PHPMailer werkt niet via browser, wel via root commandline
  • iMars
  • Laatst online: 18:42
iMars
Full time prutser
Opgelost: iMars in "PHPMailer werkt niet via browser, wel via root commandline"
Ik heb een webserver CENTOS 6.7 x86_64 xenpv – cpanel WHM 11.50.0 (build 30).
Als ik via PHPMailer een mail wil versturen via SMTP, werkt dat niet via de website. De debug code geeft aan:
2015-09-03 04:27:46 Connection: opening to mail.*****.nl:25, timeout=300, options=array (
2015-09-03 04:28:07 SMTP ERROR: Failed to connect to server: Connection timed out (110)
2015-09-03 04:28:07 SMTP connect() failed. https://github.com/PHPMailer/PHPMailer/wiki/Troubleshooting
Mailer Error: SMTP connect() failed. https://github.com/PHPMailer/PHPMailer/wiki/Troubleshooting
Als ik deze pagina als root via de commandline uitvoer, lukt het wel:
# php test.php
2015-09-03 04:37:19	Connection: opening to ***.***.nl:25, timeout=300, options=array (
2015-09-03 04:37:19	Connection: opened
2015-09-03 04:37:19	SERVER -> CLIENT: 220 *** Microsoft ESMTP MAIL Service, Version: 6.0.3790.4675 ready at  Thu, 3 Sep 2015 06:37:19 +0200
2015-09-03 04:37:19	CLIENT -> SERVER: EHLO ***
2015-09-03 04:37:19	SERVER -> CLIENT: 250-*** Hello [*.*.*.*]
                   	                  250-TURN
                   	                  250-SIZE
                   	                  250-ETRN
                   	                  250-PIPELINING
                   	                  250-DSN
                   	                  250-ENHANCEDSTATUSCODES
                   	                  250-8bitmime
                   	                  250-BINARYMIME
                   	                  250-CHUNKING
                   	                  250-VRFY
                   	                  250-X-EXPS GSSAPI NTLM LOGIN
                   	                  250-X-EXPS=LOGIN
                   	                  250-AUTH GSSAPI NTLM LOGIN
                   	                  250-AUTH=LOGIN
                   	                  250-X-LINK2STATE
                   	                  250-XEXCH50
                   	                  250 OK
2015-09-03 04:37:19	CLIENT -> SERVER: AUTH LOGIN
2015-09-03 04:37:19	SERVER -> CLIENT: 334 VXNlcm5hbWU6
2015-09-03 04:37:19	CLIENT -> SERVER: ***
2015-09-03 04:37:19	SERVER -> CLIENT: 334 UGFzc3dvcmQ6
2015-09-03 04:37:19	SERVER -> CLIENT: 235 2.7.0 Authentication successful.
2015-09-03 04:37:19	CLIENT -> SERVER: MAIL FROM:<***@***.nl>
2015-09-03 04:37:19	SERVER -> CLIENT: 250 2.1.0 ***@***.nl....Sender OK
2015-09-03 04:37:19	CLIENT -> SERVER: RCPT TO:<***@hotmail.com>
2015-09-03 04:37:19	SERVER -> CLIENT: 250 2.1.5 ***@hotmail.com
2015-09-03 04:37:19	CLIENT -> SERVER: DATA
2015-09-03 04:37:19	SERVER -> CLIENT: 354 Start mail input; end with <CRLF>.<CRLF>
2015-09-03 04:37:19	CLIENT -> SERVER: Date: Thu, 3 Sep 2015 06:37:19 +0200
2015-09-03 04:37:19	CLIENT -> SERVER: To: Een Naam <***@hotmail.com>
2015-09-03 04:37:19	CLIENT -> SERVER: From: Een Naam <***@***.nl>
2015-09-03 04:37:19	CLIENT -> SERVER: Reply-To: Een Naam <***@***.nl>
2015-09-03 04:37:19	CLIENT -> SERVER: Subject: Test
2015-09-03 04:37:19	CLIENT -> SERVER: Message-ID: <036c1a96322c44e93a33d078d2461ef1@***.***.nl>
2015-09-03 04:37:19	CLIENT -> SERVER: X-Priority: 3
2015-09-03 04:37:19	CLIENT -> SERVER: X-Mailer: PHPMailer 5.2.10 (https://github.com/PHPMailer/PHPMailer/)
2015-09-03 04:37:19	CLIENT -> SERVER: MIME-Version: 1.0
2015-09-03 04:37:19	CLIENT -> SERVER: Content-Type: multipart/alternative;
2015-09-03 04:37:19	CLIENT -> SERVER: 	boundary="b1_036c1a96322c44e93a33d078d2461ef1"
2015-09-03 04:37:19	CLIENT -> SERVER: Content-Transfer-Encoding: 8bit
2015-09-03 04:37:19	CLIENT -> SERVER: This is a multi-part message in MIME format.
