• sjoerdgl
  • Laatst online: 18-10 17:23
Mijn broertje was vanochtend Minecraft aan het spelen en opeens begon het erg te laggen en na 5 seconden kreeg hij een BSOD.
Ik heb nu dus even gekeken in de .dmp file, maar ik heb daar helemaal geen verstand van dus ik heb geen idee of het nou foute boel is of niet...
Dit stond er in:
spoiler:
PAGE_FAULT_IN_NONPAGED_AREA (50)
Invalid system memory was referenced. This cannot be protected by try-except.
Typically the address is just plain bad or it is pointing at freed memory.
Arguments:
Arg1: ffffe00000000018, memory referenced.
Arg2: 0000000000000000, value 0 = read operation, 1 = write operation.
Arg3: fffff8017ccd24a2, If non-zero, the instruction address which referenced the bad memory
address.
Arg4: 0000000000000002, (reserved)
Debugging Details:
Could not read faulting driver name
SYSTEM_SKU: To Be Filled By O.E.M.
SYSTEM_VERSION: To Be Filled By O.E.M.
BIOS_DATE: 04/24/2015
BASEBOARD_PRODUCT: H81M-HDS
BASEBOARD_VERSION:
BUGCHECK_P1: ffffe00000000018
BUGCHECK_P2: 0
BUGCHECK_P3: fffff8017ccd24a2
BUGCHECK_P4: 2
READ_ADDRESS: fffff80120247500: Unable to get MiVisibleState
ffffe00000000018
FAULTING_IP:
cpuz138_x64+24a2
fffff801`7ccd24a2 488b4a18 mov rcx,qword ptr [rdx+18h]
MM_INTERNAL_CODE: 2
CPU_COUNT: 4
CPU_MHZ: c7f
CPU_VENDOR: GenuineIntel
CPU_FAMILY: 6
CPU_MODEL: 3c
CPU_STEPPING: 3
CUSTOMER_CRASH_COUNT: 1
DEFAULT_BUCKET_ID: WIN8_DRIVER_FAULT
BUGCHECK_STR: AV
PROCESS_NAME: Speccy64.exe
CURRENT_IRQL: 0
ANALYSIS_VERSION: 10.0.10240.9 amd64fre
TRAP_FRAME: ffffd001269573d0 -- (.trap 0xffffd001269573d0)
NOTE: The trap frame does not contain all registers.
Some register values may be zeroed or incorrect.
rax=0000000000000000 rbx=0000000000000000 rcx=0000000000000000
rdx=ffffe00000000000 rsi=0000000000000000 rdi=0000000000000000
rip=fffff8017ccd24a2 rsp=ffffd00126957560 rbp=ffffd00126957b80
r8=ffffe0001b2ff8c0 r9=000000000000000e r10=0000000020206f49
r11=ffffe000185ef2c0 r12=0000000000000000 r13=0000000000000000
r14=0000000000000000 r15=0000000000000000
iopl=0 nv up ei pl zr na po nc
cpuz138_x64+0x24a2:
fffff801`7ccd24a2 488b4a18 mov rcx,qword ptr [rdx+18h] ds:ffffe000`00000018=????????????????
Resetting default scope
LAST_CONTROL_TRANSFER: from fffff801200210af to fffff8011ffd0220
STACK_TEXT:
ffffd001`26957188 fffff801`200210af : 00000000`00000050 ffffe000`00000018 00000000`00000000 ffffd001`269573d0 : nt!KeBugCheckEx
ffffd001`26957190 fffff801`1fea25f6 : 00000000`00000000 00000000`00000000 ffffd001`269573d0 ffffe000`19f97840 : nt! ?? ::FNODOBFM::`string'+0x422af
ffffd001`26957280 fffff801`1ffd92bd : ffffe000`1a44d2e0 fffff801`200f5297 ffffe000`187ebd90 ffffe000`19f97840 : nt!MmAccessFault+0x696
ffffd001`269573d0 fffff801`7ccd24a2 : 00000000`00000001 ffffe000`187ebd00 ffffe000`19fca2f0 00000000`00000000 : nt!KiPageFault+0x13d
ffffd001`26957560 00000000`00000001 : ffffe000`187ebd00 ffffe000`19fca2f0 00000000`00000000 ffffc001`628ec0c0 : cpuz138_x64+0x24a2
ffffd001`26957568 ffffe000`187ebd00 : ffffe000`19fca2f0 00000000`00000000 ffffc001`628ec0c0 fffff801`200f5297 : 0x1
ffffd001`26957570 ffffe000`19fca2f0 : 00000000`00000000 ffffc001`628ec0c0 fffff801`200f5297 00000000`0268dbe0 : 0xffffe000`187ebd00
ffffd001`26957578 00000000`00000000 : ffffc001`628ec0c0 fffff801`200f5297 00000000`0268dbe0 fffff801`2039c2d7 : 0xffffe000`19fca2f0
STACK_COMMAND: kb
FOLLOWUP_IP:
cpuz138_x64+24a2
SYMBOL_STACK_INDEX: 4
SYMBOL_NAME: cpuz138_x64+24a2
FOLLOWUP_NAME: MachineOwner
MODULE_NAME: cpuz138_x64
IMAGE_NAME: cpuz138_x64.sys
DEBUG_FLR_IMAGE_TIMESTAMP: 544918a9
BUCKET_ID_FUNC_OFFSET: 24a2
FAILURE_BUCKET_ID: AV_R_INVALID_cpuz138_x64!Unknown_Function
PRIMARY_PROBLEM_CLASS: AV_R_INVALID_cpuz138_x64!Unknown_Function
ANALYSIS_SOURCE: KM
FAILURE_ID_HASH_STRING: km:av_r_invalid_cpuz138_x64!unknown_function
FAILURE_ID_HASH: {3be5dd40-dca3-f763-9fb6-38774183ad50}
Followup: MachineOwner
Geen idee wat het inhoud maar het heeft dus met de CPU te maken..?
