed.
Since I simply can't afford a more expensive one, I'd like it to be under 500 euro and I know its not a lot.
I found this system for around 450 euros:
-CPU: AMD FX-4300 QuadCore 3.8ghz
-Optical: LG Dual Layer DVD/CD 24x RAM sata
-VGA: Nvidia Geforce GTX750-Ti-2Gb DDR5 -1x DVi-i, 1x VGA, 1x HDMI PCI-E
-PSU: Silent 12Cm Silence 500W power supply
-ATX: Sharkoon Blueled gaming tower with window
-HDD: Sata3 1000Gb 32Mb 7200Rpm harddisk
-RAM: Crucial 8Gb DDR3 1600mhz
-Mobo: ASROCK AM3+ Nforce 630A FX chipset with: 2x USB2.0, 2xUSB3.0 (2x USB2.0 front with audio)
Lan Gbit 10/100/1000, 5.1 Digital Sound HD audio / 4x Sata300 (raid)
1x PCiE 16x 2.0, 1XPCiE X1, 2x PCi, 1x Com, 2x PS2,
Case: D 44.5 xB 20 xH 43 cm.
+ additional card reader
(no OS, but thats not a problem)
I also don't know whether the power supply is enough.
And the CPU isn’t that great. but is it bad?
What are your opinions on this system? Especially considering I can only spend about 450 euro. Please share your thoughts.
Thomas
  • Ugraded
  • Registratie: Juni 2015
  • Laatst online: 09:37
Look in the best buy guides
  • br00ky
  • Laatst online: 09:46
br00ky
Topics in English are no problem, but you are required to use the standard lay-out and visualisation of your proposed build, just like everybody else, see DAA beleid. Since your topic fails on both items, I'll lock your topic.