2015-09-03 04:37:19	CLIENT -> SERVER: --b1_036c1a96322c44e93a33d078d2461ef1
2015-09-03 04:37:19	CLIENT -> SERVER: Content-Type: text/plain; charset=us-ascii
2015-09-03 04:37:19	CLIENT -> SERVER: hoi
2015-09-03 04:37:19	CLIENT -> SERVER: Content-Type: text/html; charset=us-ascii
2015-09-03 04:37:19	CLIENT -> SERVER: --b1_036c1a96322c44e93a33d078d2461ef1--
2015-09-03 04:37:19	CLIENT -> SERVER: .
2015-09-03 04:37:19	SERVER -> CLIENT: 250 2.6.0  <036c1a96322c44e93a33d078d2461ef1@***.***.nl> Queued mail for delivery
2015-09-03 04:37:19	CLIENT -> SERVER: QUIT
2015-09-03 04:37:19	SERVER -> CLIENT: 221 2.0.0 *** Service closing transmission channel
2015-09-03 04:37:19	Connection: closed
Als ik het uitvoer als gebruiker van de website (su -l username), dan werkt het ook niet:
***@***.nl [~/sub_v2014/PHPMailer/test]# php test.php
2015-09-03 04:44:40	Connection: opening to ***.***.nl:25, timeout=300, options=array (
2015-09-03 04:45:01	SMTP ERROR: Failed to connect to server: Connection timed out (110)
2015-09-03 04:45:01	SMTP connect() failed. https://github.com/PHPMailer/PHPMailer/wiki/Troubleshooting
Het ziet er naar uit dat het een rechten issue is, maar ik zie even niet hoe ik dit op kan lossen.
Iemand een idee hoe ik dit wel op kan lossen?
Koop hier mijn P1 reader :)
  • fast-server
  • Laatst online: 08-11-2025
En de firewall poorten staan ook goed ingesteld ?
PV Output SolarEdge SE5000H, 12x Jinko JKM390N-6RL3 Tiger> 4,68 kWp, Helling 42°, Oriëntatie 196° (ZZW)
  • xleeuwx
  • Laatst online: 30-09 11:03
xleeuwx
developer Tweakers Elect
Via de browser wordt waarschijnlijk een andere PHP.ini ingeladen. en hier zit dan dus ook het verschil in vermoed ik.
  • iMars
iMars
Full time prutser
xleeuwx schreef op donderdag 03 september 2015 @ 13:10:
Maar als gebruiker zijnde (cPanel draait elk website onder eigen user) werkt het ook niet via de commandline, en dan wordt er geen andere php.ini geladen. Als root kan ik het wel...
Dat vind ik dan raar...
***@***.nl [~]# telnet mail.***.nl 25
Trying *.*.*.*...
^C
***@***.nl [~]# exit
logout
root@cpanel [/home/***/www]# telnet mail.***.nl 25
Trying *.*.*.*...
Connected to mail.***.nl.
Escape character is '^]'.
220 ***.***.***.nl Microsoft ESMTP MAIL Service, Version: 6.0.3790.4675 ready at  Thu, 3 Sep 2015 19:27:11 +0200
[ Voor 28% gewijzigd door iMars op 03-09-2015 19:29 ]
  • mithras
Maak je verbinding over TLS? Onder debian staan certs onder /etc/ssl/certs, leesbaar voor iedereen. Ik weet niet wat onder CentOS de map is, maar kan het hier aan liggen?
