ohw jah hier nog ff de log-file van nero
oemuser
oemuser
1594-0499-2229-3054-6180-4637
Windows 98 4.10
WinAspi: File 'Wnaspi32.dll': Ver=1, 0, 0, 0, size=36864 bytes, created 5-5-1999 22:22:00
Nero Version: 5.0.0.3
Recorder: <HP CD-Writer+ 9100b> Version: 1.06 - HA 2 TA 1 - 5.0.0.3
Adapter driver: <ESDI_506> HA 2
Drive buffer : 2048kB
CD-ROM: <CREATIVE DVD-ROM DVD1241E>Version: 0.36 - HA 2 TA 0
CREATIVE DVD-ROM DVD1241E (Target 0, E:): Autoinsert On, DMA On, Disconnect On, SyncDataXfer Off
HP CD-Writer+ 9100b (Target 1, F:): Autoinsert On, DMA On, Disconnect On, SyncDataXfer Off
CmdQueuing : 1
CmdNotification: 2
WriteBufferSize: 34603008 (0) Byte
ShowDrvBufStat : 0
EraseSpeed : 0
BUFE : 0
Physical memory : 255MB (261508kB)
Free physical memory: 105MB (108272kB)
Memory in use : 45 %
Uncached PFiles: 0xFF
Wizard: Off
CD-Copy
13.4.2001
15:26:04#1 Phase 48 File dlgbrnst.cpp, Line 1147
Analyzing CD
15:26:04#2 SCSI -1044 File Cdrdrv.cpp, Line 1093
SCSI Exec, HA 2, TA 0, LUN 0, buffer 0x0135E6D8
Status: 0x04 (0x01, SCSI_ERR)
HA-Status 0x00 (0x00, OK)
TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND)
Sense Key: 0x05 (KEY_ILLEGAL_REQUEST)
Sense Code: 0x24
Sense Qual: 0x00
CDB Data: 0x5A 0x00 0x0D 0x00 0x00 0x00 0x00 0x00 0x10 0x00 0x00 0x00
Sense Data: 0x70 0x00 0x05 0x00 0x00 0x00 0x00 0x0A
0x00 0x00 0x00 0x00 0x24 0x00
15:26:04#3 Text 0 File CDCopy.cpp, Line 2241
session 0 (0 - 0): last session
15:26:04#4 CDCOPY -1 File CDCopy.cpp, Line 2374
CD is copyrighted
15:26:05#5 Text 0 File CDCopy.cpp, Line 2592
Index0 Index1 PostPause LastBlockOfTrack
Track 1: 0 0 343430 343429
15:26:05#6 Text 0 File CDCopy.cpp, Line 896
with subcode, without jitter corr.
15:26:05#7 Text 0 File CDCopy.cpp, Line 927
does not look like CD Extra
01. 0 - 343430 = 343430, data (0)
15:26:05#8 Text 0 File CDCopy.cpp, Line 964
drive doesn't read subcode, copy via image, new audio code => scan indices
15:26:05#9 Phase 20 File dlgbrnst.cpp, Line 1147
Start of read CD
15:30:35#10 SCSI -1024 File Cdrdrv.cpp, Line 1093
SCSI Exec, HA 2, TA 0, LUN 0, buffer 0x0257A7DC
Sense Key: 0x04 (KEY_HARDWARE_ERROR)
Sense Code: 0x08
Sense Qual: 0x01
CDB Data: 0x28 0x00 0x00 0x05 0x3D 0x80 0x00 0x00 0x06 0x00 0x00 0x00
Sense Data: 0x70 0x00 0x04 0x00 0x00 0x00 0x00 0x0A
0x00 0x00 0x00 0x00 0x08 0x01
15:30:35#11 CDR -1024 File CDCopy.cpp, Line 3522
Communication failure
15:30:35#12 CDCOPY -27 File CDCopy.cpp, Line 1306
Results of analyzing the source CD:
Track 00: Index0=00:00.00, Index1=??
?.??, End=954437:10.45, Mode=TRM_DATA_MODE1, Blocksize=2048, Track config=0x00
15:30:38#13 Phase 22 File dlgbrnst.cpp, Line 1147
Read CD failed
15:30:38#14 Text 0 File Scsicmd.cpp, Line 260
SCSI not using temporary buffers
15:30:38#15 Text 0 File Scsicmd.cpp, Line 283
10 out of 10 temporary buffers allocated
15:30:38#16 Text 0 File WinNeroThreads.cpp, Line 909
Thread priorities:
Pri. name -> class / level
0. Idle -> 32 / -15 = default
1. Background -> 32 / -2 = default
2. Normal -> 32 / 0 = default
3. HighIdle -> 128 / -1 = default
4. High -> 128 / 0 = default
5. Higher -> 128 / 1 = default
6. Realtime -> 128 / 2 = default
Existing drivers:
File 'IoSubSys\SCSI1HLP.VXD': Ver=4.10.1998, size=19270 bytes, created 5-5-1999 22:22:00
File 'IoSubsys\NEROCD95.VXD': Ver=4, 0, 0, 8, size=30887 bytes, created 5-2-2001 15:21:54
File 'IoSubsys\DRVWPPQT.VXD': Ver=3.10.36a, size=228223 bytes, created 5-5-1999 22:22:00
File 'IoSubsys\CDFS.VXD': Ver=4.10.1998, size=59133 bytes, created 5-5-1999 22:22:00