Dit is mijn PC:
#ProductPrijsSubtotaal
1Intel Core i5-4460 Boxed€ 183,95€ 183,95
1ASRock H81M-HDS€ 48,95€ 48,95
1MSI R9 380 Gaming 4GB€ 248,-€ 248,-
1Fractal Design Core 1100€ 27,95€ 27,95
1Crucial Ballistix BLS2CP4G3D1609DS1S00CEU€ 46,95€ 46,95
1Cooler Master GM G450M€ 52,50€ 52,50
1Crucial BX100 250GB€ 82,95€ 82,95
Bekijk collectie
Importeer producten
Totaal€ 691,25
Een paar weken geleden gebouwd...
Alvast bedankt!
  • Afvalzak
  • Registratie: Oktober 2008
  • Laatst online: 10-10 21:20
Afvalzak
Zet jij mij even buiten?
Als je op Google zoekt naar de foutmelding:
MSDN: Bug Check 0x50: PAGE_FAULT_IN_NONPAGED_AREA - Windows 10 hardware dev
Bug check 0x50 usually occurs after the installation of faulty hardware or in the event of failure of installed hardware (usually related to defective RAM, be it main memory, L2 RAM cache, or video RAM).
Another common cause is the installation of a faulty system service.
Antivirus software can also trigger this error, as can a corrupted NTFS volume.
Ik zou dus even memcheck draaien en je drivers nalopen.
Last.fm | Code Talks
  • sjoerdgl
Afvalzak schreef op maandag 03 augustus 2015 @ 12:48:
Memtest bedoel je dan?
  • Afvalzak
Afvalzak
Inderdaad sorry. 8)7
  • sjoerdgl
Oké, maar mijn RAM en zo doet het nog gewoon...
Of kunnen er ook nog fouten zijn terwijl de RAM het wel gewoon doet waardoor ik (vaker) een BSOD krijg?
  • F.West98
  • Laatst online: 02:37
F.West98
Alweer 17 jaar hier
Ja. Dan zijn er maar een paar bits in je RAM niet goed waardoor die net verkeerd gaan. De rest doet het wel normaal.
2x ViewSonic VP-27885K | R9 7950X | 128GB RAM | 980 Pro 2TB x2 | RTX2070 Super
.oisyn: Windows is net zo slecht in commandline als Linux in GUI
  • Afvalzak
Afvalzak
SjoerdJJ schreef op maandag 03 augustus 2015 @ 12:56:
Zeker, het kan zijn dat dat "stukje" van de RAM niet goed is, dat zie je dan met die Memtest.
Maar dit is nu 1 keer gebeurd?
  • sjoerdgl
Afvalzak schreef op maandag 03 augustus 2015 @ 12:58:
Ja, verder nooit ergens last van gehad...
Weet niet of het hier ook door kan komen, maar ik heb bij Minecraft vsync niet aan staan...
Dus heb soms 130 FPS en als je dan bijvoorbeeld in een laadscherm komt dat ik dan opeens 1000 fps heb bijvoorbeeld.
  • redfoxert
Ik zie geen CPU melding maar wel een melding van de applicatie cpuz138_x64
  • sjoerdgl
redfoxert schreef op maandag 03 augustus 2015 @ 13:01:
Oké en (hoe) kan die een BSOD veroorzaken?
  • redfoxert
SjoerdJJ schreef op maandag 03 augustus 2015 @ 13:03:
Doordat het ding zich als een driver installeert en drivers rechtstreeks met de Windows kernel kunnen praten. Als daar iets fout gaat heb je direct een BSOD aan je fiets hangen.
  • sjoerdgl
Oké, dan zal ik eerst wel even alle drivers nakijken en updaten.
  • redfoxert
SjoerdJJ schreef op maandag 03 augustus 2015 @ 13:10:
Je drivers zijn niet het probleem. CPUZ is het probleem ... die "gedraagt" zich als een driver. Update die als het probleem echt vaak voorkomt met dezelfde oorzaak (dus zoals die in je startpost).
Overigens, Speccy64.exe is het proces waar het op mis ging. Die zal onder water wel gebruik maken van CPUZ om info te tonen.
[ Voor 29% gewijzigd door redfoxert op 03-08-2015 13:20 ]
  • sjoerdgl
redfoxert schreef op maandag 03 augustus 2015 @ 13:18:
Dus als ik CPU-Z nou is verwijder, zou het dan ook opgelost zijn?
Gebruik het programma toch nooit.
Speccy gebruik ik om te kijken of mijn CPU niet te heet word bij games.
Dat doe ik bijvoorbeeld bij games die ik dan voor de eerste keer speel en dan wil ik even kijken hoe heet de CPU word.
[ Voor 23% gewijzigd door sjoerdgl op 03-08-2015 13:24 ]
  • redfoxert
SjoerdJJ schreef op maandag 03 augustus 2015 @ 13:21:
Verwijderen of updaten maar mogelijk raak je dan ook de functionaliteit van Speccy. Zorg voor updated versies van die software en je hebt waarschijnlijk je probleem verholpen.
  • sjoerdgl
redfoxert schreef op maandag 03 augustus 2015 @ 13:26:
Oké, zal alles ff updaten / verwijderen.
Bedankt iedereen voor jullie hulp :).
Gelukkig valt het dus mee voor het zelfde geld was er wel iets ernstig mis met mijn computer.
Dit was gelukkig niet het geval _/-\o_