  • _JGC_
  • Laatst online: 18:15
SELinux config die geen uitgaande verbindingen toestaat? Zo ja, verdiep je erin en zorg dat het wel mogelijk wordt. Uitschakelen van SELinux is niet aan te raden.
  • iMars
iMars
Full time prutser
mithras schreef op donderdag 03 september 2015 @ 20:46:
Nope, in dit geval gewoon plain tekst...
_JGC_ schreef op donderdag 03 september 2015 @ 21:39:
Daar ga ik even naar kijken ;)
SELinux staat uit, dat is een vereiste van cPanel:
For cPanel & WHM to run on your server, SELinux must remain disabled.
bron
[ Voor 15% gewijzigd door iMars op 04-09-2015 00:34 ]
  • iMars
iMars
Full time prutser
Iemand?
  • GlowMouse
De firewall staat wellicht geen uitgaande verbindingen toe op poort 25 voor sommige users.
  • McKaamos
McKaamos
Master of the Edit-button
php.ini en php-cli.ini hebben misschien een van elkaar verschillende configuratie?
Dan werkt t wel via de CLI (Commandline Interface) maar niet via de browser.
  • iMars
iMars
Full time prutser
GlowMouse schreef op zondag 06 september 2015 @ 08:31:
Nope, zelfs met firewall tijdelijk uit, werkt het niet.
McKaamos schreef op zondag 06 september 2015 @ 08:46:
Dat is al eerder gesuggereerd, maar ook dat is het niet. Want als root werkt het wel op de commandline, en als user werkt het niet op de commandline: iMars in "PHPMailer werkt niet via browser, wel via root commandline"
  • Sneezydevil
  • Laatst online: 29-09-2025
iMars schreef op zondag 06 september 2015 @ 09:38:
Ik zou voor de zekerheid toch alle actieve iptable ( iptables -L ) regels opvragen, ik heb wel vaker cpanel servers gezien, die enkel root, cpanel en en mail toestonden om te mailen.
Ook de regels geflushed nadat je de firewall uitgeschakeld hebt?
Wat voor output krijg je bij
iptables -L | grep owner
  • iMars
iMars
Full time prutser
Sneezydevil schreef op zondag 06 september 2015 @ 10:56:
Geen output...
user@user.nl [~]# telnet mail.***.nl 25
Trying *.*.*.*...
telnet: connect to address *.*.*.*: Connection timed out
user@user.nl [~]#
user@user.nl [~]# telnet localhost 25
Trying 127.0.0.1...
Connected to localhost.
220-xxx.xxx.nl ESMTP Exim 4.85 #2 Sun, 06 Sep 2015 11:21:45 +0200
220-We do not authorize the use of this system to transport unsolicited,
220 and/or bulk e-mail.
quit
221 xxx.xxx.nl closing connection
Connection closed by foreign host.
user@user.nl [~]#
Lokaal kan ik wel telnetten, maar niet extern, en er wordt op de server niks geblokkeerd op port 25 naar buiten. Ook niet door de provider.
[ Voor 41% gewijzigd door iMars op 06-09-2015 11:29 ]
  • iMars
iMars
Full time prutser
root@xxx [/root]# iptables -S | grep port | more
-A OUTPUT -p tcp -m tcp --dport 25 -m owner --gid-owner mailman -j ACCEPT
-A OUTPUT -p tcp -m tcp --dport 25 -m owner --gid-owner mail -j ACCEPT
-A OUTPUT -p tcp -m tcp --dport 25 -m owner --uid-owner cpanel -j ACCEPT
-A OUTPUT -p tcp -m tcp --dport 25 -m owner --uid-owner root -j ACCEPT
-A OUTPUT -p tcp -m tcp --dport 25 -j DROP
Dit verklaard een hoop |:( Ik weet nu waar het probleem zit...
  • Sneezydevil
Naar die was ik inderdaad opzoek.
